Cobra 75 WX St Hand Held CB Install - Page 2 - JeepForum.com
post #16 of 55 Old 03-28-2012, 04:59 PM Thread Starter
182329
2009 JK Wrangler
Interesting...they are so different in prices that I thought there had to be some noticeable difference
182329 is offline
post #17 of 55 Old 03-28-2012, 09:13 PM
MrFish
Two of those are a Firestik 2's (FS), one of them is a Firestik Firefly (FL), which is the lighter weight version. Go to Firestik's web site to see more.
The FireRing is just a different way to attach the coax cable to the bottom of the chosen antenna. The FireRing'd cable exits sideways to allow for more mounting options, vs straight down. Some prefer it, some don't. Whichever cable end you choose will determine which style of antenna mounting post you need (standard PL259 jack or bolt+hole). Again, read Firestik's web site for a TON of info.
Regarding the antenna height vs garage, that kinda depends on where you mount it. I used the Cool Tech Ultramount to mount a 4' Firefly to the license plate housing, and it's still about 1" too tall for my garage door. If going for a tailgate mount, 3' is probably as long as you'll be able to go.
You know what a learning experience is? A learning experience is one of those things that says, "You know that thing you just did? Donít do that."
- Douglas Adams
MrFish is offline
post #18 of 55 Old 03-29-2012, 06:31 PM Thread Starter
182329
2009 JK Wrangler
Another good post...thanks for the continued feedback
182329 is offline
post #19 of 55 Old 03-29-2012, 06:54 PM Thread Starter
182329
2009 JK Wrangler
You are certainly right about a ton of info being on their website! I have been looking and was just wondering about something. If I want to hook up the Cobra 75 wx st, then here's everything I (think) I need...please feel free to correct me if I am wrong:
1. FireStik K-8A 18 foot single antenna coax cable (http://www.amazon.com/FireStik-K-8A-single-antenna-cable/dp/B000X3EPCI/ref=wl_it_dp_o_pC?ie=UTF8&coliid=I12MW8J31M2PCV&co lid=ROT6CUDR6D8)
2. Firestix Mini-Kit PL259 Installation (http://www.firestik.com/Tech_Docs/mkpl-instl.htm)
3. Teraflex Mounting Antenna Bracket (http://www.quadratec.com/products/16180_000.htm?sgsc=GOOGLEFGFREEGRND&utm_medium=com pshop&utm_source=googlemerchant)
4. Firestix 3' FS Antenna (http://compare.ebay.com/like/360323428867?var=lv&ltyp=AllFixedPriceItemTypes&va r=sbar&_lwgsi=y&cbt=y)
Well, I think that's about it, right? Is it worth it to also get this spring shock, too? (http://www.amazon.com/SPRING-SHOCK-SS-HD-UP/dp/B00042LC9M/ref=wl_it_dp_o_pC?ie=UTF8&coliid=I1MG0BNUXWRQ6Z&co lid=ROT6CUDR6D8), If so, is there any special way to mount the spring shock?
Once again, thanks for everyone's help. I am getting excited about taking this project on.
182329 is offline
post #20 of 55 Old 03-29-2012, 07:15 PM
MrFish
Personally, I'd opt for the pre-made cable and avoid soldering the end on your own.
IF you go with a PL259-ended cable, you're still missing the antenna stud from your shopping list. The stud is what mates the male-ended antenna to whatever cable end you have snaking out of the tailgate. You'll need a K-4A or similar (not K-4) to connect the antenna to the PL259-ended cable you've chosen:
http://www.firestik.com/Catalog/K-4.htm
If you DON'T want to solder your own PL259 plug on the end of your cable, you can get a pre-made one, but trying to fit one of those big ends through various holes might be an issue. You could instead go for the 2-piece FireRing kit:
http://www.firestik.com/Catalog/MU-8R18.htm
The removable end makes it easier to fit the cable through small openings, then just screw on the larger endcap when you get to the CB location.
If you get the FireRing-ended cable, you'll still need a stud, but the one above is for "regular" coax ends. In this case, you'll need to skip the K-4A antenna stud, and opt for the FireRing-compatible version:
http://www.firestik.com/Catalog/k-4r.htm
In summary: Get your DIY cable and a K-4A stud.
-or-
Get a FireRing cable and its associated stud.
Otherwise, the antenna and Teraflex mount are very popular, you'll be fine.
Then again, one more note: Many folks have had issues getting good SWR readings when using any tailgate mount. The issue is likely that the tailgate hinge isn't solid metal-on-metal, so does not always provide a good ground to the Jeep chassis. The solution is to ground the antenna mount to the tailgate, then the gate to the chassis, though I've seen varying levels of success. You've been forewarned.
- Douglas Adams
MrFish is offline
post #21 of 55 Old 03-29-2012, 07:22 PM Thread Starter
182329
2009 JK Wrangler
Wow...I am humbled once again!
