Cig lighter and ignition - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Cig lighter and ignition
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectJKS Now Available at www.baseline4x4.com, Trackbars, SkidsFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 05-24-2014, 11:35 AM   #1
TWISTEDII
Got a weird issue here. My 10 amp fuse for my drivers side cig outlet was blown. I finally put a new fuse in and my Jeep wouldn't start. Took it out, started right up. Now it's hit or miss with it in. Is this pointing to an electrical nightmare?
TWISTEDII's Build Thread
TWISTEDII is offline   Reply With Quote
Unread 05-24-2014, 12:17 PM   #2
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Well, why did the original fuse blow? Maybe there is a low resistance short.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote
Unread 05-24-2014, 12:20 PM   #3
TWISTEDII
No idea, just stopped one day. Think it might have been an old power inverter I was using.
Unread 05-24-2014, 01:50 PM   #4
Jiblet
Not sure about the jk but I recall some cars have the ECM on the same circuit as the cig lighter/accessories. Something to do with reading the obd2. Can't recall the relationship. This ring any bells, anybody??
Jiblet is offline   Reply With Quote
Unread 05-24-2014, 08:08 PM   #5
ronjenx
ronjenx's Avatar
Both power outlets should have 20 amp fuses. Are you sure you are dealing with fuse M6?
Also, make sure the power feed on the lug in the lower right of the picture is tight.
ronjenx is offline   Reply With Quote
Unread 06-02-2014, 04:44 PM   #6
TWISTEDII
That is the fuse that was bad, it was the outlet on the right. But I don't think it was M6, and it was a 10 amp fuse. I will check the power feed lug as well. I will also try and check to see what my fuse box says that fuse number is. It has started every time since posting this, so I am not sure what the issue was. The outlet still works too. It was so bizarre.
Unread 08-05-2014, 08:31 AM   #7
TWISTEDII
Still having this issue. Jeep would not start this morning. Tried over and over. Pulled fuse M36, unplugged the phone charger from the right 12v power outlet, and the Jeep started right up.
