Daystar Dash Panel Mod - Complete Write-Up - JeepForum.com
post #1 of 28 Old 11-22-2010, 03:40 PM Thread Starter
vjr021
2009 JK Wrangler
Let me begin with apologies to the original poster of this idea, over on JK-Forum. This is in no means meant to step on his toes, and I have to give full credit to him for posting this idea first... The original post can be found here: DayStar dash panel mod
I made a few tweaks, and wanted to document the mod a little better for those attempting it.
Items Needed:
  • Daystar JK Dash Panel
  • Bungee Cord variety pack (Bought at Lowe's)
  • Black Anti-Slip Drawer Liner (Purchased at Target)
  • Rubber Grommets (9/16 OD x 1/4 OD, Lowe's)
  • (2) 1/8" Wire Rope Clips (Lowe's)
  • (4) 10/24 Nuts with Nylon inserts (Lowe's)
Materials Needed:
  • Spray Glue (I used the 3M Super 77)
  • Masking or Electrical tape (to put on drill bit)
  • Paper Towels
Tools Needed:
  • Sharp Razor Blade (knife or raw blade)
  • straight edge ruler
  • Pick Set
  • Flat Screwdriver
  • Phillips screwdriver
  • needle nose pliers
  • socket set
  • lighter
  • Drill and drill bits
Let's Begin:
1. Here's what I started with:
2. In the Bungee Cord pack you will find this cord, if you are like me, it will be at the bottom of the can, never getting used:
3. Using the needle nose pliers, pull the knot out of the back of the plastic ball...
4. Then cut the knot off the ball.
5. As you can see this is the perfect color and length:
6. Here is the hardware I used:
7. The dimensions for the inserts are as follows:
Bottom Insert: 2" x 5 1/2"
Top Insert: 2" x 8 1/4"
8. Using your straight Edge ruler, cut to the dimensions... I did not glue them at this time, but here is how they look placed in it.
9. The backsplash measurements are as such:
Back Splash: 8 1/4" x 1 3/4"
vjr021 is offline
post #2 of 28 Old 11-24-2010, 02:14 PM
Green08
Funny, I have had this for a long time, put the drawer liner on from day one, never thought about the bungy cord. I need to get this on now, this will make this perfect. Thanks...
Green08 is offline
post #3 of 28 Old 11-24-2010, 02:31 PM Thread Starter
vjr021
2009 JK Wrangler
there was more to this, but I was cut-off before I could finish it.
vjr021 is offline
post #4 of 28 Old 11-24-2010, 02:34 PM Thread Starter
vjr021
2009 JK Wrangler
10. I used the width of my small ruler and went in 1" on either side, marking the location with a straight pick.
11. Using your tape, section off the drill bit (I used a small one to start and went up to 5/8" for final hole) This is to prevent you drilling through the back of the back splash, which will really piss you off!!!
12. Result:
13. Now work the rubber grommet into the holes, be sure to check the back, sometimes the edges get bunched up, this will cause the grommet to not lay correctly. Here's how it looked:
For me, this was the biggest change, as I could not locate the grommets SJG used, and I thought the black rubber looked better, IMHO
13. Pull the bungee through one of the holes, and lightly singe the ends with a lighter, this is to prevent them from falling apart.
14. With the rope clamps, I threw out the included nuts and went with the nylon inserted ones, this is to prevent the nuts from loosening up due to use and vibrations later one.
The fitment is tight, but they will go on, you might not be able to use your sockets to fully tighten them down, I had to use my pliers at the end.
vjr021 is offline
post #5 of 28 Old 11-24-2010, 02:34 PM Thread Starter
vjr021
2009 JK Wrangler
15. This si the tricky part... You have to pull some tension in the cord when clamping on the other side... this will allow you to clamp the cord about 1.5 inches out from the hole, giving you some room to work. When you let the tension out of the cord, it will spring back and suck the clamp in the space...
16. Next I laid out some paper towels and sprayed one side of the liners. Let dry for about 15 seconds, then place on the panel.
