-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Daystar Dash Panel Mod - Complete Write-Up (http://www.jeepforum.com/forum/f96/daystar-dash-panel-mod-complete-write-up-1131770/)
vjr021 11-22-2010 02:40 PM
Let me begin with apologies to the original poster of this idea, over on JK-Forum. This is in no means meant to step on his toes, and I have to give full credit to him for posting this idea first... The original post can be found here: DayStar dash panel mod
I made a few tweaks, and wanted to document the mod a little better for those attempting it.
Items Needed:
  • Daystar JK Dash Panel
  • Bungee Cord variety pack (Bought at Lowe's)
  • Black Anti-Slip Drawer Liner (Purchased at Target)
  • Rubber Grommets (9/16 OD x 1/4 OD, Lowe's)
  • (2) 1/8" Wire Rope Clips (Lowe's)
  • (4) 10/24 Nuts with Nylon inserts (Lowe's)
Materials Needed:
  • Spray Glue (I used the 3M Super 77)
  • Masking or Electrical tape (to put on drill bit)
  • Paper Towels
Tools Needed:
  • Sharp Razor Blade (knife or raw blade)
  • straight edge ruler
  • Pick Set
  • Flat Screwdriver
  • Phillips screwdriver
  • needle nose pliers
  • socket set
  • lighter
  • Drill and drill bits
Let's Begin:
1. Here's what I started with:
http://farm5.static.flickr.com/4126/...eaafa732_z.jpg
2. In the Bungee Cord pack you will find this cord, if you are like me, it will be at the bottom of the can, never getting used:
http://farm5.static.flickr.com/4110/...53bfd07c_z.jpg
3. Using the needle nose pliers, pull the knot out of the back of the plastic ball...
http://farm2.static.flickr.com/1019/...248fa70c_z.jpg
4. Then cut the knot off the ball.
http://farm5.static.flickr.com/4087/...fe9b5e6a_z.jpg
5. As you can see this is the perfect color and length:
http://farm2.static.flickr.com/1273/...97606689_z.jpg
6. Here is the hardware I used:
http://farm2.static.flickr.com/1038/...6b13dfb2_z.jpg
http://farm5.static.flickr.com/4087/...388fa5a4_z.jpg
7. The dimensions for the inserts are as follows:
Bottom Insert: 2" x 5 1/2"
Top Insert: 2" x 8 1/4"
http://farm2.static.flickr.com/1039/...28d65da8_m.jpghttp://farm5.static.flickr.com/4147/...49ea192c_m.jpg
http://farm2.static.flickr.com/1272/...4c4f3880_m.jpghttp://farm2.static.flickr.com/1304/...51ea1cfc_m.jpg
8. Using your straight Edge ruler, cut to the dimensions... I did not glue them at this time, but here is how they look placed in it.
http://farm2.static.flickr.com/1306/...eb5674b9_z.jpg
9. The backsplash measurements are as such:
Back Splash: 8 1/4" x 1 3/4"
http://farm5.static.flickr.com/4154/...e6d2a822_m.jpghttp://farm5.static.flickr.com/4131/...9b31906e_m.jpg
Green08 11-24-2010 01:14 PM
Funny, I have had this for a long time, put the drawer liner on from day one, never thought about the bungy cord. I need to get this on now, this will make this perfect. Thanks...
vjr021 11-24-2010 01:31 PM
there was more to this, but I was cut-off before I could finish it.
vjr021 11-24-2010 01:34 PM
10. I used the width of my small ruler and went in 1" on either side, marking the location with a straight pick.
http://farm5.static.flickr.com/4127/...d1a747c2_z.jpg
11. Using your tape, section off the drill bit (I used a small one to start and went up to 5/8" for final hole) This is to prevent you drilling through the back of the back splash, which will really piss you off!!!
http://farm5.static.flickr.com/4129/...7b81a6b2_z.jpg
12. Result:
http://farm2.static.flickr.com/1027/...976386d9_z.jpg
13. Now work the rubber grommet into the holes, be sure to check the back, sometimes the edges get bunched up, this will cause the grommet to not lay correctly. Here's how it looked:
http://farm5.static.flickr.com/4131/...334ba66a9b.jpghttp://farm2.static.flickr.com/1283/...3668fe6f2f.jpg
For me, this was the biggest change, as I could not locate the grommets SJG used, and I thought the black rubber looked better, IMHO
13. Pull the bungee through one of the holes, and lightly singe the ends with a lighter, this is to prevent them from falling apart.
http://farm2.static.flickr.com/1275/...e0c2374b_z.jpg
14. With the rope clamps, I threw out the included nuts and went with the nylon inserted ones, this is to prevent the nuts from loosening up due to use and vibrations later one.
The fitment is tight, but they will go on, you might not be able to use your sockets to fully tighten them down, I had to use my pliers at the end.
http://farm2.static.flickr.com/1005/...992f724d5c.jpghttp://farm5.static.flickr.com/4133/...c6556d6c7c.jpghttp://farm5.static.flickr.com/4084/...117d639f80.jpg
15. This si the tricky part... You have to pull some tension in the cord when clamping on the other side... this will allow you to clamp the cord about 1.5 inches out from the hole, giving you some room to work. When you let the tension out of the cord, it will spring back and suck the clamp in the space...
http://farm2.static.flickr.com/1014/...821c9ba28f.jpghttp://farm5.static.flickr.com/4149/...94e3a9f0f2.jpg
16. Next I laid out some paper towels and sprayed one side of the liners. Let dry for about 15 seconds, then place on the panel.
http://farm5.static.flickr.com/4084/...54c42995b3.jpg
17. DONE!!
http://farm5.static.flickr.com/4060/...a2b8707e_b.jpg
18. Follow the install instructions Daystar provided and here is the result:
Before:
http://farm5.static.flickr.com/4113/...247a865b_b.jpg
After:
http://farm5.static.flickr.com/4126/...6acb83f2_b.jpg
MacK 11-24-2010 03:52 PM
I'm going to have to do this! My Daystar Dash panel looks like CRAP it's so old. Did they fix the bend at the bottom of it? Looks like it's not there anymore.
rirrgang 11-24-2010 07:38 PM
I like it but I think I might of just tied knots in the bungee instead of all the hardware.
herculz 11-24-2010 11:08 PM
does this sit on top of that existing center piece or do you have to remove it and insert the new one?
MacK 11-24-2010 11:12 PM
I was thinking the same thing, but I think he did that because it would be somewhat hard to get the knot in the right spot. I'm going to run wires through mine so I can hook my MP3 or phone to it =)
cj-ing-rj 11-25-2010 07:02 AM
Good call on the bungee. Do you have the compass option in your JK? If so did you still attached the module to the bottom side of the Daystar dash or did you need to relocate that???
Mol 11-26-2010 09:04 AM
Maybe I'm an idiot....but what do you hold with the bungee?
Great finish work :thumbsup:
echo1 11-26-2010 09:10 AM
A phone comes to mind. Something like the iPhone propped up letting you see a map or what have you.
Butterbuddha 11-29-2010 11:58 PM
The knots will hold just fine, ask any kayaker :)
1222 11-30-2010 01:57 AM
I think you did an excellent job. Look fantastic. :thumbsup:
:cheers2:
RAZORBILL 11-30-2010 03:58 AM
Great work!! I did the same thing minus the grommets. The grommets make it cleaner looking, I might have to grab some. I did just tie a couple knots in the bungee, works fine. I also added a couple led lights to get a bit of light up front.
http://i208.photobucket.com/albums/b...jeep/003-1.jpg
The time now is 07:16 PM.
