Cutting front bumper...? - JeepForum.com
post #1 of 22 Old 03-21-2011, 12:54 AM Thread Starter
Whitefang
What did you guys use to cut your front bumper? is it pure plastic or is there steel underneath? just curious what i should use since im cutting the ends off my bumper in the next couple of weeks
Whitefang is offline
post #2 of 22 Old 03-21-2011, 12:59 AM
No_Return
There is metal underneath that extends out 7"- 10"... You can buy a set of caps for it so you don't have razor sharp metal exposed.
http://www.roughcountry.com/jeep_xtras_1047.html
One does not establish a dictatorship in order to safeguard a revolution; one makes a revolution in order to establish a dictatorship. - Orwell
No_Return is offline
post #3 of 22 Old 03-21-2011, 02:15 AM
asknight
Sawzall of course
asknight is offline
post #4 of 22 Old 03-21-2011, 02:37 AM
kjamesm
2010 JK Wrangler
sawzall cut through it like butter, took maybe 8 minutes.
2010 JK
2.5 RC BB
1.5" spacers
315-75-16 Duratracs
kjamesm is offline
post #5 of 22 Old 03-21-2011, 10:18 AM
prodh
2010 JK Wrangler
Ginsu.
I wish my Jeep was as dirty as my wife.
2010 Surf Blue Unlimited Rubicon, 4" Teraflex full flex lift, 35" tires and 5.13 gears.
prodh is offline
post #6 of 22 Old 03-21-2011, 10:25 AM
MrOrange
2009 JK Wrangler
Here's a write-up from another site.
http://project-jk.com/jeep-jk-write-...umper-write-up
'09 X Unlimited, 4WD, auto, half-doors, soft-top
RC 2.5" Series II BB, JKS Quick Discos, JKS adjustable front track bar
15x8 Unique 297 (Soft 8), Goodyear MTR/Kevlar 35x12.50R15
5.13 gears, ARB front locker, Currie front shafts
Bushwacker flat flares, Rubicon rails with steps added
MrOrange is offline
post #7 of 22 Old 03-21-2011, 10:33 AM
MrJeepJoy
2009 JK Wrangler
I used a cutting wheel on an angle grinder because I didn't have a metal blade for my sawzall.
I have good friends. They always ask, "When we going Jeeping?"
MrJeepJoy is offline
post #8 of 22 Old 03-21-2011, 12:49 PM
Oris
2015 JK Wrangler
Here are end caps by Vertically Driven Products (VDP). The design looks similar to the stock bumper ends and a little less boxy than the ones from Rough Country.
http://www.quadratec.com/vendor/Vert...acks/index.htm
Oris is offline
post #9 of 22 Old 03-21-2011, 01:48 PM
PlatinumOre
My Rough Country Installation I did a while back.
http://www.jeepforum.com/forum/f96/r...-caps-1016789/
PlatinumOre is offline
post #10 of 22 Old 03-21-2011, 01:50 PM
Bionicrooster
2010 JK Wrangler
I used the ones from Oris and it was an easy install. Saw Zaw with a metal blade worked fine, but buy 2 just in case, I broke one and had to run back out to Home Depot.
" We do not inherit our wildlife from our fathers, we only borrow it from our children."
Bionicrooster is offline
post #11 of 22 Old 03-21-2011, 02:36 PM
JTPhoto
JTPhoto's Avatar
I just cut mine off even and made an end plate. Its a stubby now, rather then a mid width. I used a 4" mini grinder and cut off wheel very carefully.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 37x12.50x17 Pitbull Rockers on ProComp 7069 Alloys, AEV Prem Bumper ETC..
JTPhoto is offline
post #12 of 22 Old 03-21-2011, 03:54 PM
wscbikes
Ride Hard -- Ride Long
Did you make the end-plate out of metal or plastic; and, more importantly do you have any pictures of it, as I may be interested in giving this a shot?
Regards,
Shawn
wscbikes is offline
post #13 of 22 Old 03-21-2011, 05:22 PM
DANJEEPO8
ripped the plastic off, cut crush cans off and the angle pieces off the metal bumper with my grinder, then, just bought a piece of steel to fit over top. looks awesome. no sharp edges. little primer and paint. whoolah!
$20 for steel plate on top
:cheers :
DANJEEP08
DANJEEPO8 is offline
post #14 of 22 Old 03-21-2011, 06:27 PM
Vin
:cheers :
Now you have me thinking...always a dangerous thing. I need to find a winch plate and see how much of the to it'll cover...
Vin is offline
post #15 of 22 Old 03-21-2011, 07:19 PM
JTPhoto
JTPhoto's Avatar
Yes I just formed a piece of sheet metal to fit just inside the plastic. I pre-drilled the sheet metal then painted with bedliner. Fasted with black 3/16" pop rivets.
^^Jeff^^
JTPhoto is offline
Cutting stock bumper mscottz TJ Wrangler Technical Forum 10 08-08-2010 10:16 AM
Cutting front bumper SoCalJK JK Wrangler Technical Forum 2 11-09-2009 11:23 AM
Anti Rock and bumper cutting chappy84 TJ Wrangler Technical Forum 2 01-31-2008 06:36 PM
Cutting Front & Rear Bumper jbpdog TJ Wrangler Technical Forum 7 04-17-2006 05:25 PM
Cutting Stock Front Bumper 1rockhead YJ Wrangler Technical Forum 13 12-21-2005 10:12 AM
