Custom Jk Rear bumper - JeepForum.com
post #1 of 24 Old 03-14-2013, 03:08 PM Thread Starter
Dr.Dirty
I thought I had already posted this here....
A buddy of mine wanted me to make him a bumper so here is what I came up with.
We started off with some 2x4 to make the frame rail inserts.
Then cut and notched to fit the supports that will frame out the bumper.
We started putting our measurements into the computer to see how much we needed to cut and where our bends would be. Then worked up the bumper frame.
Then it was time to start adding the supports to the upper frame of the bumper, setting it up so we could get a feel for the level. Made sure I could open the rear gate.
Once satisfied with the top, it was time to measure and weld in the frame rail supports, then put those initial components together.
The best thing about that design while building was that we could now set it on the welding table either side up and it sat perfectly.
We marked the holes while in the frame rails, then drilled them out on the table and welded in the nut for the front bolt.
Used the same measurement for the lower bar, then angled it upward. A little more cutting and grinding and we had our bottom piece. We added two supports to the bottom to off-center the upper supports, as well as giving us a new place for the license plate.
Now it was time to place the main tire carrier support and set the spindle in place. The spindle is not only really heavy duty, but is supported by the corners of the two bumper frame bars, its own tube cut to size and welded to the bumper, and a plate cut for the spindle and welded to the spindle tube we made and the bumper itself.
Next came the hoop frame for the tire carrier. We wanted to utilize the bends in the support beam to create a recess where the Kolpin fuel packs would mount, so we angled the hoop slightly toward the Jeep and tacked it on.
To be continued....
Dr.Dirty is offline
post #2 of 24 Old 03-14-2013, 03:09 PM Thread Starter
Dr.Dirty
We brought the latch around to the side of the main support so it could reach around back and give the best grip to stay closed.
Added a tab for the CB antenna, welded a smaller tube to the tire mount plate and slid everything on to test fit.
Added some plate onto the top to cover things up nicely. We also put some sheet metal in the lower recesses...
Some final fitting shots before bolting it to the frame and putting everything on.
Dr.Dirty is offline
post #3 of 24 Old 03-14-2013, 06:54 PM
DAYJ
Pure awesomeness.... Great skills, I'd buy it!
New- 2013 Commando Green Rubicon
Old-2010 Flame Red Rubicon Unlimited
Utah Jeep Crew Member #47
Cheyenne Trail Junkie
ROADS!? Where we're going, we don't need roads... (Doc)
DAYJ is offline
post #4 of 24 Old 03-14-2013, 09:34 PM
1222
RIP John
1222's Avatar
Very nice, is that the first time you’ve used that design?
1222 is offline
post #5 of 24 Old 03-15-2013, 10:30 AM
zenman
I can just hear my brakes squeeling and that big tire getting bigger in my whindshield, lol!
New Jeep: 10th Anniversary Rubicon, Anvil with Red Leather seats
Old Jeep: 2012 JK Sahara Dozer
zenman is offline
post #6 of 24 Old 03-15-2013, 11:42 AM
awinski
looks sweet, i like the latch. ive been trying to find some similar with no luck!
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #7 of 24 Old 03-15-2013, 12:26 PM
Metalman
2014 JK Wrangler
Look no further
http://www.emsoffroad.com/store/inde...roducts_id=449
edit:
or
http://www.reidsupply.com/sku/TC-344-R/ (lockable)
Metalman is offline
post #8 of 24 Old 03-15-2013, 02:41 PM
awinski
thank you!
awinski is offline
post #9 of 24 Old 03-15-2013, 08:25 PM Thread Starter
Dr.Dirty
Yeah its was a build as we go the way he wanted it.
Originally Posted by Metalman View Post
Not a huge fan of that latch because it doesnt lock.
This is the latch I used
Dr.Dirty is offline
post #10 of 24 Old 03-19-2013, 11:29 AM
Metalman
2014 JK Wrangler
^^ Oh hell, my bad I didn't know that. That's a great looking bumper, excellent work!
Metalman is offline
post #11 of 24 Old 03-26-2013, 03:08 PM Thread Starter
Dr.Dirty
thank you sir!
Dr.Dirty is offline
post #12 of 24 Old 03-26-2013, 03:31 PM
awinski
thanks for the latch help. ill be hopefully using one with my rear stinger!
awinski is offline
post #13 of 24 Old 03-27-2013, 06:46 AM Thread Starter
Dr.Dirty
Reid sells a ton of different ones to in case you need something else
Dr.Dirty is offline
post #14 of 24 Old 03-27-2013, 08:28 PM
182329
2009 JK Wrangler
Excellent custom build. Well done!
Just curious, how much does it weigh?
182329 is offline
post #15 of 24 Old 03-28-2013, 11:01 AM
Kenny-g
Damn that's an awesome one off bumper/tire carrier. Very heavy duty and sturdy looking. I love it! Nice job. Makes me want to learn how to weld and get practicing, that's for damn sure lol
Project; LOST YETI
'13 Wrangler Sport "Lee-Roy2.0"
32" BFGoodrich Mud Terrain T/As | Rubi MOABs | OMIX-ADA Locking Lugs | Rough Country hybrid front bumper & 8K lb Smittybuilt winch coming soon!
Kenny-g is offline
