Collapsed oil filter. - JeepForum.com
post #1 of 10 Old 11-19-2015, 09:51 PM Thread Starter
JTPhoto
Buddy's 2013 is having major engine issues. Upon inspection it appears the oil filter has collapsed and caused some engine damage. Any ideas as to what would cause the filter to collapse.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 37x12.50x17 Pitbull Rockers on ProComp 7069 Alloys, AEV Prem Bumper ETC..
JTPhoto is offline
post #2 of 10 Old 11-19-2015, 10:01 PM
222Doc
there was a change of design somewhere in the 13's. You have to be real sure you get the right one. Mine is the first gen one so i have to check the parts guy to be very sure i dont get a new designed one. makes it almost a orphan... the only thing i can think off that might have caused this.
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is online now
post #3 of 10 Old 11-20-2015, 05:05 AM
Wrigley
I have a 2013 as well. 90,000 miles on it. I only use Purolator filters. L36135 is what he wants.
Mike
Wrigley is offline
post #4 of 10 Old 11-20-2015, 06:42 AM Thread Starter
JTPhoto
Do you know what the difference is between the filters? How would one tell if they have the wrong filter?
^^Jeff^^
JTPhoto is offline
post #5 of 10 Old 11-20-2015, 06:47 AM
Neo1130
2015 JK Wrangler
Different lengths check video below at 7:20
Neo1130 is offline
post #6 of 10 Old 11-20-2015, 07:04 AM Thread Starter
JTPhoto
Originally Posted by Neo1130
Different lengths check video below at 7:20 Video Link: http://www.youtube.com/watch?v=jjGnEI1HmNY
Excellent thank you.
^^Jeff^^
JTPhoto is offline
post #7 of 10 Old 11-20-2015, 08:59 AM
1222
Make mine a Jeep!
1222's Avatar
Neo1130,
Thanks for posting that video, great stuff.
I posted your video in the 2012 and up JK oil filters: Be careful what you buy sticky.
1222 is offline
post #8 of 10 Old 11-20-2015, 01:18 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
So likely the short filter in the long housing allowed the oil pressure to blow the filter shut... sounds like $$$ on the repair.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a hard knock...
jwmbishop is offline
post #9 of 10 Old 11-20-2015, 01:57 PM
JIMBOX
Chances are---that engine won't have to worry about the proper oil filter ANY MORE-
When you run an engine at starved/no flow oil--bearings aren't "fixable", sounds like a total engine replacement--hopefully warranty, but I doubtit-
Good luck
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is online now
post #10 of 10 Old 11-20-2015, 05:13 PM Thread Starter
JTPhoto
Issue started with cam phaser position code and CEL. Dealer couldn't find a problem, as code only appeared at certain times. Code was not stored til the end. Engine is toast.
Thanks guys for the replies.
. Thanks. NM got it just hadnt had the time to watch the whole vid thanks..
^^Jeff^^
JTPhoto is offline
