Cobra 75 WX St Hand Held CB Install - JeepForum.com
post #1 of 55 Old 03-28-2012, 09:47 AM Thread Starter
jehnmg
2009 JK Wrangler
Hello All,
I need some help guiding me on the install. I have never done an install before, especially electrics.
Therefore, I have some q's:
1. How do you run the wires to the batery through the firewall? Are there openings in it already, or do I need to drill (got any pics?)?
2. Are there any special instructions when hooking it up to the battery (ground, etc.)?
3. Right now I only have the Cobra 75 WX ST and the parts that came in the packaging. What else will I need to hook it up with a firestix antenna? Wiring? Mounting bracket? Quick Release?
4. I garage the Jeep, and there is not much room when I drive under the door. So I do not think that a 4' firestix will cut it, as it will be too high and prevent me from parking every night. I know that you can buy magnet antennas, but I was hoping to maybe use a 3' firestix with a disconnect to remove it when I garage the Jeep. Any ideas on the disconnect system or other alternatives?
Bascially, I am looking for a parts list and a "how to," especially regarding the garage issue.
As always, thanks for everyone's help.
Teraflex 2.5" Coil & Shock lift, fr. lower control arms,
Gdyr 35x12.5r15, P.Comp 1069's...
Skids- Sway Bar, c. arms, s.mounts, oil pan, evap. cannister, EVO C2 front axle Gussets...
jehnmg is offline
post #2 of 55 Old 03-28-2012, 10:45 AM
SoCalJK
SoCalJK's Avatar
Assuming that nothing changed between 2007 and 2009 there should be a hole through the firewall on the left under the dash. Can be accessed by removing the panel on the side of the dash. You can also see it from under the hood. It is about 1.5" diameter and covered with the silver insulation. Just take a screwdriver etc and poke a hole through it.
You'll need to either buy or manufacture a mount for the antennae and also purchase the actual mount fitting and 18' of co-ax. I just made an L-shaped bracket that I mounted to the spare tire mount. Easy to route the cable from there through the same place where the 3rd brake light is routed.
Once fitted you will have to get someone to calibrate the antennae. Don't think there are any quick disconnects for the antennae. I just unscrew the actual Firestick from the mount when I need to.
2007 Sahara Unlimited
4x4, Auto, Jeep Green, Tow Package, Soft top, 3 inch spring lift, MBRP Catback
SoCalJK is offline
post #3 of 55 Old 03-28-2012, 11:29 AM
smcutter
First off, some links to help you out on ideas and how-to's:
Great Photo-Only Walkthrough
Nice looking (but poorly written) installation notes
This is probably the best-looking installation I have seen. If possible, you should make sure that whatever instructions you follow will get you to this end result. I found this photo here.
As for the antenna, I would highly recommend the Teraflex antenna mount. Installation is relatively easy (especially if you are willing to drill through your tailgate) and it should be noted that you don't have to mount it on the upper right side of your spare tire mount. You can also mount it upside down on the bottom left of your spare tire mount, which has the effect of lowering your mounting point by about a foot. Combine that with a 3' antenna and I'm fairly confident that you won't have any problems with the garage.
For the record, I'm probably judging you for your bad grammar or spelling.
smcutter is offline
post #4 of 55 Old 03-28-2012, 11:42 AM
smcutter
1. You will only need to run a positive wire into the engine bay. As stated above, there are pre-existing routing holes that you will need to find. The one I used is explained in this write-up, but there are several others that will work just fine. I prefer the one on the passenger side because it put my right next to my battery (but I'm not sure which side the battery is on in your Jeep).
2. You'll only need to connect the negative lead to the body or frame somewhere. I connected the positive lead using a solderless ring connector (example below).
3. Don't go with a quick release. Instead, use a Teraflex antenna mount flipped upside down and a 3' Firestik. You should be fine. You'll also need an 18' length of coax cable. All of your coax ends should be PL-259 connectors.
4. When wiring a CB, it's best to keep the wiring simple. The more components you have, the worse your signal will be. You will need to get an SWR Meter to make sure you can tune your CB, otherwise you risk damaging the unit if your SWR is way out of wack. http://www.amazon.com/METER-Radio-Antennas-Jumper-cable/dp/B002KRME3C/ the one I bought and it works well with no frills.
smcutter is offline
post #5 of 55 Old 03-28-2012, 12:17 PM Thread Starter
jehnmg
2009 JK Wrangler
A ton of info...thank you for all the responses.
