Cons of regearing - JeepForum.com
post #1 of 20 Old 09-05-2012, 12:11 PM Thread Starter
12Htownsahara
Cons of regearing
I'm considering pulling the trigger on some gears 5.13 to be exact. Just wondering of there are any cons in regearing. I have a 2012 JKU auto tranny. Will my gas mileage Increase or decrease? I know they will help my engine run under less strain just curious about downfall of regearing if there is any. My JK is 90% highway for now. 3 months 6200 miles.
"Back up and Gas it"
12Htownsahara is offline
post #2 of 20 Old 09-05-2012, 12:40 PM
MudDuck99
2014 JK Wrangler
With no lift or bigger wheels and/or tires, and and you driving 90% highway ; it really wouldn't make sense. It doesn't seem like it would be worth the money. 5.13s on the highway will definitely give you worse mpgs
MudDuck99 is offline
post #3 of 20 Old 09-05-2012, 12:48 PM Thread Starter
12Htownsahara
Im sorry I have a 3.5 inch lift with some 35 inch Nitto trails
post #4 of 20 Old 09-05-2012, 02:37 PM
DrHolliday
2011 JK Wrangler
4.10's are pretty good for the 2012 auto and 35's. 4.56 would be better. Anything higher would be too much gear imo.
2011 JK Rubicon 2 door 6-speed manual, 3.5" Rock Krawler Suspension lift, 1.25" Daystar body lift, 40x13.50R17 Nitto Mud Grapplers
DrHolliday is offline
post #5 of 20 Old 09-05-2012, 02:44 PM
SubAtomicGenius
2011 JK Wrangler
Cons of regearing to the right gear range? None. Regearing deeper than required? High RPMs on highway and loss of mileage.
SubAtomicGenius is offline
post #6 of 20 Old 09-05-2012, 03:01 PM Thread Starter
12Htownsahara
So maybe 4.88s would be better. I don't wanna run over 3 grand doing 70-75. I just want to stop lugging my tranny and hunting for OD.
post #7 of 20 Old 09-05-2012, 03:02 PM
perryhooah
yeah, like he said... you need to know where you wanna go before you do it, and if you install the correct ratio, you will be great, but if not, too low OR too high, things could suck pretty bad
2008 UNLIMITED
OIF ('03-'04) & OEF ('07-'08)('12-'13) Veteran
perryhooah is offline
post #8 of 20 Old 09-05-2012, 03:28 PM
Vince1
2010 JK Wrangler
Few have ever regretted going 5.13 with 35's on an automatic.
Vince1 is offline
post #9 of 20 Old 09-05-2012, 03:34 PM Thread Starter
12Htownsahara
Like I said I drive mine on the hwy everyday. 2000 miles a month. I want to regain my stock power and and stop OD hunting.
post #10 of 20 Old 09-05-2012, 04:07 PM
DrHolliday
2011 JK Wrangler
On 07-11 correct, the 2012 has completely different gearing. Its more like the 07-11 manuals as far as over drive is concerned.
post #11 of 20 Old 09-05-2012, 04:13 PM
Spank
2014 JK Wrangler
4.56 seems to be the sweet spot on the 2012+ models with 35's.
'14 Wrangler Unlimited Rubicon
Spank is online now
post #12 of 20 Old 09-05-2012, 05:08 PM
gwar11d2
2009 JK Wrangler
Looks like 4:1 or 4:56 would put you in a nice spot. The 5:13's you posted first would be good for 2007-2011, but you have a 2012 so here is what the gear chart says. These are RPM's at 70MPH, Green - Good balance, Yellow - Sluggish or flat roads - Blue - rock crawling, a lot of towing, etc
09 JK Jeep Green Sahara Unlimited / Teraflex 2.5" Spring-Shocks / 35's x 16" Level 8 Trackers/ Aussie Locker Front / 5:13's
My Build Thread:
gwar11d2 is offline
post #13 of 20 Old 09-05-2012, 08:26 PM
cdj588
When I drove the 2012 4door with the 255/75/17 wheels and 5 spd auto and the 3.73's the rpms were right at 3000 at 70. Seems like this chart is wrong or Im missing some information cause 255/75/17 is a 32inch overall wheel
cdj588 is offline
post #14 of 20 Old 09-05-2012, 09:25 PM
Brightwhite
From all of the research i have done I am torn between 4:56 and 4:88 on my '12 auto. The 4:56's seem to be plenty for even up to 37's (the largest I could ever see going). That's what I am leaning towards.
I drive like you. To and from the airport every week and around town. Then the occasional weekend run up to the mountains.
Brightwhite is offline
post #15 of 20 Old 09-05-2012, 10:00 PM
tjkj2002
2002 KJ Liberty
Going the next lower gear set will help for city driving and let's face it driving a Jeep on 35"+ tires at 75mph+ can be scary and sometimes unsafe.Plus going one set lower will help overcome the added weight of the tires and any armor while just going back to the "stock zone" you still have mpg and performance loss due to the added weight but drastically better then the stock gears ratio with the big tires.Higher engine rpm's does not mean less mpg's or reduced engine life.
When I was researching what gear ratio to regear to everything said 4.88's would get me back in the stock range so I went with 5.13's since I do alot more city driving.After all was said and done I wished I went with 5.38's.
tjkj2002 is offline
