Daystar 3/4 inch lift - JeepForum.com
post #1 of 7 Old 09-01-2013, 08:04 PM Thread Starter
jeepjeep123
I've had the itch for a lift for a while and just simply don't have the $$$ for a large lift nor do I plan to run larger than 32" tires. I decided to get the front and back 3/4 inch coil spring spacers to give my jeep a little bit more sporty look without having to make any other purchases. Is this install doable by myself without prior experience? I have very basic know how but am willing to learn if I can work my way through without causing too much damage. Thanks
jeepjeep123 is offline
post #2 of 7 Old 09-01-2013, 08:08 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
So long as you can jack up the axle/wheel and remove the srping and add the spacer to the spring, it is doable. Do a quick search for this and you will find more info. You have to disconnect the shocks, sway bar links and control arms to drop the spring out. If not, get a spring compressor to take them out.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 7 Old 09-01-2013, 08:25 PM Thread Starter
jeepjeep123
Thanks. Directions are very vague that came with the kit. I'm assuming it will take a while?
post #4 of 7 Old 09-07-2013, 07:08 PM Thread Starter
jeepjeep123
Got it done today. Took all day for sure. It's a noticeable but mild for sure. I wouldn't do more without bigger tires.
post #5 of 7 Old 09-07-2013, 08:46 PM
SubAtomicGenius
2011 JK Wrangler
"Honey, I just got three-quarters of an inch extra!!!"
->silence<-
Hehe, just kidding. I know what you mean, I installed the high-rise fender flares on a 3-inch lift and now my 35's look puny.
Lift for your tires - don't lifting for the sake of lifting.
Pics would be nice!
SubAtomicGenius is offline
post #6 of 7 Old 09-08-2013, 05:27 PM
chunz82
I would love to see a pic of that as 3/4 is as high as I want to go.
chunz82 is offline
post #7 of 7 Old 09-09-2013, 01:50 PM Thread Starter
jeepjeep123
I'll snap one today and will post.
