Currie 4" lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Currie 4" lift
Swag Off Road BIG-HIT TJ-YJ Rear BumperAll Bilstein shocks & struts - Lowest Prices Ever and Iron Rock Offroad products - get them from Kolak!
Unread 05-18-2015, 10:14 PM   #1
akdiesel
Currie 4" lift
Anyone here running a 4" Currie Antirock lift on a JKU? I am interested due to a neat YouTube video for Iron Hornet Offroad but can't find any info on their Jeep and they haven't posted on FB or Instagram in like a year so doubt they are still around. Lift look to articulate well and the AR swaybar seems to ride well. Also what shocks? I love Kings but don't know how any shocks would do in the winters up here. Thanks guys!
2012 JKU Sahara 4x4 Dozer Orange
USMC/OIF Vet
akdiesel is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 12:03 AM   #2
JLC08JK
What was I thinking?
JLC08JK's Avatar
I don't have a Currie lift so to speak though I do have Currie control arms, track bars and full Anti Rock system. All of their products are top notch. The Anti Rock system is great, no disconnecting and great flex with a good fealing of control.
I have Elka shocks that are made for Teraflex and really like them though I'm not sure how available they are now. Teraflex doesn't list them on their site anymore. Fox shocks are a more affordable option. I haven't tried Fox so I can't compare the two.
JLC08JK is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 11:12 AM   #3
akdiesel
Glad to hear they make quality products. I am excited to get the Jeep lifted but want to make sure I'm doing it right so I only have to do it once. From videos the AR looks awesome though there isn't much rock crawling up here I like trails and adventuring with my wife and kids. I think fox maybe the way to go since kings are so much but I'm not sure
USMC/OIF Vet
Unread 05-19-2015, 01:11 PM   #4
YATZI1980
2011 JK Wrangler
Just curious but any reason why 4" lift? Are you set on that height or just interested because of the video ?
YATZI1980 is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 03:36 PM   #5
yoyoyo109
2015 JK Wrangler
+1 on this
95 YJ 4.0L 5spd AX-15
15 JKUR Hard Rock
yoyoyo109 is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 03:52 PM   #6
mrwhipple
Had their 4" kit a TJ. Great lift and super flexy.
silver jkur
mrwhipple is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 04:38 PM   #7
SLADE
The flex, articulation, travel is mostly dependent on the shocks. Shocks depend on bump stop extention and mount location. A longer compressed shock length does not always mean a longer stroke.
If your after travel put some thought into your shocks.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 08:10 PM   #8
YATZI1980
2011 JK Wrangler
Ok. TJ and JK totally different animal. 2.5" is popular/ economic for the jk and you can up to 37" tires depending on other factors (fenders/wheels etc..) above 2.5" gets expensive around $1k per inch on avg and may require many additional components like drive shafts etc... But the possibilities are endless so build whatever you like. But my advice.... DO NOT BUY A CHEAP LIFT. By cheap I mean incomplete and low quality. You will regret it and end up spending the money anyway. There's lots of good info on here and some really smart people that will gladly give advice. Best of luck.
Unread 05-19-2015, 08:12 PM   #9
duneslider
The Fox shocks are a great shock but they really are geared towards high speed desert runs. That may not be the best fit for your type of jeeping. Not saying they won't be good but they may not be the best fit.
duneslider is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 10:08 PM   #10
akdiesel
Alaska apparently is quite strict about fenders covering tires. I want to run flat fenders but don't want to be completely harassed though I've considered it to stay lower center of gravity. I like the jeep in the video quite a bit and want to eventually upgrade axles and run 37s.
Thanks. I learned from previous rigs not to buy cheap. Do it once and do it right.
Good point. I do need to research shocks a bit more...the climate here is -50 to 90 depending on the season and it's all mudding and trails so rock crawler or desert **** doesn't really apply...I haven't found a recipe for up here like there are so many for normal environments in the States
USMC/OIF Vet
Unread 05-20-2015, 10:29 AM   #11
duneslider
Might want to look at the bilstein 5150,5165.
