Cracked Exhaust Manifold - JeepForum.com
post #1 of 14 Old 07-03-2012, 12:06 PM Thread Starter
westt
Looking for a low cost solution: Anyone try welding the crack? Or just bite the bullet and have a new one installed? Can this be done with simple hand tools? Anyone near New Philadelphia, Ohio that would want to help me wrench this?
I bought an used early 2007 fab date and I swear that it has every issue known: lifter tick - check, torque converter shudder - check and replaced under warranty, fuel burp - check (waiting for recall), windshield leak - check (waiting for rock damage).
All that being said, my wife and I still love it.
westt is offline
post #2 of 14 Old 07-03-2012, 01:21 PM
CJsPerson
I fixed mine in an hour in my driveway.
I bought my manifold at a distributor not a dealer so the price was fine, can’t remember what I paid but I remember thinking “that’s all?”
You will need several extensions or a long one and a swivel for your ratchet. The two bolts on the exhaust pipe are easier to get from the bottom. I hit all the bolts with PB blaster the day before. The repair went off without a hitch. Very easy.
Never trust a happy man
I off road because I have a Jeep. I don't have a Jeep because I off road. Above all my Jeep is a convertible. That's where my love is for the brand ...convertible overkill
CJsPerson is offline
post #3 of 14 Old 07-03-2012, 01:29 PM
Coolcatracing
When it comes to cast iron pieces I just replace them, welded cast iron is a pain and pretty much impossible in the vehicle. Once you have it out and pay the cost to weld it you've almost paid for a new one.
08 Unlimited Rubicon 6 speed, 315/70-16 Kelly TSR, 1.5" Spidertrax spacers factory Moab's, Rubicon Express Flex arm 3.5" lift, Smittybilt XRC front bumper with D-rings, Body Armor Extreme rock slider steps, AEV snorkel, trimmed fender flares, Hella 8" HID driving lights
Coolcatracing is offline
post #4 of 14 Old 07-03-2012, 03:27 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
DITTO - well at least cost to weld CORRECTLY. Even on the old obsolete cast iron parts (where a new item does not exist) I would recommend lock-n-stitch over welding. Properly welding cast requires a ton of prep and a VERY good welder (man and machine) - well above average, and even then you have new stresses that must escape - usually as a crack elsewhere a few miles later.
Although I am sure you can always find someone willing to take your money and give you other hope...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #5 of 14 Old 10-08-2012, 07:14 AM Thread Starter
westt
Is the exhaust manifold covered under federal emissions warranty???
westt is offline
post #6 of 14 Old 10-08-2012, 09:26 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
No - only the components newly developed and added under the clean air act that control combustion are covered. Manifolds existed prior to the clean air act.
post #7 of 14 Old 10-08-2012, 10:15 AM
Prot
Prot's Avatar
2014 JK Wrangler
Might want to consider headers since replacing the manifold with an identical manifold may lead to the same failure.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #8 of 14 Old 10-08-2012, 10:38 AM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Not really - a quick trip to a machine shop for a $10.00 run through the shot blaster will relieve the stress risers and make that new manifold last almost forever!
But lacking that headers are a good choice - just a bit more underhood noise and a small amount more underhood heat.
post #9 of 14 Old 10-08-2012, 10:48 AM
ronjenx
ronjenx's Avatar
I don't know about that being how they figure what's covered, but here is what the JK warranty book says is covered for a longer period than the rest of the vehicle:
B. Parts Covered for 8 years or 80,000 miles
If your vehicle has one of the following parts, this
Federal Emission Warranty
covers that part for a
period of 8 years or 80,000 miles, whichever occurs first.
These limits are counted from the time when your
Basic Limited Warranty begins under 2.1(E). The
covered parts are:
catalytic converter; and
powertrain control module.
ronjenx is offline
post #10 of 14 Old 10-08-2012, 04:05 PM
Coolcatracing
So the PCM is covered as well, did not know that.
post #11 of 14 Old 10-08-2012, 06:43 PM
JTPhoto
JTPhoto's Avatar
What about JB Weld??
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 37x12.50x17 Pitbull Rockers on ProComp 7069 Alloys, AEV Prem Bumper ETC..
JTPhoto is offline
post #12 of 14 Old 10-08-2012, 07:43 PM
mello
Jb weld is a good thought however on a cast iron manifold the excessive heat will cause it to fail very quickly.
mello is offline
post #13 of 14 Old 07-08-2013, 07:43 PM
herculz
2010 JK Wrangler
Got mine at dealership today wondering if its this. I read a lot of threads of ticking starting when they warm up, my ticks when it's cold and after it warms up ticking has vanished. Someone I bumped into mentioned his jk did same and to start jeep place in drive step on brake and give some gas, that made ticking come back hot or cold. So not sure. We will find out
herculz is offline
post #14 of 14 Old 07-09-2013, 08:49 PM
herculz
2010 JK Wrangler
Got my jk back and sure was a cracked exhaust manifold. Guess its part of warranty as I have 88k miles and paid for the extended warranty but issues before had me pay a deductible but this time bill was zero dollars.
herculz is offline
Cracked Exhaust Manifold tha5150 YJ Wrangler Technical Forum 7 02-16-2010 01:09 PM
cracked exhaust manifold Schmuds YJ Wrangler Technical Forum 23 07-08-2008 09:40 PM
Cracked NEW exhaust manifold Nonya TJ Wrangler Technical Forum 18 06-28-2008 08:20 PM
cracked exhaust manifold weslaine TJ Wrangler Technical Forum 17 03-31-2006 12:58 PM
CEL = Cracked Exhaust Manifold? quadna71 TJ Wrangler Technical Forum 1 04-12-2005 08:34 AM