I actually think that I understand everything you said, minus the ground info at the end. My understanding (which is not a very good one!) is that I needed to just hook the positive lead up and then ground the negative lead anywhere else...I figured that I would just ground it to the body inside the engine compartment by the battery. Is this not o.k.?
Thanks
182329 is offline
post #22 of 55 Old 03-29-2012, 07:36 PM
MrFish
Everything I'm spouting off, I learned from the Firestik web site. 2 weeks ago. I've never had a CB before, this is my first. My point being, it's not nearly as complex as it seems now. I was in the same boat as you seem to be, and was <this> close to having a shop install the kit for me.
Now, though, I just look back and laugh. Those were the days.
Ahem, anyway ...
So we're talking about two different grounds here. You're referring to the electrical ground, or the negative power lead for the CB, and you're correct. Red to the battery, black to a nice shiny bolt somewhere on the body or chassis or bracket or something near the CB's control box.
I'm referring to the RF ground for the antenna. If your antenna isn't grounded to the body or chassis or bracket or something near the mount, things no workie. Standing waves, RF reflectivity, smoking CB transmitters, blah blah.
Once you get all the cables hooked up, plug in your trusty SWR meter ($15 from Frys or Radio shack) and check your readings. See http://www.firestik.com/Tech_Docs/Setting_SWR.htm for how and why. If you're in the red after many (many many many) attempts at tuning the antenna tip, you likely need to ground the antenna/mount. There are a ton of threads here about grounding. If you're in the red, do NOT transmit with your radio (see 'smoking' above).
As for the install kit, though, I think you're on the right track.
- Douglas Adams
MrFish is offline
post #23 of 55 Old 04-05-2012, 09:28 PM
JKatfish
Just finished my install. Very simple and located the receptacle under the trim piece passenger side and the junction box behind the panel. No drilling. You can see it peeking out which will be covered with a bit of carpet. I used the complete antenna kit from QT, a bit pricey but had everything included, so it made the install a piece of cake or pie if you like.
JKatfish is offline
post #24 of 55 Old 04-06-2012, 07:12 AM Thread Starter
182329
2009 JK Wrangler
Excellent post...any chance you have a link to the QT antenna kit you were mentioning? Just curious and want to take a look!
BTW, with the junction box behind the passenger panel like that, is there plenty of cord on the hand held Cobra to get over to the driver?
How about the cb mount itself...if you mount that somewhere in the driver's side, does the cord go across the radio, etc, or is there enough slack for it to not be in the way?
Thanks!
182329 is offline
post #25 of 55 Old 04-06-2012, 08:06 AM
SoCalJK
SoCalJK's Avatar
I mounted mine in the same place last weekend. Since I don't remove the handset I didn't worry about actually mounting the connector. Just ran the cable behind the center console and hooked it up and left it there. If I do need to remove it, it is simple just to pull the plastic cover off under the glove box and disconnect.
Plenty of cable to still use the handset from the drivers seat.
2007 Sahara Unlimited
4x4, Auto, Jeep Green, Tow Package, Soft top, 3 inch spring lift, MBRP Catback
SoCalJK is offline
post #26 of 55 Old 04-06-2012, 08:31 AM Thread Starter
182329
2009 JK Wrangler
Cool...Sounds good.
Anyone know of the QT antenna kit that was discussed 2 posts prior? Just curious and want to take a look!
As always, great forum and great feedback
182329 is offline
post #27 of 55 Old 04-06-2012, 08:31 AM Thread Starter
182329
2009 JK Wrangler
Cool...Sounds good.
182329 is offline
post #28 of 55 Old 04-06-2012, 09:14 AM
aristobrat
2010 JK Wrangler
CoolTech also has some complete antenna systems!
aristobrat is offline
post #29 of 55 Old 04-06-2012, 09:25 AM Thread Starter
182329
2009 JK Wrangler
let's get some links going!!! I am interested in these antenna packages
Found one: http://www.cooltechllc.com/jeep/jk_gatemount.shtml
182329 is offline
post #30 of 55 Old 04-06-2012, 09:44 AM
aristobrat
2010 JK Wrangler
If you pick someone else's mounting bracket, CoolTech still offers their antenna wire kit where you don't have to solder the end piece onto the cable.
http://www.cooltechllc.com/jeep/jk_firestik.shtml
cb , cobra 75
Cobra 75 install, where to run wires through firewall gmgreen JK Wrangler Technical Forum 6 10-15-2011 07:40 AM
Cobra 75 module install locations skivviss JK Wrangler Technical Forum 12 08-06-2010 11:10 AM
Cobra 75 Off-Road CB Kit install Stu Olson TJ Wrangler Technical Forum 18 05-16-2008 06:59 AM
LED Taillight install gone bad Held Needed tmwoodall TJ Wrangler Technical Forum 16 02-08-2008 08:13 AM
Hand held CB or in dash? ravenfan TJ Wrangler Technical Forum 13 02-22-2003 01:37 PM
