crazy shuddering ? - JeepForum.com
post #1 of 14 Old 03-27-2008, 04:15 PM Thread Starter
JaredBoys
crazy shuddering ?
ok so a few days back I was running through a construction site and ran over a series of bumps in a row.. Straight road, no incline... it started to shudder like the frame was breaking in half... I slowed down and it stopped when I got down to about 25 mph or so... I thought about it and wrote it off to maybe the TSB freaked out b/c of the short series of bumps and whatever...
well today on the way home i'm going about 45-50 mph and around a slight turn ran over a few bumps and again.. felt like I was going to lose control... WTF... anyone else having a problem like this? love this jeep but what the heck man... I had the recall for the TSB thing done months ago... It is weird how all of the sudden this has happened twice in a week. I've had the jeep for about a year, 13k miles and nothing until now.
HELP
07' X Black 2dr w- S pkg, Hard top, Sirius, Side Steps, Power pkg, mats.
99' Cherokee Sport 4 dr, Red
JaredBoys is offline
post #2 of 14 Old 03-27-2008, 07:55 PM
91Jeep07
I've posted before with this problem also... happened to me last summer, took it to the dealer & they asked me to re-create the problem, which of course, I couldn't. Scenario was about 40mph around a slight corner 7 hit a small pothole which sent the front end into a wobble, had to brake about 10mph to stop the shuddering...not sure what the answer is yet.
91Jeep07 is offline
post #3 of 14 Old 03-27-2008, 07:58 PM
EmbarkChief
"death wobble"
Well Documented.
EmbarkChief is offline
post #4 of 14 Old 03-27-2008, 08:06 PM
91Jeep07
"Deathwobble" is not well documented by Chrysler though, most of the previous posts on it occur on lifted jeeps, not on stock suspension.
91Jeep07 is offline
post #5 of 14 Old 03-27-2008, 08:25 PM
tx-Skydiver
tx-Skydiver's Avatar
1979 CJ5
"Death Wobble" is really only a term used by us...and maybe some other enthusiast groups.
Basically, your alignment is out pretty bad and needs to be corrected. Once corrected, you are good to go.
Easy fix.
Current Jeep:
2007 JK Wrangler Unlimited (Black), 4" SuperliftRanchoExpress Lift, 36" Super Swamper Irok's covering 16" ProComp's, AFE CAI, FlowMaster 40 Series, Shrockworks Rock Sliders, Rock Hard line of undercarriage skids, Warn Powerplant, Shrockworks Mid-width front bumper, Dana 44 Front
tx-Skydiver is offline
post #6 of 14 Old 03-27-2008, 08:36 PM
Warlord2
could be the ESP coming on over the bumps, but I would put money on death wobble.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #7 of 14 Old 03-28-2008, 08:57 AM
91Jeep07
It has nothing to do with the alignment loose bots, etc..., had mine checked & was straight as an arrow, ESP would & should not come on over minor potholes, there was no tire slippage to set it off.
From what I could tell, the bump is enought to set the coils resonating
91Jeep07 is offline
post #8 of 14 Old 03-28-2008, 09:05 AM
TampaJK2008
you just aren't hitting the bumps hard enough...
2008 Jeep Wrangler X Unlimited
Stone White
6 Speed Manual
TampaJK2008 is offline
post #9 of 14 Old 03-28-2008, 04:22 PM Thread Starter
JaredBoys
no lift and i don't see how it can be out of alignment already. bone stock
post #10 of 14 Old 03-28-2008, 05:26 PM
onlyone
onlyone's Avatar
2014 JK Wrangler
Check trackbar tightness. Get tires rebalanced. Those are the 2 major reasons for death wobble.
Thank you Jesus
2014 Wrangler Sport 1.5" spacers in front .75 rear, 1" BL 255/80/17 BFG KM2
onlyone is offline
post #11 of 14 Old 03-29-2008, 07:35 AM
chrisgardner73
chrisgardner73's Avatar
Agree! Mine was trackbar related!
This seems odd for a stock JK though!?!?! You would think that it would have come off of the line good to go. However, I found loose bolts here and there when mine delivered...
2007 Rubicon Unlimited / Skyjacker 2.5" Lift / Teraflex Track Bars / JKS Discos / 35x12.50 BFG MT's on 17" Steel Rims / AIRAID CAI / Borla Exhaust / JET Stage One Chip / AIRAID Throttle Body Spacer / Xenon Flares / Garmin Trail Guide / KC Lights / Husky Liners / Alpine iDA-X001 iPod Head Unit / CB / I think that I have a problem....
Just Jeeps of Omaha
chrisgardner73 is offline
post #12 of 14 Old 03-29-2008, 05:10 PM Thread Starter
JaredBoys
feels tight in the front.. I did notice if you grab the track bar (the one with the steering stabilizer on it). It will rotate up and down a bit. I believe this is normal b/c of the ball joints on the ends. Then again, could be very wrong to have any play at all in it. Can anyone else confirm their front bar does the same thing... I don't see how that could have already developed a problem. I don't take it off road nearly as much as I would like to.
Thanks to anyone that can check theirs for me
post #13 of 14 Old 03-30-2008, 07:06 PM
thejafe
thejafe's Avatar
That's not your track bar that's your tie rod and yes it moves due to the ball joints.
Definitely sounds like you were experiencing death wobble. Things to check:
alignment
wheel balance
front track bar bolts for tightness
Best thing to do is have a friend sit in the driver seat and turn the wheel rapidly from side to side. While he/she does this get on the ground and watch all of the bolts in your steering components to see if there is any play (ie. bolts or the bushings that surround them moving from side to side).
If you do notice any play then tighten 'em up.
Use the search feature and you will find about a gazillion threads documenting the cause and effects of death wobble and how to get rid of it.
Any Jeep with loose steering components and or a bad alignment or wheel balance is susceptible to death wobble. It's just the nature of the beast.
thejafe is offline
post #14 of 14 Old 03-30-2008, 07:22 PM
thejafe
thejafe's Avatar
thejafe is offline
shuddering AX-15 tranny evilpsych YJ Wrangler Technical Forum 8 07-14-2011 03:07 PM
Jeep is shuddering...? HMTwin TJ Wrangler Technical Forum 4 11-21-2009 05:11 PM
tranny shuddering?? Beltfed09 JK Wrangler Technical Forum 9 08-28-2009 10:46 PM
Need some help (shuddering) BlackJeepin TJ Wrangler Technical Forum 11 06-03-2008 05:39 PM
Shuddering on takeoff... RenegadeYJ17 YJ Wrangler Technical Forum 3 04-13-2003 10:07 PM
