Ck engine light - JeepForum.com
post #1 of 17 Old 11-24-2013, 06:47 PM Thread Starter
moemoe88
Ck engine light
Came on at 7000 miles on my 2013 Wrangler. Reset myself twice because I thought it was the gas cap, it started first start after fillup. Had to go the dealers they said it is my oil pressure sending unit. I asked if they were absolutely sure, they said yes. Had to order the part. Plenum needs to be pulled for that. I really don't like the idea of them pulling it apart. Any comments/suggestions will be appreciated.
moemoe88 is offline
post #2 of 17 Old 11-24-2013, 07:30 PM
ronjenx
ronjenx's Avatar
What was the code it set?
ronjenx is online now
post #3 of 17 Old 11-24-2013, 09:09 PM Thread Starter
moemoe88
Let's see on my receipt it says cause 100 engine 141
Does that sound like it or I don't know and didn't ask.
moemoe88 is offline
post #4 of 17 Old 11-24-2013, 09:20 PM
ronjenx
ronjenx's Avatar
It would be a P code, such as P06DD
post #5 of 17 Old 11-24-2013, 11:52 PM Thread Starter
moemoe88
It's not anywhere on the receipt.
moemoe88 is offline
post #6 of 17 Old 11-25-2013, 10:52 AM
COLOUXJ
2010 JK Wrangler
Why are you worried about them fixing it? You will pay for someone else to do it.
COLOUXJ is offline
post #7 of 17 Old 11-25-2013, 04:14 PM Thread Starter
moemoe88
p0520 from AutoZone
Not real worried about them fixing it, more worried that it is the problem and not something else
moemoe88 is offline
post #8 of 17 Old 11-25-2013, 04:22 PM
COLOUXJ
2010 JK Wrangler
Do you mean P0522? Im not seeing a P0520
COLOUXJ is offline
post #9 of 17 Old 11-25-2013, 04:40 PM
psychoteen101
2013 wrangler with less than 10,000 miles is under warranty. No sense in paying someone to diagnose it, dealer will fix it for free. Bring it back to them until its fixed.
1996 Jeep Cherokee- Project-- Rusty's 8in long arm, SYE kit, Teraflex driveshaft, Cragar soft 8's 15x10 with 33x12.5 Firestone Destination MT's, Eaton Tru Trac in the front
psychoteen101 is offline
post #10 of 17 Old 11-25-2013, 04:42 PM
COLOUXJ
2010 JK Wrangler
And if it is P0522 Then thats low oil pressure, which probably mean that the sending unit is bad or you're running low on oil.
COLOUXJ is offline
post #11 of 17 Old 11-25-2013, 05:05 PM Thread Starter
moemoe88
Yes AutoZone is general and has about 6 or 7 possibilities for the cause including the sensor, oil pressure, etc.
Of coarse I am having the dealer fix it under warranty, just bugs me that they have to take so much of it apart with it being so simple.
moemoe88 is offline
post #12 of 17 Old 11-25-2013, 07:45 PM
ronjenx
ronjenx's Avatar
Originally Posted by moemoe88 View Post
p0520 from AutoZone
P0520-ENGINE OIL PRESSURE SENSOR CIRCUIT
When Monitored: Ignition on, engine not running.
Set Condition: The Powertrain Control Module (PCM) senses the oil pressure is out of the calibrated range. One Trip fault.
NOTE: Make sure that the engine oil is at the proper level. Also, review the customers oil change history to ensure that the oil is being changed at the correct intervals and that the proper oil viscosity is being used.
Possible Causes
ENGINE OIL PRESSURE SENSOR SIGNAL CIRCUIT SHORTED TO VOLTAGE
EXCESSIVE RESISTANCE IN THE (G6) ENGINE OIL PRESSURE SIGNAL CIRCUIT
ENGINE OIL PRESSURE SIGNAL CIRCUIT SHORTED TO GROUND
EXCESSIVE RESISTANCE IN THE (F855) 5-VOLT SUPPLY CIRCUIT
5-VOLT SUPPLY SHORTED TO GROUND
EXCESSIVE RESISTANCE IN THE (K900) SENSOR GROUND CIRCUIT
POWERTRAIN CONTROL MODULE (PCM)
post #13 of 17 Old 11-26-2013, 08:51 AM Thread Starter
moemoe88
I changed the oil at 6000 miles, put 5-30 in it. I guess it called for 5-20. Wonder if that is an issue. I have been checking the web and there seem to be some issues with this function, including the oil pump. That's the kind of stuff that worry's me.
moemoe88 is offline
post #14 of 17 Old 11-26-2013, 12:08 PM
Jiblet
People run 0w-40 without problems.
Jiblet is offline
post #15 of 17 Old 11-26-2013, 12:52 PM
psychoteen101
Bring it back to the dealer. If its still under warranty and you or another shop messes with it, they can void the warranty. Make sure they verify with a mechanical gauge the oil pressure is within specification.
