Clutch Safety Sensor 2014 Rubicon - JeepForum.com
post #1 of 3 Old 01-13-2014, 06:57 PM Thread Starter
jksull
Any one figure out how to wire the Clutch Safety sensor so it can be started with out pushing the clutch to the floor?
I have found several threads but nothing matches the sensor / Switch? I see on
the 14.
jksull is offline
post #2 of 3 Old 01-13-2014, 06:59 PM
ncb
Originally Posted by jksull
Any one figure out how to wire the Clutch Safety sensor so it can be started with out pushing the clutch to the floor? I have found several threads but nothing matches the sensor / Switch? I see on the 14.
I haven't seen it done, but in 4lo the switch is automatically bypassed.
ncb is offline
post #3 of 3 Old 01-16-2014, 06:12 PM Thread Starter
jksull
Bringing this back to the top, I am still looking for someone who may have made this change on a more recent JK.
I found this from another forum.
http://www.jkowners.com/forum/showthread.php?t=45722
Yes. There are three wires to the switch(located at the master cylendar). 1-??-Cruise, 2-Yellow/Orange-start interlock, 3-Black-ground.
If you ground the yellow/orange wire the PCM will always think the clutch is pressed in and it will defeat the system. HOWEVER, I am finding mixed info on whether the cruise really uses pin 1 or if it uses pin 2 along with the starter override, so it's possible by doing this your cruise will no longer work. Wouldn't hurt to try.
jksull is offline
