Quantcast Dead Spot in Electronic Throttle? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Dead Spot in Electronic Throttle?
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 06-08-2008, 03:26 PM   #1
Millermagic
I've driven a few vehicles with electronic throttle. It seems that the first 1/8 to 1/4 of the electronic throttle doesn't work. It does change in 4lo.
I do know that it changes the electronic throttle response for 4lo and 2hi, but should there be a dead spot?
AND does anyone else notice that the engine doesn't slow down when upshifting? It usually takes 3-4 seconds for it to slow down when shifting from 1 and usually around 2 in any other gear.
The cool thing is when I drive the f350 I keep spinning the tires from a stop because it doesn't have a dead spot haha.
2000XJ - 4.0/AW4 - 95k
2001 F350 - 5.4 5 speed 4.10s - 55k - Very rusty [shared]
2008 JK Rubicon - 3.8/NSG370 - 40k Miles - Moms
Millermagic is offline   Reply With Quote
Old 06-08-2008, 05:28 PM   #2
specs
My 07 Sahara does the same thing. Try hitting the button to turn off the overdrive. Made all the difference in mine.
specs is offline   Reply With Quote
Old 06-11-2008, 01:41 PM   #3
Millermagic
It's a 6 speed. Here's something else I noticed while driving it. The dead spot goes away when moving.
Old 06-11-2008, 08:13 PM   #4
Warlord2
never noticed a dead spot on my 6spd..
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline   Reply With Quote
Old 06-11-2008, 09:21 PM   #5
LHS-Cowboy
DETN8R
LHS-Cowboy's Avatar
me neither.
'08 DETN8R Yellow Unlimited Rubi
6-Spd / Soft top / Power / Side Air Bags
Installed:
R.E. 3.5" (4" now) Super Flex Kit & Ft. driveshaft/Full Traction Rear Adj. Trackbar/Rancho (4" long arm) 9000XL shocks/Superior 4.88 Gears & Evo Rear Axle Shafts/37" Goodyear MTR's/Poly Perf. Rock Sliders/Shrockworks Mid Ft. & Prototype Rear Bumper/Custom High Steer with PSC Hydro Assist/Plumbed Warn PowerPlant/Cobra 75 WS XT C.B./Prototype Bully Dog Programmer/Custom Exhaust/Dual Optimas/48" X-treme Hi-Lift Jack on custom mount & brace...
____oooo
[ l_,[____],
l---L -[
OlllllllO]
( )_) ( )_)--)_)
LHS-Cowboy is offline   Reply With Quote
Old 06-11-2008, 11:08 PM   #6
DinnerYeti
I have noticed this as well. In fact the first few days driving it in town, I almost stalled it. I just feather the throttle a little bit now to work the RPM's up some before i start engaging the clutch.
DinnerYeti is offline   Reply With Quote
Old 06-12-2008, 09:51 AM   #7
firefly
Yes, there is no response in my auto when I feather the throttle while under way. I'm not a big fan of fly by wire.
TJ Sahara (with Plow)
BMW 330xi (Sold!)
BMW X3
65 Vette ragtop
2008 JK Sahara Unlimited
firefly is offline   Reply With Quote
Old 06-12-2008, 06:20 PM   #8
JhawkJK
I have it on my six speed. Drives me up the wall.
'07 Steel Blue Rubicon Unlimited
JhawkJK is offline   Reply With Quote
Old 06-12-2008, 06:21 PM   #9
waterboarder
waterboarder's Avatar
Mine has a dead spot - that seems to go from 0 to 80mph. Probably goes on past 80 too, but I've never tried it.
waterboarder is offline   Reply With Quote
Old 06-13-2008, 01:14 AM   #10
Mountaineer19
US Army
Mine does the same thing. I don't know what to do about it at all.
Mountaineer19 is offline   Reply With Quote
Old 06-13-2008, 08:43 PM   #11
Millermagic
Well glad it's not just this wrangler. Is it possible that Chrysler did it on purpose?
I'm the only one that really has a problem with it in the family so it's not a big concern really.
Old 06-13-2008, 09:07 PM   #12
techmule
Same thing here with the dead spot and 6speed. I came to the JK from a TJ straight 6 where you just let the clutch fly and it moved. I did stall the engine on the JK a few times before I retrained myself on shifting with this different engine. I have to slight rev the engine from a dead stop. No problems when vehicle is in motion. This has got to be a program bug with the wire throttle. Maybe there is something that can be flashed to offer a fix.
techmule is offline   Reply With Quote
Old 06-13-2008, 10:17 PM   #13
REXEY
I have seen on other Jeep sites they are having the same problem! Someone needs to forward this to Jeep!
If you can't get there by a Jeep, why would you go?
REXEY is offline   Reply With Quote
Glock Forum
