Dana 35 vs. Dana 44 - JeepForum.com
post #1 of 20 Old 12-11-2006, 09:48 PM Thread Starter
bperrypa
Dana 35 vs. Dana 44
A question for the saavy please. What would be the difference (capability) of the Dana 35 vs. the Dana 44 axle. I've got a Sahara ordered, not built yet (BX) and am wondering if its worthwhile to make amendment to the build spec to include a tow package. Is more, better ?? I want to offroad, not necessarily rock crawl, and am not planning to tow.. Is the upgrade significant ?
Thanks for info/help
bperrypa is offline
post #2 of 20 Old 12-11-2006, 10:00 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
The D44 is probably THE most important option to get from the factory if you plan to wheel it at all. Unless you plan on swapping out an even tougher axle down the road, the D35 is not the way to go.
It remains to be seen how the new and improved D35 is, but on the TJ it was weak. With a D35 you would generally be limited to 31s or smaller, and no locker. Sure there are lots of people running a locker and 33s, but it is just a ticking time bomb IMO.
I'll be Savvy someday!
neZZr is offline
post #3 of 20 Old 12-11-2006, 10:30 PM
SecondTJ
SecondTJ's Avatar
its worth it to get the Dana 44 from the factory, if you want to get it down the road, its going to cost you a lot more money that it would have initially.
the 35 was the weak link in TJs when going bigger
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #4 of 20 Old 12-11-2006, 11:10 PM
doojer
I never plan on towing much, but I knew if I was planning on wheeling my Sahara (which I was) I'd want the Dana 44.
Is the difference between the D30 fronts in our Saharas and the D44 front in the Rubi just as significant? I kind of assumed that since I wouldn't be lifting my JK, I wouldn't really need the D44... at what point does the stronger front axle become a major factor?
- Jeep Green, Auto, 4:10, D30 front/D44 rear, RockCrusher Diff Covers
doojer is offline
post #5 of 20 Old 12-11-2006, 11:26 PM
neZZr
neZZr's Avatar
On a TJ, the only real difference is the ring/pinion. The shafts and everything else are the same. I believe this is true for the JK as well, but I don't know for sure. The front axle should be good to 35" tires for either the D30 or D44. Upgrading to chromoly shafts will give a little insurance.
On the JK the axles have been improved over the TJ axles, so I'd say that the D30 should be just fine unless you plan to go 37" or larger. Any bigger and you wouldn't want any of the stock axles IMO. Few people have really tested them out with large tires yet to know for sure.
neZZr is offline
post #6 of 20 Old 12-12-2006, 12:24 AM
Karamba
At the moment you engage a front locker.
With Sahara you get a fairly capable electronic limited slip, and in your shoes I would skip the mechanical limited slip in the rear and upgrade later to a selectable locker in the 44 if you find that you need it. Apparently many folks are finding out that the electronic stuff goes quite far, with a rear selecable you should be fine for a lot of stuff.
Karamba is offline
post #7 of 20 Old 12-12-2006, 05:01 AM
JoiseyJeff
JoiseyJeff's Avatar
I thought all Sahara's had the D44 and that the tow package just gave you 4.10 gears in the rear? Maybe just the Unlimited's?
89YJ Sahara, Best Jeep I ever had to sell
90MJ 2nd Best Jeep I ever had to sell
93ZJ Might sell soon.
07JK Sahara Rescue Green
JoiseyJeff is offline
post #8 of 20 Old 12-12-2006, 10:18 AM
doojer
Thanks. I actually did skip the LSD rear so that I could add a true locker down the line. I was hoping to lock the front eventually, too... in another thread I was told that my D30 should be able to handle a locker alright. What is the danger of running a locker on my D30? Would upgrading my shafts eliminate that danger?
