Confusion about towing - Page 3 - JeepForum.com
post #31 of 37 Old 07-28-2013, 08:20 AM
rirrgang
As bad as the performance of the 3.8 ltr is just pulling the JKU around, I can't imagine how bad and unsafe it would be taking on an additional 3500lbs. The Wrangler is just not made to tow. You should buy something that is. The Jeep isn't it.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #32 of 37 Old 07-28-2013, 09:34 AM
rayder1
I towed my bass boat, tackle, luggage and 1 or 2 passengers all over the state with the inline 6 '87 YJ perfect, maybe a little slow in the mountains. I don't know if people here are expecting F350 performance, but you are towing with a relatively low torque gas engine. My manual tranny held out fine for years....and this was a crappy model year.
Tow to capacity. Have brakes on the trailer if 3000# or more. Use turn outs and stop for gas a lot. That's all you should expect with a class 2 equipped jeep with 4: plus gear ratio. If you are less than 4:10 you shouldn't tow because you are going to lug like you had twice the weight on. It'll still work, just a lot slower.
Exceed the tow capacity and you will have severe handling issues.
rayder1 is offline
post #33 of 37 Old 07-28-2013, 10:25 AM
Filthy-Beast
^+1, If your performance sucks while towing, it's gear ratio, plain and simple. You want to be in the green of the gear charts, if you want balls with 3000+# be in the blue. It's rated to pull 3500# in the US, more in other counties.
Don't use marginal equipment! Have good brakes and tires on the jeep and trailer, good brake controller, safety chains, breakaway kit on trailer. properly distributed load with 10-15% of the weight on the tongue not exceeding 350#. Use a truck stop weight station to make sure. If the rear of the jeep is sagging get a weight distributing hitch with anti-sway.
Loaded and towing your tires air pressure needs to increase vs. unloaded around town, chalk test.
finally it's a brick on wheels pulling a brick, MPG will suck
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #34 of 37 Old 07-28-2013, 10:37 PM
Downwindtracker
That's good advice. How ever from experience ,trailer brakes are very important.
Blue wire, trailer brakes I think, but check your Podigy brake controller instructions.
For hills, gear down, and be patient.
Downwindtracker is offline
post #35 of 37 Old 07-29-2013, 05:20 AM
Filthy-Beast
Originally Posted by Filthy-Beast View Post
... Have good brakes and tires on the jeep and trailer, good brake controller.....
I Agree!
For Sale:
post #36 of 37 Old 07-29-2013, 10:26 AM
duneslider
IMAG0036 by duneslider, on Flickr
I pull a 10ft popup with mine and it pulls great. I think the max weight is around 2700lbs. I am sure I am close to that when loaded and then I have stuff in the back of the jeep and 3 kids. Trailer brakes are a must. I did have 33's and 4.10's and it was pretty good. I usually got about 15-16mpg pulling with OD off and keeping speeds to 65 max. With trailer brakes it seems to stop just as good as when I am not pulling a trailer. I have no issues pulling this weight and the mountains are plenty steep here. I am not going 65 up the mountain passes though!
A transmission cooler is a must though, up the really steep passes the transmission is getting pretty warm even with a cooler.
I have pulled my utility trailer without brakes with a weight of 3500-3700lbs (just a short distance near my house) and that was a very uncomfortable few minutes, I would not want to do it on the highway or for a long distance.
duneslider is offline
post #37 of 37 Old 09-01-2013, 07:15 PM
ColoradoTravler
2011 JK Wrangler
After 1800 miles on the road with our R Pod travel trailer we are convinced towing can be a good experience with a Jeep Wrangler if it is set up properly. Check out our reply to a question about R Pod we posted earlier.
ColoradoTravler is offline
