Custom Build: JK Electrical Panel - Page 2 - JeepForum.com
post #16 of 32 Old 08-03-2008, 01:24 PM Thread Starter
waterboarder
waterboarder's Avatar
Just because you priced out an expensive, sub-optimal solution, doesn't mean that DIY is not the way to go (:
waterboarder is offline
post #17 of 32 Old 08-03-2008, 05:17 PM
rubrock
True...it's pricey stuff....hey...why not use quality parts. (not sure Painless is quality).
I built both of my bumpers and swing gate because I wanted something custom..but it took me weeks of cutting, welding, grinding, machining and I had fun doing it.
I got what I wanted out of the project that someone else did not make.
Was it cheaper..hell no! I could have bought three sets of bumpers for what I put into mine. But if someone has what I need and it suits the bill...hey I will pay for it to free up my time to go wheeling.
My 1947 flat fender had kept me very busy..but there was not a lot of aftermarket goodies for it, so I fabricated parts for it. The same thing with my 1978 CJ-5..lot's of work.
But I will tell you, there are lot's of cool stuff for my TJ & JK out there and I could get off the trail and hit the road with air conditioning and cruise control on!
So what I am saying is, I to love to fab my own stuff. It gives me the appreciation for the guys who go ahead and make the aftermarket equipment (like the small guys like spod). I understand why things cost so much for these guys to build, especially if it's made here in the US.
I'm just standing up for the small guys..that's all.
Like I said, your project is very nice and it is what you wanted. Spod does not have what you wanted. For others, yes, maybe no, but to me the price for their system is justified my project.
rubrock is offline
post #18 of 32 Old 08-03-2008, 07:28 PM
jeeperjk
2009 JK Wrangler
Forgive me for the stupid question, but I'm trying to figure out how many amps the stock fogs draw. Planning some mods for my (yet to be delivered) new Rubi and can't find the specs anywhere. Are the both running on a 30A fuse?
jeeperjk is offline
post #19 of 32 Old 08-03-2008, 08:53 PM Thread Starter
waterboarder
The stock fogs cannot take much. I tried putting a slightly higher than stock bulb in there and it didn't work. The way to get around this is to make the fog light mod described in the wiring diagram above. Essentially, you wire the stock switch to a relay, and use the relay (which draws directly from the battery via a fuse) to power the fogs. If you go this route, you can put in as much watts to the fogs as you want - provided you use a suitable relay, wiring, and fog bulb - and still use the stock fog switch to operate the thing.
From my experience, you can't really upgrade the bulb in the fog lights without making the relay mod.
post #20 of 32 Old 08-03-2008, 09:57 PM
jeeperjk
2009 JK Wrangler
I was planning on using Xmitter 6" bars in their place.
http://www.visionxoffroad.com/products/led/xmitterbar/
These things only draw 2 amps each. The stocks gotta draw that much, right?
jeeperjk is offline
post #21 of 32 Old 08-03-2008, 11:40 PM Thread Starter
waterboarder
I was planning on using Xmitter 6" bars in their place.http://www.visionxoffroad.com/products/led/xmitterbar/
Oh, yeah, sure. But those things are not going to fit in the stock fog light openings, so why disable the stock fogs to use this switch, rather than just running another switch? Maybe I don't understand what you mean (:
post #22 of 32 Old 08-04-2008, 12:39 AM
jeeperjk
2009 JK Wrangler
When I replace the bumper, I am planning on using stock wiring to run the Xmitters on the new bumper. I'm gonna have the new bumper built with fog cutouts for the Xmitters and wanted to ensure that I'd be good with running them on the stock wiring.
Looks like it'll be fine...
jeeperjk is offline
post #23 of 32 Old 08-04-2008, 12:50 AM
OhanaTrails
texasdog,
Brah, you got some skillzzz! Looking good! Definitely gonna solicit your assitance once I hit the "light mod" phase of my build up
Stock Jeepney
OhanaTrails is offline
post #24 of 32 Old 08-04-2008, 02:37 AM Thread Starter
waterboarder
Oh, I see. Well, with that plan, yeah, you should be fine. If those new lights are really drawing only 2A, you will not have any problems at all. Look forward to seeing your results (:
post #25 of 32 Old 10-01-2008, 07:27 PM
Pylot7
Texasdog I just want to say thanks and a big jeep wave to you!
I studied what you did and created a panel similar to yours mounted on a piece of plexiglas with four relays and room for two more. Hooked it all up to a Daystar switch panel.
Works great! Looks professional! And I know that all of the circuits are fully fused so nothing is going to burn down.
With all of the potential for electric add ons for a Jeep an aux fuse panel is just about mandatory and getting it right is not hard if you have a great example to follow along.
Thanks again for all of your explanations and pictures! See you on the trail
Pylot7 is offline
post #26 of 32 Old 08-08-2009, 02:42 PM
compcrasher86
Looks really nice! I'm going to be setting up something similar for my XJ so I'll tell you how it goes. From OTRSTTW I'm getting a replacement switch for my rear wiper, momentary switch for defrost, E-Fan override switch, fog switch for my bumper lights, lightning bolt switch for my inverter, and a "work light" switch for my roof rack lights ,
In the end I'll end up custom fitting the panel into the factory area and I'll use some of your diagrams to help me set it all up. Good news is defrost and wiper wiring is already right there, and e-fan override is hooked up to the e-fan relay so I only need a three relay setup. Anybody have some advice on where to stash a relay board for an XJ? I was hoping to keep it in the cockpit just for waterproofing reasons.
Matt
compcrasher86 is offline
post #27 of 32 Old 08-09-2009, 09:07 PM
fernjack
Very clean ,did you put an Optima in ? a Premere power alt ? I really like how tight that looks . Very cool !
fernjack is offline
post #28 of 32 Old 08-10-2009, 08:42 AM
compcrasher86
Where did you order the Cole Hersee relays from? I want a couple haha
Matt
post #29 of 32 Old 08-10-2009, 08:52 AM
ge2
Gold Member
ge2's Avatar
I miss Tex......
The good ol' days.......
ge2 is offline
post #30 of 32 Old 08-10-2009, 09:04 AM
mattman8706
mattman8706's Avatar
2009 JK Wrangler
do you really?
someone misses him....
-Matt
mattman8706 is offline
Lower Switch Panel Electrical Issue JMW1191 JK Wrangler Technical Forum 1 08-20-2009 04:27 PM
custom console build dukegnarley YJ Wrangler Technical Forum 17 07-29-2008 07:40 AM
Custom Switch Panel????? brutester TJ Wrangler Technical Forum 17 03-14-2007 07:16 AM
Instrument Panel Lighting & Trailer Electrical... JohnChrist YJ Wrangler Technical Forum 2 09-07-2006 08:07 PM
Instrument Panel Lighting & Trailer Electrical... JohnChrist YJ Wrangler Technical Forum 7 09-07-2006 08:28 AM
