could use a little more flex - JeepForum.com
post #1 of 23 Old 10-05-2006, 02:08 PM Thread Starter
I.O.A.MUD
I.O.A.MUD's Avatar
http://www.quadratec.com/community/j...=QNEWSLET0906C
1990 2.5 basicly stock
WIFES CAR 1997 Grand cherokee Larado v-8 auto
We dont stop playing because we grow old....we grow old because we stop playing!
I.O.A.MUD is offline
post #2 of 23 Old 10-05-2006, 02:40 PM
cab76
Looks good to me - the article notes these were taken with the sway bar intact.
It is a fact that a stock JK (with the electronic disco) will flex better than a stock TJ.
cab76 is offline
post #3 of 23 Old 10-05-2006, 02:56 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
are the electronic sway bar disco's an option on all JK or just std on the Rubi?
2013 FR-S
BlaineWasHere is offline
post #4 of 23 Old 10-05-2006, 03:09 PM Thread Starter
I.O.A.MUD
I.O.A.MUD's Avatar
Didnt see the part about the swaybar still bing in tact. Still gets a little tippsy even with the longer wheel base.
post #5 of 23 Old 10-05-2006, 03:40 PM
scottyc
Late availability on X and Sahara. Must be optioned with rear locker.
scottyc is offline
post #6 of 23 Old 10-05-2006, 04:21 PM
Laxstar46
From what quadratec says in there they say the 3.8 feels better than the 4.0. that comes as a surprise to me
Laxstar46 is offline
post #7 of 23 Old 10-05-2006, 04:39 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
WTH kind of RTI ramp is that? Designed for ATVs? If they disconnected the swaybar they could have driven right over the thing.
I'll be Savvy someday!
neZZr is offline
post #8 of 23 Old 10-05-2006, 06:00 PM
Laxstar46
Yea it looked pretty good i would bet the 2 doors would be even better. I still not sure bout the 3.8 tho
post #9 of 23 Old 10-05-2006, 06:19 PM
wrnglrguy
wrnglrguy's Avatar
Looks like the rear is flexing more than the front. Weird.
wrnglrguy is offline
post #10 of 23 Old 10-05-2006, 07:09 PM
NEWtoTHEjeepLIF
If the front is connected that is what it's going to look like. Even on a TJ.
NEWtoTHEjeepLIF is offline
post #11 of 23 Old 10-06-2006, 01:16 AM
Hip2u77
2 Door Flex. . . RTI 831 (or something like that) with the swaybar disconnected)
Hip2u77 is offline
post #12 of 23 Old 10-06-2006, 07:02 AM
JLH
Just to compare a few other vehicles here is a cut and paste from the Motor Trend test of other SUVs. Its easy to see that the JK with kill the Xterra and FJ on the RTI scores.
Fourth Place: Our "Trail Rated" Liberty had a not-too-shabby 450 RTI result, but had the smallest tires of the group (225/75R16) with the least aggressive tread. Gearing is adequate, but the clumsy slot-machine 4WD lever puts up a fight when going into and out of 4Low.
Third Place: The Xterra scored a 384 RTI (lowest of the four), but did offer a big tire (265/75R16) and an electronic locking rear differential (some called it the "Save Me!" button). The 4.0-liter V-6 is powerful and responsive, making the Nissan a favorite in the high-speed sand washes.
Second Place: The Toyota FJ's suspension uses coil springs in front and back and scored a solid 491 RTI. The "A-TRAC" traction-control system calculates the right amount of traction needed in high and low range. And, although it's loud and vibrates like crazy when engaged, several testers appreciated the A-TRAC's feedback. In addition, the FJ offers a push-button rear locker (which disconnects traction control), and runs the dry-wash trails like a Baja pre-runner.
First Place: With the most compliant suspension, the H3 scored a 521 RTI and has a transfer-case low-range gear almost two times lower than do the others. In addition, the Hummer had the biggest, most aggressive tires (285/75R16) and a smart traction-control system that works in combination with a rear locker. If there's a weakness, not surprisingly, it's the anemic I-5 that had trouble pushing our 2.5-ton H3 through the desert sand washes.
JLH is offline
post #13 of 23 Old 10-06-2006, 07:11 AM
JLH
Originally Posted by I.O.A MUD
That is not a standard 20 degree RTI ramp, so calculating the score is impossible without knowing the angle.
JLH is offline
post #14 of 23 Old 10-06-2006, 08:16 AM
300bhp/ton
1995 XJ Cherokee
What's RTI?
Ex Jeep owner. Currently lots of Land Rovers....
300bhp/ton is offline
post #15 of 23 Old 10-06-2006, 08:20 AM
Sweeney
All you need is the height off the ground, the angle is irrelevant.
Sweeney is offline
RE 3.5 - Need more flex?? seabass2020 TJ Wrangler Technical Forum 54 07-16-2009 11:25 AM
Max. Flex vs. Useful Flex and The Anti-rock lupinsea TJ Wrangler Technical Forum 34 10-29-2008 10:03 AM
Need More Flex JamesLouis YJ Wrangler Technical Forum 17 11-08-2006 07:25 PM
flex tjsooley TJ Wrangler Technical Forum 9 03-04-2006 07:10 AM
RE Super flex or Standard flex treypal TJ Wrangler Technical Forum 10 06-21-2005 08:01 PM
