Cut exhaust crossover or deal with it? - JeepForum.com
post #1 of 8 Old 10-31-2013, 11:08 AM Thread Starter
bobwilson2020
I need advice from people smarter than me...
I'm in the process of replacing throwout bearing, clutch, PP, etc. and in a how-to the poster wondered after the fact about cutting the exhaust crossover section under the transmission, then re-attaching with a couple of exhaust clamps. This got me curious but I can't find anyone else who's tried this.
That makes me think it's not the best idea. If it was, there would be more stuff about it.
Here's what I'm thinking:
PROS
Accessing/removing the trans would be much easier
Not having to remove the exhaust would be much easier
Changing trans fluid would be somewhat easier (I made a tool for this, so that's hot a huge PRO)
It's below all O2 sensors so I doubt they would be affected.
CONS
Increased chance of exhaust leak
Two cuts could add flex (Would pass. side need a hangar?)
I'm sure I'm missing some pros and cons, or I may be way off in my thinking, so feel free to add your thoughts. All thoughts and help is very appreciated!
bobwilson2020 is offline
post #2 of 8 Old 10-31-2013, 11:11 AM Thread Starter
bobwilson2020
If anyone needs to know vehicle stuff:
2007 Wrangler X
Manual trans (or I wouldn't be doing this)
2-door
I thought that was in my profile to the left but I'm not seeing it. First post noob issues.
post #3 of 8 Old 10-31-2013, 01:52 PM
PanthersFan
I did it. Only one cut. Joined it with a coupler and clamps. No problem, and made dropping the transmission much, much easier.
THE Conventions of a number of the States, having at the time of their adopting the Constitution, expressed a desire, in order to prevent misconstruction or abuse of its powers, that further declaratory and restrictive clauses should be added: And as extending the ground of public confidence in the Government, will best ensure the beneficent ends of its institution.
PanthersFan is offline
post #4 of 8 Old 10-31-2013, 02:33 PM Thread Starter
bobwilson2020
Thanks for the info. Where was your one cut?
post #5 of 8 Old 10-31-2013, 02:36 PM
PanthersFan
Driver's side just past the transmission drop point.
post #6 of 8 Old 10-31-2013, 02:42 PM Thread Starter
bobwilson2020
With that cut location, removing the passenger side seems to be the harder of the two sides. But easier than both together I'm sure.
post #7 of 8 Old 10-31-2013, 02:55 PM
PanthersFan
The nuts are captured on the top side of the manifold. A long extension or two makes the passenger side relatively easy to remove.
post #8 of 8 Old 10-31-2013, 03:01 PM Thread Starter
bobwilson2020
I grabbed an extra extension last night for this exact thing.
diy jeep mods , exhaust , jk
