Customer Preferred Package 24R -?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Customer Preferred Package 24R -??
Poly Door Hinge BushingsStainless Steel Door Hinge PinsNew Knuckles Skid Plate at JeepHut
Unread 01-30-2012, 12:39 PM   #1
Meir10
Does anyone know what "Customer Preferred Package 24R" is?
Oreder Unlimited Auto Rubi w\ Hard top, 4.1 axle ratio, and see it in the
vehicle status.
Meir10 is offline   Reply With Quote
Unread 01-30-2012, 01:25 PM   #2
jwmbishop
2011 JK Wrangler
24R CUSTOMER PREFERRED ORDER SELECTION PKG -inc: 3.6L V6 engine, 5-speed auto trans *Upon selection of this pkg, the cost of powertrain components will be added*
J Wm Bishop EA, ASADE
The Jeep wave - it means nothing. Now I look for the RearView wave. Anyone can cause a guy to readjust his rear view at night. But in the daytime when you roll up behind someone and they adjust their mirror to frame your Jeep straighter - THAT'S a compliment!
jwmbishop is offline   Reply With Quote
Unread 01-30-2012, 01:28 PM   #3
Roll
vehicle status.
Jeep site says:
Roll
2012 Wrangler Unlimited Sahara; Deep Cherry Red, to match the Motorcoach.
2010 Wrangler Unlimited Sport X; Mountain Edition; Rescue Green. Current Toad.
Will move the base plate and wiring from the 2010 to the 2012 this summer.
Roll is offline   Reply With Quote
Unread 01-30-2012, 01:30 PM   #4
FlyinJeep
vehicle status.
"24R CUSTOMER PREFERRED ORDER SELECTION PKG (24R) -inc: 3.6L V6 engine, 5-speed auto trans w/3.73 axle ratio"
That's what I found online anyway so maybe someone else can verify. Seems weird that a "preferred package" only includes that.
FlyinJeep is offline   Reply With Quote
Unread 01-30-2012, 01:32 PM   #5
FlyinJeep
Dammit, Roll and Bishop beat me to the post. I guess 3 answers are better than none!
Also it seems to auto-select the 3.73 gear ratio if you chose that package. I thought all Rubis came with the 4.10 gears?
Unread 01-30-2012, 01:38 PM   #6
Meir10
Originally Posted by Roll View Post
Jeep site says:
I don't find it in Jeep site, can you send me the link?
Unread 01-30-2012, 01:38 PM   #7
jwmbishop
2011 JK Wrangler
24 is the starting point for the powertrain configuration - ie the one I just made an offer on is 24B - 3.6, 5spd, choice of gears - on this one another code (dme) appends to get me 3.73s... 24R (3.6, 5spd auto) no appending needed on a Rubicon24R as Rubicon only comes with 4.10 anyway...
A standard trans would use the 23 series packages...
Unread 01-30-2012, 01:57 PM   #8
Meir10
Rubi w\ auto trans comes with 3.73 as standrt, 4.1 is an option.
I hope the 24R doesn't mean 3.73.
Where can I find details about this code?
Unread 01-30-2012, 02:34 PM   #9
Meir10
Can Rubicon be w/ Limited slip differential???
I saw in some Dealer sites Rubicons with Limited slip differential, is it true?
Can a Rubi comes w\out Differetial lockers?
Unread 01-30-2012, 02:39 PM   #10
jwmbishop
2011 JK Wrangler
Not sure about where to find ALL the details... usually takes a build sheet (the dealer can provide - but he would be bending the rules a bit...) or window sticker to tell exactly what you have.
In the Rubicon package 4.10 is standard for 24R (the Rubicon order overwrites the gear) - 3.73 becomes the option when appending with code (DME) - you probably won't find 3.73 in many dealer equipped\ordered vehicles...
Unread 01-30-2012, 02:41 PM   #11
Prot
Gold Member
Prot's Avatar
By definition a Rubicon has lockers.
Sounds like some overthinking is going on.
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, Goodyear Duratrac 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Front Rancho 9000 shocks, Rear Bilstein 5100 series shocks, 5.13 gears, Kenwood DNX9990HD, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650
Prot is offline   Reply With Quote
Unread 01-31-2012, 12:22 PM   #12
JeepCares
Wrangler Rubicon or Wrangler Unlimited Rubicon
23R - 6 speed manual transmission - the 4.1 rear axle ratio is standard
24R - 5 speed automatic transmission - the 3.73 rear axle ratio is standard (you have the option of the 4.1)
The Rubicon comes standard with Tru-LokŪ Elect Locking Front/Rear Differentials
These electronic-locking front and rear differentials balance speed between left and right wheels maintaining forward momentum for the ultimate in Wrangler traction. The instrument panel-mounted rocker switch can lock the rear, the front, or both axles.
Lee
Customer Care
Chrysler Group LLC
JeepCares is offline   Reply With Quote
Unread 01-31-2012, 12:28 PM   #13
Meir10
Thank you Lee
Unread 01-31-2012, 02:37 PM   #14
jwmbishop
2011 JK Wrangler
Intersting - dealer just confirmed if you order a Rubi - you are getting 4.1 unless you specify 3.73. Never new you had to specify standard... but then this IS Chrysler we are dealing with.
Unread 02-01-2012, 05:39 AM   #15
JeepCares
Interesting, indeed - I'm looking at the most recent code guide - dated 1/24/12.
I believe the change was due to the new engine/transmission that came out for the 2012 model.
Lee
Customer Care
Chrysler Group LLC
