Chirping Sound in the Rear... Bad wheel bearing? - JeepForum.com
post #1 of 17 Old 03-31-2015, 04:23 PM Thread Starter
ciphershort
2009 JK Wrangler
Hello all,
I've had a chirping sound for quite some time but it comes and goes. Well now its back and it sounds like a freaking bird chirping when I'm coasting, braking, and sometimes accelerating. Brake system looks good. The sound does slightly change when mildly braking. I'm thinking it may be a bad wheel bearing as it sounds like its from my rear drivers side wheel. Question is...how do I confirm? I know if its a bad hub/bearing up front, you can jack the vehicle up and see if your wheel moves on the hub but I doubt this is a valid test for the rear. Any ideas would be greatly welcome.
Thanks!
ciphershort is offline
post #2 of 17 Old 03-31-2015, 04:32 PM
goodwrenchdave
check your u-joints for seizing. most likely that is the chirp. remove the driveshaft (easy) and check articulation.
goodwrenchdave is offline
post #3 of 17 Old 03-31-2015, 04:34 PM
JeepersDigest
If one is capable of removing the rotors.. they might noticed a build up of mud etc in the drum part within the rotor. This drum part/area is there for the Emergency brake.. if left unclean or unchecked (routinely) the buildup of mud and debris can force the e-brake to lock up and disintegrate the brake pads completely. Remove the rotors, clean the area and grease the e-brake cable.
JeepersDigest is offline
post #4 of 17 Old 03-31-2015, 04:43 PM
goodwrenchdave
Yes the e-brake shoes rubbing is a possibility and very easy to check first... almost forgot . slightly pull on it while slowly rolling and see if the sound goes away. No need to remove all right away
post #5 of 17 Old 03-31-2015, 04:52 PM
JeepersDigest
goodwrenchdave, NP.. in our case.. the rear brake pads were completely gone, reduced to a leaf, and once the caliper was removed, the pad (or what was left of them) simply floated to the ground..
post #6 of 17 Old 04-01-2015, 10:14 AM Thread Starter
ciphershort
2009 JK Wrangler
Sound doesn't change when applying the e-brake. I had that thought last week and tried it. I've had someone hang out the back of the Jeep while the sound was being made and they confirmed that it is definitely coming from the driver's side rear wheel. I'll see if I can take the rotor off and see if its dirty though.
post #7 of 17 Old 04-01-2015, 02:00 PM
Neo1130
2015 JK Wrangler
Mine was a loose shock bolt. Check them by hand...
Neo1130 is offline
post #8 of 17 Old 04-01-2015, 08:15 PM
Neo1130
2015 JK Wrangler
Or rock the jeep from side to side with a friend...
Neo1130 is offline
post #9 of 17 Old 04-01-2015, 08:32 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Best way is by wrench...
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is online now
post #10 of 17 Old 04-01-2015, 08:42 PM
Neo1130
2015 JK Wrangler
Applying a wrench would be a way to fix. I was giving a no doubt to troubleshooting...
Neo1130 is offline
post #11 of 17 Old 04-02-2015, 07:37 AM Thread Starter
ciphershort
2009 JK Wrangler
thanks for all the help guys. rocking the jeep back and forth doesn't make the sound. shock bolts are tight as well. its only when the wheel is spinning. it really starts going off in the 30-40mph range on a flat straight road maintaining a constant speed. seems to be something circular as it happens at a certain point of the revolution of the tire for example when driving faster the chirps are closer together and when driving slower the chirps are farther apart if that makes sense.
post #12 of 17 Old 04-02-2015, 01:34 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Well yes - but if you knew what a wrench party was...
It when the race crew gathers one last time pre race and every one gets a wrench. Then makes sure every damn bolt matching their wrench on the car is tight. That's really the ONLY way to know...
I was jus being facetious...
post #13 of 17 Old 04-02-2015, 01:51 PM
romank
2014 WK
If those are disks and not drums it should be the metal tang that alerts you to the pads getting near replacement time. Easy test is lift the rear, chock off at least 2 of the other wheels, put in neutral and spin that tire. If you hear it then it's not the driveshaft and doubtful it's a bearing. Bearings tend to growl more than chirp. Odd because the fronts typically go first but.........
romank is offline
post #14 of 17 Old 04-02-2015, 03:42 PM Thread Starter
ciphershort
2009 JK Wrangler
They are disks. I checked the pads a while back and they still had plenty left. The only thing that has me thinking it isn't the brakes is I hear the chirp even when I'm not braking. Plus, brake pad squealers usually make a constant noise (not a chirp) since it is the metal in the pads making contact with the rotor.
post #15 of 17 Old 04-02-2015, 03:56 PM
Kiwi Jeeper
I had harmonic chirping like that from the right rear wheel recently. I took off the brakes and cleaned everything really well. Then greased the slid pins. Noise is gone for now.
One shop said my wheel bearings were gone. Another shop said disc was out of round or warped. I tried the simplest way first before spending money. For me it was a noise that went away when brakes were fully applied. No shudder or growling.
'12 JK Rubicon V6 3.6L
'15 KL Trailhawk V6 3.2L
Kiwi Jeeper is offline
