Dash Mounted Power Outlets - JeepForum.com
post #1 of 13 Old 03-16-2007, 09:08 PM Thread Starter
ericg
From the Owners Manual, it appears both of theses are only on when the Jeep is on. On some other vehicles it is possible to move a fuse in the fuse box to change how the power outlet functions. Any way to make one always on?
ericg is offline
post #2 of 13 Old 03-16-2007, 09:30 PM
jeepers3
The way I read it, one is always on, the other is on only when the Jeep is. I did some experimentation and found this to be true. But I don't remember which is which. I think the one on the right is the always on one, but I can't swear to it.
jeepers3 is offline
post #3 of 13 Old 03-16-2007, 09:36 PM
luckyjeeper
luckyjeeper's Avatar
Yes, that's correct. the one on the right is always on. the drivers side shuts off with the ignition.
patrick
2007 JK X 2dr. 6spd.
Steel Blue Hardtop
Virescit Vulnere Virtus
luckyjeeper is offline
post #4 of 13 Old 03-17-2007, 05:54 AM
dodco1
dodco1's Avatar
On mine the left one is on with the ignition. The right is suppose to be on all the time. Except non of my power adapters will work in it. The dealer said he would look into it next time I brought it in.
DoDco Dan
2007 Wrangler 4dr
and other toys
dodco1 is offline
post #5 of 13 Old 03-17-2007, 07:03 AM
JK_Jeep
JK_Jeep's Avatar
the right side is also rated at 20 amps, good for larger electronic items
IT'S A JEEP THING!
Originally Posted by sierraexplorer
Thanks, if it is that good than I'm sure that they can't sell it in California. Everything else is illegal in this state except the illegalsl
JK_Jeep is offline
post #6 of 13 Old 03-17-2007, 07:25 AM
FLSeaMonkey
The left one is perfect for a radar detector. On/off with the ignition. Why on earth do we not have one in the back??????
'07 Wrangler Unlimited Sahara Rescue Green
'94 Land Rover Defender 90
'64 Porsche 356C
FLSeaMonkey is offline
post #7 of 13 Old 03-17-2007, 07:43 AM Thread Starter
ericg
Thanks guys!
ericg is offline
post #8 of 13 Old 01-27-2013, 09:03 AM
jeepster1947
2012 KK Liberty
power outlet fuse position
This forum is great. Just changed fuse position to keep outlet powered all the time...just the way I want it. Thanks guys!
jeepster1947 is offline
post #9 of 13 Old 01-27-2013, 11:59 AM
ronjenx
ronjenx's Avatar
You did that for the outlet in the back?
ronjenx is online now
post #10 of 13 Old 01-28-2013, 04:55 AM
Green08
Close to 6 year old thread..this has got to be a record....
Green08 is offline
post #11 of 13 Old 01-28-2013, 05:12 AM
Spaf
2011 JK Wrangler
Maybe a record but certainly a proof that the search function works.
Yellow Jeep Club #54
"Que scais-je?"
Spaf is offline
post #12 of 13 Old 01-28-2013, 10:01 AM
rirrgang
My 07: Right is always hot, Left is only on when key is in acc or run.
Did you actually try them?
-Rick
07 Sahara Unlimited
rirrgang is offline
post #13 of 13 Old 01-28-2013, 10:24 AM
ronjenx
ronjenx's Avatar
The left front power outlet (fuse M6) is hot when the key is in the ACC and RUN positions.
The right front power outlet (fuse M36) is hot all the time.
The only outlet that is selectable ACC or BATT is the optional outlet in the back, (fuse M7).
Power outlets in car. tylerd JK Wrangler Technical Forum 18 02-07-2010 02:11 PM
fuse location for power outlets redsoxski TJ Wrangler Technical Forum 1 07-13-2008 08:41 PM
No power to power outlets Bean TJ Wrangler Technical Forum 1 12-29-2007 01:03 PM
Stupid question about my 05 tj and the dual power outlets Killedbybob TJ Wrangler Technical Forum 15 12-29-2005 10:24 PM
power outlets Jeepin'TJ TJ Wrangler Technical Forum 3 06-03-2003 07:31 PM