You all are a tremendous help
jehnmg is offline
post #6 of 55 Old 03-28-2012, 01:15 PM
SoCalJK
SoCalJK's Avatar
Only issue I see with mounting the antennae so that it doesn't protrude above the roof is loss of power. With the antennae low down your range is going to be shorter. Probably OK if you are only looking to talk to buddies in your convoy.
SoCalJK is offline
post #7 of 55 Old 03-28-2012, 01:44 PM
goldenglory18
For the routing of the wires, I've been using a second hole in the firewall boot that is down in the foot well of the passenger side (It's hard to get to and well hidden. Stretch well before attempting to go though here... LOL ) It's a pretty big boot, and on the inside, I've made quite a mess of it. At some point (probably once I'm done installing all my extra electronic goodies) I'll make an attempt to seal it back up with some heavy electrical tape.
Gone and I dont miss it at all - 2011 JKU
goldenglory18 is offline
post #8 of 55 Old 03-28-2012, 03:10 PM
Spank
2014 JK Wrangler
Originally Posted by smcutter View Post
Although this looks nice and clean, it's ultimately unnecessary and you're just drilling a hole in dash parts.
Stick the cord underneath the ends of the center console and have it come out the bottom, like this:
'14 Wrangler Unlimited Rubicon
Spank is offline
post #9 of 55 Old 03-28-2012, 03:57 PM Thread Starter
jehnmg
2009 JK Wrangler
I'm not following you...what exactly do you mean?
Thanks!
jehnmg is offline
post #10 of 55 Old 03-28-2012, 04:08 PM
smcutter
Thanks!
He's saying that the method I suggested requires drilling part of your dash (which is expensive to replace). His alternative simply means routing the wire through holes that already exist.
smcutter is offline
post #11 of 55 Old 03-28-2012, 05:14 PM Thread Starter
jehnmg
2009 JK Wrangler
In researching the Coax cable, I found one that comes with a "fire ring." Is this what I need? What's the purpose of the "fire ring?"
http://www.amazon.com/FireStik-K-8R18-Fire-Flex-cable-Fire-Ring/dp/B000X3C8L8
or, do I need this one:
http://www.amazon.com/FireStik-K-8A-single-antenna-cable/dp/B000X3EPCI/ref=pd_sim_e_6
jehnmg is offline
post #12 of 55 Old 03-28-2012, 05:16 PM
JKatfish
Has anybody spliced into the power outlet in the glovebox? Should be doable since almost same as using a CLA.
JKatfish is offline
post #13 of 55 Old 03-28-2012, 05:21 PM
SoCalJK
SoCalJK's Avatar
http://www.amazon.com/FireStik-K-8A-...ref=pd_sim_e_6
No idea what the fire ring is. You want one that has the connector mounted at one end and the other connector (same as the one mounted) supplied for you to fit. This allows for easy routing of the cable. Both connectors should be the same.
SoCalJK is offline
post #14 of 55 Old 03-28-2012, 05:29 PM Thread Starter
jehnmg
2009 JK Wrangler
Got another one for everyone. It seems as if there are a number of different firestix 3' antennas. Are all antennas treated equally?
I attached a few links to check out:
Option 1:
http://www.amazon.com/FireStik-FL3-B-FireFly-Antenna-Tuneable/dp/B000UUNHJG/ref=sr_1_sc_1?ie=UTF8&qid=1332973579&sr=8-1-spell
Option 2:
http://www.amazon.com/Firestik-Series-Tunable-Antenna-Watts/dp/B00317EJ0Q/ref=sr_1_sc_2?ie=UTF8&qid=1332973579&sr=8-2-spell
Option 3:
http://www.amazon.com/FIRESTICK-II-TUNABLE-TIP-BLACK/dp/B000WYYP14/ref=sr_1_sc_3?ie=UTF8&qid=1332973579&sr=8-3-spell
jehnmg is offline
post #15 of 55 Old 03-28-2012, 05:54 PM
SoCalJK
SoCalJK's Avatar
I think they are all the same, just different vendors. You choose your color.
SoCalJK is offline
cb , cobra 75
Cobra 75 install, where to run wires through firewall gmgreen JK Wrangler Technical Forum 6 10-15-2011 08:40 AM
Cobra 75 module install locations skivviss JK Wrangler Technical Forum 12 08-06-2010 12:10 PM
Cobra 75 Off-Road CB Kit install Stu Olson TJ Wrangler Technical Forum 18 05-16-2008 07:59 AM
LED Taillight install gone bad Held Needed tmwoodall TJ Wrangler Technical Forum 16 02-08-2008 09:13 AM
Hand held CB or in dash? ravenfan TJ Wrangler Technical Forum 13 02-22-2003 02:37 PM
