-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Crashed my JK into a tree last August.. still problems? (http://www.jeepforum.com/forum/f96/crashed-my-jk-into-tree-last-august-still-problems-1534600/)
ctappan94 06-10-2013 08:41 AM
Hey all,
While offroading last year, I went through a mud pit and the windshield wipers never turned on (my bad) and next thing I knew, I had hit a tree... Well I effed the alignment up really bad and if i hit the brakes they would pulsate and sound like crack crack crack when i hit the pedal.. and randomly, even after replacing the right lower control arm (it bent badly) and getting an alignment AND even new tires, every once in awhile, the jeep will still not track straight, and the brake clicking occurs once in every 100 pedal depressions (guesstimate) .. and occasionally while driving (only happened twice), but when Im driving the traction light will randomly flash and a significant pulsating can be felt through the steering wheel, exactly how it pulsed when I had effed up the alignment the first time... how do I check for other damage because to my naked eye, everything LOOKS normal.!? thanks
TheMercenary556 06-10-2013 09:21 AM
Sounds like a great time to trade for a 2013
ctappan94 06-10-2013 09:36 AM
lol there's nothing wrong with the 12's & I have wayyyyy too much money in it to do that :/
Astennis1 06-10-2013 09:44 AM
Is the steering wheel straight? That will cause the brake clicking which is probably abs. The alignment should have fixed this.
AveCat 06-10-2013 04:45 PM
x2
tankinyj 06-12-2013 01:10 AM
ESP, which activates the ABS to "correct the path of the vehicle from the current 'slide' that it thinks its on"
ctappan94 06-12-2013 08:21 AM
The steering wheel, despite two alignments , never tracks straight. If the steering wheel is straight, the vehicle will barely aim to the left. Happens 75% of the time. The rest of the time it tracks normally
tacjeep99 06-15-2013 10:04 PM
Sounds to me like you need to get your axle checked over thoroughly to make sure that it is not bent, the upper ball joint hasn't been screwed up and make sure your drag link is adjusted properly. If your control arm was bent badly enough to need replacement then there was probably other damage as well. They may have fixed what was readily apparent without checking further.
You say it doesn't track right, I would also have the frame alignment checked out. I had a CJ-5 that didn't track right. The PO told me he slid off in a ditch while going down the road but it was "ok". After I drove it for awhile I knew there was something wrong with how it drove. Took it to a friend of mine's frame shop. The frame was tweaked and needed to be straightened. He fixed it and it drove great after that.
I hit a rock with my TJ and knocked the front end out of alignment. The Jeep dealer said they could align it, but there would still be a slight pull. They said the upper ball joint needed to be replaced. I had them replace it, align it, and it drives perfectly, and the steering wheel is aligned like it should be.
In short, by your own description, I think you have more hidden damage than you realize. I would get the axle checked to make sure it isn't bent, check the ball joints, and if the problem is still there, I would consider getting the frame alignment checked. When you hit something, the weakest point might give, but the energy from the hit does transfer throughout the vehicle via the frame, axle and body.
ctappan94 06-17-2013 08:42 AM
oh my god.. lol thank you this was exactly the response I was looking for ^^. driving down the parkway today, my whole dash lit up and the speedo dropped to zero and the jeep pulled violently to the right and just pulsed....scared the sh** out of me!
tacjeep99 06-17-2013 09:00 AM
Whatever is wrong with your Jeep is fixable, you just need to get the problem figured out. I would start with the ball joints and front axle check first and if that doesn't solve the problem, get the frame checked.
pentastarguy 06-17-2013 03:04 PM
hello in whitehouse, my first thought was your front axle is crooked. that is the first thing i would have checked. then the steering wheel. if those two items are ok, i would move on to the steering shaft and steering box and continue to the front end components. did you fix this yourself or have it done? if you had it done, you need to go back to the place that did the repair. involve ins company if you need to.
ctappan94 06-17-2013 09:28 PM
unfortunately I did it myself.. and yes I DO remember the axle sitting crooked prior to the new control arm..you think it may still be the case???
ctappan94 06-17-2013 09:29 PM
and if so, any ways to check if its crooked or not? sorry for the repeated response haha
pentastarguy 06-17-2013 11:03 PM
yes there is a way to check it but not something i have done or can explain. hopefully someone else can jump in and explain, or you might need to get to a good body shop and have them give it the once over.
tacjeep99 06-18-2013 07:54 AM
You need to take it to a frame and alignment shop. They have the tools and the measuring gages to determine what is going on with your jeep. A body shop, unless they do inhouse frame repair, may not have the right measuring tools to evaluate if your axle or frame is damaged. Base on your latest description of the damage, there is a high likelihood your axle is tweaked, and possibly the frame.
The time now is 11:00 PM.
