Damp carpet without rain, help! - JeepForum.com
post #1 of 8 Old 04-13-2013, 04:03 PM Thread Starter
CMcKillen
2009 JK Wrangler
I just bought my first Jeep in mid December 2012; I noticed that the carpeting was damp on the driver and passenger sides of the vehicle but attributed to the snow. I gave it time and all the snow has melted and my area has had a dry spell (about a week and a half). I checked today and my carpets are still wet (border-line soaked). What should I look for that could be causing this/ a solution. I'm just paranoid that the constant dampness is going to rust-out my bottom prematurely.
Specs:
Wrangler 2009 Sport X, 6-speed, freedom-top
CMcKillen is offline
post #2 of 8 Old 04-13-2013, 04:17 PM
Filthy-Beast
The mildew would be a bigger concern. Find the leak then work on fixing it. Have someone else spray with a hose while your inside looking and feeling for the leak. If you don't have access to a hose go to a manual car wash. Probably a damaged seal on the hard top panels.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #3 of 8 Old 04-13-2013, 05:23 PM
rha600
I was thinking AC condenser but seeing as you are in NY at this time of the year, I guess no?
rha600 is offline
post #4 of 8 Old 04-13-2013, 05:44 PM
Filthy-Beast
Possible if he's running the AC compressor with the heater to defrost the windows from all the moisture.
For Sale:
post #5 of 8 Old 04-13-2013, 05:59 PM
jabsther
2010 JK Wrangler
Mine are damp also. Thought they got wet and the rubber floormats keep it soaked. Lifted the carpet and the white pad holds the moisture the most. Going to let it stay up for a week and check to see if it drys up some.
Did see it rain a few weeks ago when I had the hardtop on, and see it dripping from the forward top corner of the passenger door. Rain was blowing from that direction.
Thinking about rino-lining it, like some of the others have done.
jabsther is offline
post #6 of 8 Old 04-13-2013, 06:10 PM
Wavedatya
2010 JK Wrangler
Jeep are water tight like the 50 year old aluminum boat.
Mine leaks. I've given up. I put truck bed liner and ripped out carpet. Look around the corners near the front mostly comes in around the very top left of door. On passenger right top corner. Also look around B pillar if soft top. Rear tailgate soft top or hard top. Also with soft top you'll get water come through the Velcro at top of side window. Hard top where the front panels meet the rear along the seam.
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #7 of 8 Old 04-14-2013, 06:38 AM
Remmy18
I keep a spray bottle of mold/mildew preventer handy and spray the carpet and seats down often. I also run with all drain plugs removed and doorless often so the moisture doesn't bother me. No mold or mildew.
Remmy18 is offline
post #8 of 8 Old 04-14-2013, 07:57 AM
GPV
................Depends...........................
Sorry that isn't very helpful. You could try running a dehumidifier inside or leaving some dessicant inside to dry it out. Check the drain plugs and make sure they are installed.
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
carpet , help needed , wet driver's side floor
