Quantcast Dashboard Rattle - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Dashboard Rattle
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 05-16-2008, 07:32 AM   #1
silverJK2007
Dashboard Rattle
I have a rattle in my dashboard, appears to be coming from the drivers side between the center console (radio and temp. controls) and the steering wheel. Anyone else experiencing this? Any solutions?
Thanks
silverJK2007 is offline   Reply With Quote
Old 05-16-2008, 07:39 AM   #2
Sahara GT
2011 JK Wrangler
I had a similar noise a few months ago and it turns out the rattle wqas caused by a loose rear tightening screw on the freedom roof panel.Once I snugged it up --voila the noise was gone.Noise and rattles travel and can appear to be coming from a place like the dashboard but in fact are coming from another location as was the case with the rattle I had.
hope this helps
Sahara GT is offline   Reply With Quote
Old 05-16-2008, 10:03 AM   #3
jeepcouple
hope this helps
Had the same thing but........DO NOT OVER TIGHTEN THE KNOBS!
Also "thought" I heard a vibration from dash. My wife found it - the driver side sun visor.
Allan
jeepcouple is offline   Reply With Quote
Old 05-16-2008, 11:34 AM   #4
ten27oh4
Allan
It took me a while to figure that one out as well.
ten27oh4 is offline   Reply With Quote
Old 07-26-2008, 10:41 PM   #5
IsleSeat
hope this helps
Can you deliberate on this a bit further? Which knob/screw did you tighten or loosen to eliminate the rattle?
IsleSeat is offline   Reply With Quote
Old 07-27-2008, 09:00 AM   #6
possumface
i used silicone spray on the rubber seals on the freedom tops now mine kinda creaks i get alot of plastic noises from dash & tops , temps seem to change the tunes i guess its a jeep thing
possumface is offline   Reply With Quote
Old 08-01-2008, 06:40 PM   #7
2007UnlimitedNJ
I had a similar sound and found it to be in the hood of my Jeep. The vent on the outside needed to be pushed into place... it was never pushed hard enough when manufactured to "clip in". I also put nuts on the back of the tie down bars on the hood. They just rattle and pull out... no more rattle (knock on wood).
2007UnlimitedNJ is offline   Reply With Quote
Old 09-28-2011, 04:29 PM   #8
jenn7522
2010 JK Wrangler
HELP with Dashboard Noise
Hi, I'm new to the forum and need some help. I have a noise in my dashboard that is driving me nuts. It's random when it occurs. Mostly over smaller bumps but I hear it on occassion when i make a sharp turn. It's almost like a clunking noise - it's not a vibration, it's not a squeak. I hear it predominently on the driver side, but it does occur on the passenger side as well. It sounds like it's coming from inside the dash, closer to the door NOT the middle.
I'm at my wits end and have no clue what it is. I had my mechanic check all the suspension etc, to make sure it wasn't something underneath. He even said it sounds like it's in the dash. I took the side panel off and couldn't see anything. Nothing seems loose when looking up under the steering wheel.
I've had it back to the dealer 3 times. They made it worse the first time and basically don't want to tear the dash apart again, so they blame it on the lift and say they can't help me.
Any ideas!!!!!!! And yes, I know jeeps have rattles, but this is freaking annoying, I can deal with the door pillars, etc.
jenn7522 is offline   Reply With Quote
Glock Forum
