Common Problems with JK - Page 3 - JeepForum.com
post #31 of 36 Old 12-06-2006, 09:54 AM
scottyc
Originally Posted by JK2BJeep3
3500 miles so far JK Unlimited Sahara. Have had a couple hiccups actually. Electrical system blinked on me one day while driving - lights dimmed, radio died, speedometer, etc. shut down and then all came right back on (all idiot lights came on) then everything went back to normal. I mentioned it to the dealer at my oil change and they check battery connections but everything seemed fine. Couple days ago the ESP/BAS light came on but I hadn't touched the ESP off button. Hit the button, and it the light went off, seems normal now....
These are known issues. You should check out this TSB:
http://www.alldata.com/tsb/Chrysler/.../18036061.html
scottyc is offline
post #32 of 36 Old 12-06-2006, 10:25 AM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
That's also posted in this thread in case that link goes down: http://www.jeepforum.com/forum/f96/head-unit-problems-345243/
I'll be Savvy someday!
neZZr is offline
post #33 of 36 Old 12-06-2006, 06:51 PM
tbrkek
I had the exact same problem! I even posted it here a while ago somewhere. Everything blinked on and it died. Started right back up. This happened around 3000 miles as well. I now have 9500 miles on it and it hasn't happened since. WEIRD!!
tbrkek is offline
post #34 of 36 Old 12-07-2006, 09:44 AM
JK2BJeep3
Originally Posted by neZZr
That's also posted in this thread in case that link goes down: http://www.jeepforum.com/forum/showthread.php?t=345243
Thanks for the info. Just after I posted I found that in the other thread or on JKboard and was relieved it wasn't just me. Will bring the info at my next trip to the dealer.
JK2BJeep3 is offline
post #35 of 36 Old 12-08-2006, 03:56 PM
doojer
Interior paint issues
Well, I was digging around on the floor of my JK today and all of a sudden something horrible caught my eye.... the paint on the inside of the front passenger side (towards the hood from the door, below the glove) was completely shreaded There is just no way that somone could have done this with their feet, so I checked the driver's side in the same spot and it was shreaded, too! I went back around to look at the passenger side again and noticed a bubble in some of the paint near the shreaded area. I rubbed it with my finger and it came off Left a big ol' chip showing the primer!
Man, I've got to call my dealer now. I'll post pics in 2 days and 8 posts
EDIT: here are links, in the meantime...
Driver's side:
Passenger's side (with paint chip to the left of the scratches
- Jeep Green, Auto, 4:10, D30 front/D44 rear, RockCrusher Diff Covers
doojer is offline
post #36 of 36 Old 12-15-2006, 11:00 AM
Good
1975 CJ5
Mine leaks antifreeze, but I think it's only when it's cold. Like pressure builds up before the thermostat opens and it just blows some out where the top tube goes into the radiator. Any suggestions?
Part Dodge
Part Chevy
Part Humvee
Mostly Jeep...
All American.
Good is offline
Common problems on a 95 whitejeep08 YJ Wrangler Technical Forum 14 03-07-2007 11:57 AM
Common A/c Problems. Pheonix1001 YJ Wrangler Technical Forum 1 07-11-2006 04:20 PM
Common TJ problems Gundog TJ Wrangler Technical Forum 53 10-20-2004 03:25 PM
Common Problems with '92 - '95s? JeffR YJ Wrangler Technical Forum 16 02-19-2003 05:22 PM
Common problems for my 94? ImNotRyan YJ Wrangler Technical Forum 1 01-15-2002 06:53 AM