17. DONE!!
18. Follow the install instructions Daystar provided and here is the result:
Before:
After:
vjr021 is offline
post #6 of 28 Old 11-24-2010, 04:52 PM
MacK
2015 JK Wrangler
I'm going to have to do this! My Daystar Dash panel looks like CRAP it's so old. Did they fix the bend at the bottom of it? Looks like it's not there anymore.
I don't want your d**n lemons! What the hell are these?! Demand to see life's manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I'm the man who's gonna burn your house down! WITH THE LEMONS! I'm gonna get my engineers to invent a combustible lemon that BURNS YOUR HOUSE DOWN!
Mango Tango 2010 JK Wrangler Rubicon
Silver 2000 TJ Wrangler Sport
The 2008 Jeep Wrangler is not so much an SUV as it is an experience. It's slow and loud, handles poorly, has crummy interior materials and features doors that provide virtually no crash protection. But when it comes to off-road performance, the Wrangler is simply the best choice available.
MacK is offline
post #7 of 28 Old 11-24-2010, 08:38 PM
rirrgang
I like it but I think I might of just tied knots in the bungee instead of all the hardware.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #8 of 28 Old 11-25-2010, 12:08 AM
herculz
2010 JK Wrangler
does this sit on top of that existing center piece or do you have to remove it and insert the new one?
herculz is offline
post #9 of 28 Old 11-25-2010, 12:12 AM
MacK
2015 JK Wrangler
I was thinking the same thing, but I think he did that because it would be somewhat hard to get the knot in the right spot. I'm going to run wires through mine so I can hook my MP3 or phone to it =)
MacK is offline
post #10 of 28 Old 11-25-2010, 08:02 AM
cj-ing-rj
1973 CJ5
Good call on the bungee. Do you have the compass option in your JK? If so did you still attached the module to the bottom side of the Daystar dash or did you need to relocate that???
cj-ing-rj is offline
post #11 of 28 Old 11-26-2010, 10:04 AM
Mol
Disclaimer: I'm Polish
Mol's Avatar
Maybe I'm an idiot....but what do you hold with the bungee?
Great finish work
Mol is offline
post #12 of 28 Old 11-26-2010, 10:10 AM
echo1
2010 JK Wrangler
Great finish work
A phone comes to mind. Something like the iPhone propped up letting you see a map or what have you.
echo1 is offline
post #13 of 28 Old 11-30-2010, 12:58 AM
Butterbuddha
2010 JK Wrangler
The knots will hold just fine, ask any kayaker
YOU CAN'T HANDLE THE TRUTH!
Butterbuddha is offline
post #14 of 28 Old 11-30-2010, 02:57 AM
1222
RIP John
1222's Avatar
I think you did an excellent job. Look fantastic.
(2011-2016)
1222 is offline
post #15 of 28 Old 11-30-2010, 04:58 AM
RAZORBILL
RAZORBILL's Avatar
2014 JK Wrangler
Great work!! I did the same thing minus the grommets. The grommets make it cleaner looking, I might have to grab some. I did just tie a couple knots in the bungee, works fine. I also added a couple led lights to get a bit of light up front.
Previously owned: 80 CJ-5, 97 TJ,99 XJ, 95 YJ,10 JK Rubicon Unlimited, 10 JK Sport
RAZORBILL is offline
daystar dash tray , diy , JK Wrangler , modified daystar dash , wrangler
Daystar Dash Panel z_gilligan JK Wrangler Technical Forum 7 08-06-2010 01:03 AM
Daystar Upper Dash Panel pjv01 JK Wrangler Technical Forum 10 03-07-2010 07:11 PM
daystar uper dash panel Rscal1986 JK Wrangler Technical Forum 20 04-17-2009 06:53 AM
Help: Daystar Dash Panel Maldoro JK Wrangler Technical Forum 11 10-24-2008 08:58 PM
Daystar Upper Dash Panel JK_Jeep JK Wrangler Technical Forum 14 04-08-2008 07:22 PM
