D44 Rubi Gears - JeepForum.com
post #1 of 11 Old 02-24-2009, 09:24 PM Thread Starter
gmd
2009 JK Wrangler
D44 Rubi Gears
how hard would it be to swop a d44 gear or the hole axle and the front to my x ??? how much would i be looking at
----says it all----> meus veneratio est verum
Originally Posted by jsbarks View Post
pics or your making this all up
n i g h t c r e w #077
BLACK JEEP MEMBER 327
(from:friskeljr)The real test comes when all strength has fled and man must produce victory on will alone...
Courage is the mastery of fear...
rs.com/commu...mber.php?u=750
gmd is offline
post #2 of 11 Old 02-24-2009, 09:33 PM
WVUJeeper
The gears out of a D44 will not fit your D30. I would imagine that he whole axle would bolt right up if you got it from another JK or from Mopar.
- Fletcher: Oil Field Trash Extraordinaire
Originally Posted by VetteDriver View Post
BTW, what's with the "if you haven't driven one shut up" nonsense? How can we have a good internet fight if experience and knowledge are going to be a requirement?
'08 Rescue Green Unlimited X - Hard Top, 3.73 gears, Limited Slip, Infinity 7 speaker system, KC Slimlite Long Range, Cobra CB, Rough Country 2.5" BB, 35" BFG KM2's on ProComp 7089's. Fenderless and proud!
My build thread:
RESCUE GREEN JEEP CLUB MEMBER #25
COLORADO JEEP CLUB MEMBER # 1001
WVUJeeper is offline
post #3 of 11 Old 02-24-2009, 10:48 PM
4x4jkx
WVUJeeper is right the gears won't match up. A D44 will bolt up right to the X no problem. You just have to get the D44. If you do it yourself you can get a D44 of another JK'er for probably around 2 grand. To have someone else install I have no idea.
4x4jkx is offline
post #4 of 11 Old 02-25-2009, 08:41 AM
N2rock
N2rock's Avatar
Quadratec (and Jeep Dealers) sell a front D44 for $3000, plus another $100 for the wiring harness & switch pod, plus freight shipping charges. So for a brand new D44 you would be looking at around $3500 not including install. Used ones would be cheaper, but hard to find.
The install would not be terribly difficult since it would be a direct bolt-on but would take 3-4 hours labor.
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #5 of 11 Old 02-25-2009, 09:14 AM Thread Starter
gmd
2009 JK Wrangler
ok here is what i want to know . if i get a rubi axle it will come with electronic lockers right ??? well if i do a front swop only i will have to get lockers for the rear???
gmd is offline
post #6 of 11 Old 02-25-2009, 09:17 AM
2005X
and you would need to regear the rear to match the front
2005X is offline
post #7 of 11 Old 02-25-2009, 09:20 AM
N2rock
N2rock's Avatar
yes it will come with the locker. You don't have to wire the lockers together. Hell you don't even have to get the switch pod, and can just run the single locker with a simple toggle switch.
and as 2005x mentioned- you'll need to have matching gears. The Rubi gears are 4.10.
I'm one of the lucky ones that has an X with 4.10's ('07 auto). So for me it would be a simple swap. But if you don't have an '07 auto or '07 tow package, you'll need to re-gear
N2rock is offline
post #8 of 11 Old 02-25-2009, 09:30 AM Thread Starter
gmd
2009 JK Wrangler
i looked up gears and there not that coustly where is the fee to re gear ?? why dont people do it more often if its onl y 300 bucks
gmd is offline
post #9 of 11 Old 02-25-2009, 09:39 AM
N2rock
N2rock's Avatar
It costs around $1000 for labor to regear. Re-gearing requires special tools/instruments. So you can't just do it in your garage. You have to pay someone.
N2rock is offline
post #10 of 11 Old 02-25-2009, 10:30 AM
igofshn
Locked @ both ends
igofshn's Avatar
You can pay anywhere from $150-500 per axle to regear it and it depends on who does it. Chain stores like 4wheel parts tend to charge the most.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #11 of 11 Old 02-25-2009, 11:14 AM Thread Starter
gmd
2009 JK Wrangler
wow that sucks
gmd is offline
Just bought a TJ Rubi. Which gears should I run? omgwtfbbqcopter TJ Wrangler Technical Forum 8 12-19-2009 01:29 PM
5.38 gears for rubi 44 ? Anyone make these newbs TJ Wrangler Technical Forum 8 06-26-2008 10:27 AM
06 rubi gears daver032 TJ Wrangler Technical Forum 2 06-26-2007 03:42 PM
05 Rubi gears on an 06 non-Rubi? surfcaster TJ Wrangler Technical Forum 7 02-13-2007 05:29 PM
4.88 gears with 33s on a Rubi toastervet TJ Wrangler Technical Forum 20 09-23-2006 06:37 PM
