Dead Electrical Circuit - JeepForum.com
post #1 of 8 Old 12-23-2010, 11:28 AM Thread Starter
Chad07
I seem to have a dead electrical circuit in my '07 Unlimited X. In the fuse box it looks like a single fuse powers the interior dome lights and the switch bank (hazards and esp off). None of these items work. Can't turn on the dome lights, no 4 ways, and can't turn off the esp. Fuses are all fine. Does anyone know where to search for a broken wire or loose connection in this circuit? Or is there a relay I am missing?
Chad07 is offline
post #2 of 8 Old 12-23-2010, 11:41 AM
muttytruckster
If you have checked all the fuses, the quick and easy thing to do is unhook one terminal on the battery and let it sit for a minute or more and then hook it back up.
Might be worth a try, might not do anything but make you reset your radio stations.
2007 Jeep Wrangler Unlimited Rubicon -JKUR
Rescue Green 6-Spd, 33" KM2s- 17 x 8 BlackRock Series 909 wheels, Stainless Steel Gibson Exhaust & AFE Air Intake, Superchips, Aberle Front Bumper&10.5K Winch, PiAA ATP Lights
muttytruckster is offline
post #3 of 8 Old 12-23-2010, 11:47 AM Thread Starter
Chad07
I replaced the battery about a month ago because it was getting weak. I had the problem before and still have it after the battery job. I will try it for kicks, but seems like there is an open spot in the circuit somewhere.
Chad07 is offline
post #4 of 8 Old 12-23-2010, 11:53 AM
ronjenx
ronjenx's Avatar
Anytime you disconnect the battery, disconnect the negative terminal first for safety reasons; even if you intend to disconnect only one lead.
ronjenx is offline
post #5 of 8 Old 12-23-2010, 12:53 PM
JK-Ford
It sounds to me that everything on that circuit doesn't work. In my experience, when everything is off on one circuit, the open spot is usually the fuse.
The Green Monster
2007 JK-XS 2-door Jeep Green
130w KC 6" Long Range on Smittybuilt brackets
130w KC 6" Driving Beams on Grab Bar Mod
Rock light mod
Reverse light mod
JK-Ford is offline
post #6 of 8 Old 12-23-2010, 06:04 PM Thread Starter
Chad07
I would love to find a problem with the fuse, but swapping in a new one does not change the situation. The connectors are still in place at the base of the fuse also, so I know the power is at least that far. Does anyone have an electrical schematic or a link to one online to chase wire colors, etc.? I can't seem to find one.
Chad07 is offline
post #7 of 8 Old 04-20-2011, 08:32 AM Thread Starter
Chad07
Solution
I
Chad07 is offline
post #8 of 8 Old 04-20-2011, 08:37 AM Thread Starter
Chad07
Solution
I know this is an old thread, but here's what I did to make it work. I found a good mechanic that would work with me for about 20 minutes with his access to schematics. He helped me find the right wire on the bottom of the power module/fuse panel. It was hot, so we took the dash apart and got to the back side of the hazard switch, found the wire that should have been hot (it was dead), we ran a new wire from the fuse panel to the hazard switch and tied the two together. Still fed through the correct fuse, all parts of the circuit now work fine. Great solution from the helpful mechanic, since there was no way we were going to actually follow the wire through the looms, plugs, splits, etc. Works like a dream. Thanks to those that suggested other fixes.
Chad07 is offline
Electrical brake circuit fried sduncan TJ Wrangler Technical Forum 6 10-02-2010 09:50 PM
in-cab electrical ALL dead, gauges, lights and switches whatevah TJ Wrangler Technical Forum 5 08-04-2010 09:04 PM
Dead Jeep! Electrical/Fuse Issue?? malo8899 TJ Wrangler Technical Forum 3 05-23-2010 09:49 PM
P0740 TCC Enable Solenoid Circuit Electrical - TCC is torque converter clutch. DesertJeep2002 TJ Wrangler Technical Forum 6 04-03-2009 06:32 PM
Help! Electrical gremlins! Jeep's completly dead! drummerdude1234 TJ Wrangler Technical Forum 5 01-13-2009 04:41 PM
