Clearing 33's on Jeep - JeepForum.com
post #1 of 9 Old 12-23-2011, 07:30 AM Thread Starter
beeharring
I am working on a truck and the owner is looking to get 33's on the jeep. It is a 2010 with 18 inch rims from a Stock Sahara. The tires I have measured now are about 31.5 inches. Am I gonna be able to get the 33's on or am I gonna have to get a different rim offset or a lift?
Thanks for any help.
beeharring is offline
post #2 of 9 Old 12-23-2011, 07:35 AM
Jowlz
Tough call. 33's rubbed on the sway bar on full turn for me, but some people report no rubbing. Rims with less backspacing (4.5") or a set of spidertrax spacers will cure any rubbing... No lift needed for 33's...
Jowlz is offline
post #3 of 9 Old 12-23-2011, 08:54 AM
8figgas
275-70-18 w/1.25" spacers
Tires=33.4"
No Rubbing
And if you still get slight rubbing, shorten the steering a tad.
Just because you bought every bolt-on accessory available for your jeep, doesn't mean you know WTH your doing or talking about...
8figgas is offline
post #4 of 9 Old 12-23-2011, 09:11 AM
ALKNOPE
2011 JK Wrangler
i have 285/70/17 duratracs on my 2011 JKU the rims i got have 4.5 backspacing and there is no rubbing issue.
You will need spacers or a rims with 4.5 backspacing.
ALKNOPE is offline
post #5 of 9 Old 12-23-2011, 10:30 AM
jrmandryck
BS on the rims?
I have 285/75/R16's 4.5 BS no issues
truth is so precious that she should always be attended by a bodyguard of lies...
jrmandryck is offline
post #6 of 9 Old 04-07-2012, 12:07 PM
redbull86
Tires=33.4"
No Rubbing
Do you have any lift or just the wheel spacers?
redbull86 is offline
post #7 of 9 Old 04-07-2012, 12:25 PM
Mol
Disclaimer: I'm Polish
Mol's Avatar
No lift necessary - lesser backspacing will probably be needed if the tread width is greater than 11"
Mol is offline
post #8 of 9 Old 04-07-2012, 03:51 PM
8figgas
Now I hv a leveling kit and Rubi take offs
8figgas is offline
post #9 of 9 Old 04-07-2012, 08:33 PM
2007UnlimitedNJ
I have GY Duratracs 275/70/18 on my Sahara. I went with 1.5in spacer kit to get rid of the rub on my sway bar and had to trim the plastic skid piece under the front bumper.
I have a 2in lift kit, but others say it's not needed.... If you go offroad, I personally think you could hit the flares without a little lift. My personal hypothesis.
2007UnlimitedNJ is offline
jeep , lift , offset , sahara , tires
need help with tj clearing 35s dhornesjeep TJ Wrangler Technical Forum 22 09-07-2011 01:53 PM
Clearing PCM.. Lakeray TJ Wrangler Technical Forum 6 07-12-2010 01:39 PM
Clearing 33's BlueTJ28 TJ Wrangler Technical Forum 3 12-15-2008 03:55 AM
Need some help clearing 32,s vinsonrider TJ Wrangler Technical Forum 28 08-19-2007 02:47 PM
Clearing 33s? MichiganTJ TJ Wrangler Technical Forum 7 10-10-2002 10:49 AM
