Corner Armor Without Fuel Hole - JeepForum.com
post #1 of 11 Old 02-14-2014, 09:25 PM Thread Starter
Maertz
2009 JK Wrangler
Does anyone know if anyone makes a rear 2 door corner armor that does NOT have the hole on the driver side for the fuel filler? Id hate to have to cut out circle chunk of metal weld it in then grind it flush to eliminate it. Id prefer the corner also goes from the rear and cover the whole rear quarter panel. I cant seem to find any.
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
post #2 of 11 Old 02-14-2014, 09:37 PM
Brut4ce
2010 JK Wrangler
Not until we run on air....lol
Call one and ask they just need to eliminate that action from the cutter. Don't know that they will but filling it in and grinding is quick enough.
"There's plenty of time to rest when your dead or knocked out!"
BUILT FOR THE ROCKS BUILD
Brut4ce is offline
post #3 of 11 Old 02-14-2014, 10:05 PM Thread Starter
Maertz
2009 JK Wrangler
true i was just being lazy lol
Maertz is offline
post #4 of 11 Old 02-14-2014, 10:49 PM
Brut4ce
2010 JK Wrangler
Lol....understand...wish there was blanks for a lot of stuff...life would be good...
You can probably get a set though....it would be on one of the upcoming production runs. Might hit you with a 1 off price for removing it from the batch ....
Brut4ce is offline
post #5 of 11 Old 02-14-2014, 10:52 PM Thread Starter
Maertz
2009 JK Wrangler
on a second note anyone know what the dimension of the hole is on the corners thats precut? I can measure mine tomorrow, but ill need to know this to get the right size hole saw. Im hoping its 4.5 as i already have one
Maertz is offline
post #6 of 11 Old 02-14-2014, 10:59 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Have your local steel supplier cut you one and turn it to the exact radius of the corner on the jeep.
I priced out aluminum and it was cheaper blanked than the steel smittybilt was off the shelf for my yj.
Luck Favours The Prepared
Anticanman is offline
post #7 of 11 Old 02-14-2014, 11:03 PM Thread Starter
Maertz
2009 JK Wrangler
I was just debating that, minus the rolling. I was trying to think how it would look squared away were the bend was. then itd be pretty simple. i can get the steel sheets from my work.
Maertz is offline
post #8 of 11 Old 02-14-2014, 11:05 PM
Brut4ce
2010 JK Wrangler
Yj has a single radius jk is compound it has vertical radius as well as horizontal.
That's why poison spyder paid to have a stamp made and the reason the material thickness is limited.
Brut4ce is offline
post #9 of 11 Old 02-14-2014, 11:09 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You could square it off or have separate pieces made up and weld a butt joint at the apex joining the two sides.
post #10 of 11 Old 02-14-2014, 11:09 PM
Brut4ce
2010 JK Wrangler
Evo has squared off sides it will give you an idea...they weld little top plates for antennas and whatever their.
Brut4ce is offline
post #11 of 11 Old 02-14-2014, 11:17 PM Thread Starter
Maertz
2009 JK Wrangler
just looked at those. i dont want mine to look like an evo one though...
http://www.northridge4x4.com/shop/po...teel-14-04-040
this is ideally what i want for the jk. the front of the wheel well is where i want to put my fuel fill at the moment. I would just need one bend on top. I bet it wouldnt be bad.
thats essentially how im cutting the body tomorrow.
Maertz is offline
