Chevy 6.2L in a JK - Page 4 - JeepForum.com
post #46 of 60 Old 09-22-2013, 08:36 PM Thread Starter
JohnPShoe
Sorry I haven't posted in a while, life tends to get in the way. The Jeep has been good. The swap was definately worth it! The power is nice. Currently, I have the body and frame separated again. I am making a few changes to a couple of things and checking on how well everything has performed for the last 10k miles. I will post back when i get it back together.
2008 Stone White Unlimited Rubicon, 400+HP 6.2L LS Motech special
JohnPShoe is offline
post #47 of 60 Old 06-27-2014, 01:37 PM
gbanker
2014 JK Wrangler
Current status?
Wondering if the changes were needed due to the engine, etc. install and can we get an update as to how the last 10K went?
Thanks
gbanker is offline
post #48 of 60 Old 08-10-2014, 10:42 AM
69mach1
5.3 or 6.2?
Checking for status update, satisfaction, mpg, and mods you've added since I'm on the fence 5.3 or 6.2 my JK 4dr is portly and will have trailer duties towing an Rpod trailer now and again. Any advice would be appreciated
69mach1 is offline
post #49 of 60 Old 08-10-2014, 07:27 PM Thread Starter
JohnPShoe
Hey guys, sorry I haven't logged on in a while.
gbanker......The Jeep is doing well. No major changes when I took it apart, just a few tweaks. We've got about 18k on it since the swap and it is driven everywhere. It's been to Destin twice(6hr trip), to Little Rock once(7hr trip), and all over locally. The wife loves it! She told me again the other day that I hit the nail on the head.
69mach1.....I have not driven the 5.3 in a Jeep, but the wife's Suburban has one. I think the 5.3 would be great, but I prefer the 6.2. The power is awesome, definately more than the Sub, but the Jeep is also probably 3500lbs lighter. Mileage is not what I hoped it would be, but i'm sure that it is proportional to it spending most of it's time on the interstate at 75mph. I'm spending a lot of time on a custom tune right now trying to get everything perfect. Before I finish, I will spend a little time on trying to improve mileage.
post #50 of 60 Old 08-10-2014, 08:15 PM
goodwrenchdave
What I've always wondered is if the stability control, ABS, traction control work flawlessly or even work at all. Lets not get into a debate as to the usefulness or personal opinions of such systems!
How effective is the 2way intercommunication between the GMLAN, and the Chrysler Cbus then to the -TIPM (translator to the) I bus? I assume mo-tech or whomever builds an "interface" so one can speak to the other? Nothing ever seems to be spoken about these systems.
goodwrenchdave is offline
post #51 of 60 Old 08-10-2014, 09:20 PM
VEGASROBBI
All ESP active braking functions remain active; this includes anti-lock brakes ABS, electronic roll mitigation ERM, Hill start, trailer sway control TSC, brake locking differentials, brake assisted steering and more. Torque management is not functional through the Jeep side, the ABS module cannot command the PCM too reduce power. The GM side has it's own torque management for axle protection, anti clunk, etc. Your JK operates in the same mode as pushing the ESP button.
For an additional cost we can fit an adjustable TC that allows torque reduction that won't get you into trouble by cutting engine power in a precarious situation like the OEJK system. Dirt track racers use a similar TC to go faster.
As far as the effectiveness of the integration I would say it is excellent. We manufacturer our own electronics, hardware, software and firmware. Properly done it's difficult to tell a swap has been done. The factory cruise control, HVAC controls, instruments, etc all work as intended by Jeep.
MoTech
LS Specialists
500 South Buffalo Drive, Las Vegas NV 89145 702-491-7710
www.LSWrangler.com
VEGASROBBI is offline
post #52 of 60 Old 08-10-2014, 09:35 PM Thread Starter
JohnPShoe
What he said!