I appreciate the info!
doojer is offline
post #9 of 20 Old 12-12-2006, 12:16 PM
lupinsea
lupinsea's Avatar
Does anybody actually know exactly how and what Jeep did to beef up the new D35 and D44 axles? I've heard both are now stronger than their TJ counter parts but I've not heard anything beyond that. For instance, does anybody know:
Torque strenth ratings for the old and new axles?
Axle shaft diameter?
The specific "upgarded" areas of the new axles?
Not trying to be a smart ***, just trying to figure out what it was that was upgarded on the new axles.
- Jay
lupinsea is offline
post #10 of 20 Old 12-12-2006, 12:18 PM
Karamba
It will be easier to break, but obviously your mileage may vary. I would not bother with a front locker unless your trails are not passable with just a rear one and the electronic limited slip... And that does cover quite a lot of trails.
Karamba is offline
post #11 of 20 Old 12-12-2006, 01:28 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
It was either (or both) Peterson's 4 Wheel and Off-Road and/or JP Magazine that gave specifics on the axles a few months ago.
Here's what I remember (sorry for the lack of numerical data):
  • Front axles are now high pinion, both the D30 and the D44
  • Rubi D44 axles are 32 spline - I'm not sure if non-Rubi models get the 32 spline rear or not.
  • D44 has a larger ring gear (maybe the D35 too, but I'm not positive)
I'll try to locate the article or some better data, because I can see this is not really helping much.
Wheelin98TJ is offline
post #12 of 20 Old 12-12-2006, 04:47 PM
neZZr
neZZr's Avatar
Larger ring gear??? How can they change that and still call it a 44?
neZZr is offline
post #13 of 20 Old 12-12-2006, 08:36 PM
XJ2Timer
4 Wheel & Off Road April 2006.
Dana 35 is now a non C clip captive bearing style with stronger shafts, strengthened tubes and bigger pinion and pinion bearings. Front Dana 30 has bigger pinion and pinion bearings and bigger axle joints and stub shafts and also features a captive unit bearing so the stub shaft can be removed if needed. Rubicon's front Dana 44 is now a reverse pinion design, has stronger tubes, a bigger pinion shaft and bearings, bigger 1350 series U joints, better axles and a captive unit bearing. The rear Dana 44 features bigger pinion bearings and pinion, a larger ring gear by 10mm, bigger tubes and 32 spline 1.4 inch axleshafts.
1st one- 1989 Cherokee Laredo. 12 great years
2nd one- 2001 Cherokee Limited. Got it before they were gone.
XJ2Timer is offline
post #14 of 20 Old 12-12-2006, 11:54 PM Thread Starter
bperrypa
Talk about good/bad timing.. I call today to get the tow package added (for the axle) and I'm a day too late.. I'm now in 'D' mode. Ready to build and no changes.. it was "Yippee!....no, aw damn..." LOL. Build first week Jan.. Delivery late January.
bperrypa is offline
post #15 of 20 Old 12-13-2006, 11:02 AM
Wheelin98TJ
JEEP FREAK
I agree - Dana should have renamed the axles since there were so many changes made.
I can only imagine the complications this will cause for driveline shops/gear vendors. Its crazy how many D44 variations there are.
my dana 35 snaped again can i swap the parts out of a 1990 dana 35 from a cherokee bulickmcj TJ Wrangler Technical Forum 7 04-02-2009 12:42 PM
upgrading from a dana 30 to a dana 44 front axle cprats TJ Wrangler Technical Forum 12 12-10-2007 09:20 AM
Build Thread for my Dana 44 and Dana 60 axles... Pics & Questions Inside Big-n-Broke-YJ YJ Wrangler Technical Forum 9 07-11-2006 09:37 AM
QUESTION: front axle(DANA 30) why does mine look like a DANA 35 713JeepTJ TJ Wrangler Technical Forum 5 03-06-2005 09:20 PM
4:10, 33's, Dana M35 Rear, Dana 30 Front Jeeper-4-Life TJ Wrangler Technical Forum 1 02-10-2004 04:48 PM
