Creaking hardtop..without freedom panels on - JeepForum.com
post #1 of 15 Old 09-14-2015, 12:35 AM Thread Starter
02jeepliberty
Lately been hearing sounds from the top and I looked up what it could be, read that it's mainly been the freedom tops making the noise. Pulled the freedom tops off today in hopes the creaking sound would go away, but it's still there. Sounds like it's coming from the roll bar area on the driver side..anyone else have this problem? Any ideas how to get it to stop? It's very annoying.
02jeepliberty is offline
post #2 of 15 Old 09-14-2015, 12:55 AM
Moezer
2015 JK Wrangler
Did u make sure that the top bolts r tight
Moezer is offline
post #3 of 15 Old 09-14-2015, 01:18 AM Thread Starter
02jeepliberty
Yes, out of curiosity...how tight should all the bolts be tightened?
post #4 of 15 Old 09-14-2015, 09:54 AM
Moezer
2015 JK Wrangler
Not sure but do it by feel, u can also check and see if the weather stripping on the hard top is damaged or not there at all
Moezer is offline
post #5 of 15 Old 09-14-2015, 10:58 AM
LFrider66
Check the sound bar bolts
LFrider66 is offline
post #6 of 15 Old 09-14-2015, 11:40 AM Thread Starter
02jeepliberty
When the two front panels are removed I have the creaking sound, so the two bolts for the sound bar aren't in place. It sounds like it's coming from the drivers side where the speakers are in the sound bar. Is there anything over there that it could be rubbing on that you know of?
post #7 of 15 Old 09-14-2015, 11:41 AM Thread Starter
02jeepliberty
What weather stripping should I check?
post #8 of 15 Old 09-14-2015, 11:43 AM
Moezer
2015 JK Wrangler
Well there's some on in the back and the ones on the front 2 bolts
Moezer is offline
post #9 of 15 Old 09-14-2015, 01:02 PM
JIMBOX
Don't forget the T30 TORX bolts that hold the hardtop to the tub and the (4) 10mm bolts that secure the soundbar to the roll cage !
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #10 of 15 Old 09-14-2015, 04:33 PM
LFrider66
There are bolts in the sound bar outside of the speakers my drivers side one right above my head came loose causing the soundbar to rattle
post #11 of 15 Old 09-14-2015, 05:28 PM Thread Starter
02jeepliberty
I'll check that out, thanks
post #12 of 15 Old 09-14-2015, 05:38 PM
Strats
2010 JK Wrangler
What do you use to keep the weather stripping from drying out? Any treatment for that?
Strats is offline
post #13 of 15 Old 09-14-2015, 05:53 PM
JIMBOX
Keepit in a garage and outta the sun !--
Move to Arizona/Nevada--mine is 7 years old/w no degrading to any of the rubber seals--
Good luck
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #14 of 15 Old 09-28-2015, 06:05 PM Thread Starter
02jeepliberty
Wanted to update...LFrider66 was right. Never would've guessed that the sound bar bolts would've caused the sound I was hearing but the creaking is gone. Thank you! New it had to be that after I still heard the creaking when the whole top was off
post #15 of 15 Old 09-28-2015, 06:26 PM
JIMBOX
you're WELCOME !
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