You beat me to the punch.
post #53 of 60 Old 09-11-2014, 10:41 PM
69mach1
Thanks for touching base Still researching by options while I save for this swap. What radiator did you use? I'm going to be pulling a 3000lb camping trailer and want to be sure of no overheating issues. I'm running 37" Nitto Trail Grapplers w/5:13 gears. I didn't notice what tire/gears you're running. Is the mpg @ 75 ~15mpg ish? I'm hoping for 17mpg @ 70 without a trailer hanging on the back Any other helpful hints on this swap, Motech seems to be the path I'm taking once the $ appear
Thanks for you response,
Jon aka 69Mach1
69mach1 is offline
post #54 of 60 Old 01-30-2015, 07:31 PM
Bbeyer
Nice Work, man. I work at a shop that is doing one of these (with motec parts, and a 6.2). The motec guys are great, but they told us that they dont really offer an "install guide".. they just shipped us a box full of brackets and things... I figured Id find someone on the board here that has done this swap and learn from their posts. I havent had the time yet to look through all of your thread here but I will check it out.
Here are some pics of the jeep we have. We know this JK inside and out. We did a clayton longarm kit, a Ripp supercharger, rock sliders, bumpers, onboard air compressor, Pro rock 44 front.. regearing etc..
and then the guy wanted to go bigger so he bought 40" tires, pro rock dana 80's, and took it to clayton for the coil over suspension stuff (hes got that slick throwdown rear setup, too)
Now hes in need of more power. On top of that, his tranny toasted from the heat recently. We had a temp gauge on the dash for the trans, with a thermostatic switch controlling a tranny cooler we mounted behind the radiator. that wasnt enough so another cooler got mounted inside the jeep in the back with a fan on it... (someone else installed that) He still fried the tranny.. I think the 40's are just too much for it..
So he ordered a 6.2 with an auto trans, were gonna bolt an atlas tcase to that.. and we have the Motec swap parts.. We already sent the cluster and harness, etc to them.
Hopefully the knowledgable JK community here can guide us along on this swap. Thanks guys
Bbeyer is offline
post #55 of 60 Old 01-31-2015, 05:26 AM
JLH
Not to turn this into a 5.3L vs 6.2L debate, but obviously the 5.3L will return better MPG numbers than the 6.2L. With the 6L80's 0.667 overdrive the 5.3L should pull down 20 MPG going down the highway.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
JLH is offline
post #56 of 60 Old 01-31-2015, 06:08 AM
Prot
Prot's Avatar
2014 JK Wrangler
It is comical that fuel economy enters the equation when doing such an expensive modification to a Jeep, a modification whose sole purpose is more power I might add.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #57 of 60 Old 01-31-2015, 09:46 AM
222Doc
222Doc's Avatar
what is comical is that it gets as good mpg as the pentatick
222Doc is online now
post #58 of 60 Old 01-31-2015, 12:38 PM
JLH
A vehicle's maximum fuel range is not comical. Get stranded out in BFE and see how much you laugh about your MPG.
JLH is offline
post #59 of 60 Old 01-31-2015, 02:12 PM
pgottwig
John, this is almost EXACTLY what I'm planning to do once I get the fam moved out to S California this spring! Great info and thanks for the heads up on Dahmer Power. Just so I don't mis-quote...You purchased the L92/6L80 combo from Dahmer (great deal btw) and then the Motech Basic Kit to ease the install? How are you liking the paddle shifters? I'm still on the fence about them, but cruise is always nice getting to and from the dirt. Nice job...any pics of everything completed?
pgottwig is offline
post #60 of 60 Old 09-07-2015, 01:18 PM
BORDERBUM
Any new info on this install?
BORDERBUM is offline
OMG!!! Saw an 07 4dr with a Chevy 6.0L 07BlackOps JK Wrangler Technical Forum 19 03-13-2011 11:25 AM
05 TJ looking for d60 and chevy 14b 2005X TJ Wrangler Technical Forum 4 03-28-2008 05:23 PM
89 2.5 ax5 to chevy 350? magoo1019 YJ Wrangler Technical Forum 1 01-01-2008 03:15 PM
Chevy 350 W/ Chevy Tranny - Will It Work??? I8JPB4U YJ Wrangler Technical Forum 5 09-16-2004 11:53 PM
4.0L or Chevy 350 SC PuddleJumper YJ Wrangler Technical Forum 2 12-29-2003 01:47 PM
