Chevy 6.2L in a JK - Page 2 - JeepForum.com
post #16 of 60 Old 01-19-2012, 08:17 PM
DrHolliday
2011 JK Wrangler
Looking forward to seeing more of this... I happen to have access to a couple spare LS motors, now I'm thinking even more about it.
2011 JK Rubicon 2 door 6-speed manual, 3.5" Rock Krawler Suspension lift, 1.25" Daystar body lift, 40x13.50R17 Nitto Mud Grapplers
DrHolliday is offline
post #17 of 60 Old 01-20-2012, 07:55 AM
TheBoss
Subscribed!
Wow the best of both worlds a Jeep with proven Chevrolet reliability and performance.
TheBoss is offline
post #18 of 60 Old 01-20-2012, 08:45 AM
h20squirter
not gonna lie, when i first opened up this thread my initial thoughts were, why on earth would anyone want to swap a crappy old 6.2L Chevy diesel into a JK, then i realized you were talking about the newer LS series gas motor, i was relieved to say the least, haha. looks like a great build, i need a new career. I see people on these forums doing bad *** builds and dropping $$$ like its pocket lint and gotta say, I'm jealous, but in a good way. great looking build, i'm subscribed.
2012 JKU Black, Soft Top. Next mods are a 2.5" lift, 35" Tires, and either 4.10 or 4.56 gears.
h20squirter is offline
post #19 of 60 Old 01-20-2012, 07:54 PM Thread Starter
JohnPShoe
I am thinking of starting another thread....I think I'll call it "help a brother dig up a little extra lint for a good cause!". Just kidding. Truth be told, I have been saving for this for almost four years. I've actually owned two hemis that were supposed to go in. I had a 5.7 and a 6.1.
2008 Stone White Unlimited Rubicon, 400+HP 6.2L LS Motech special
JohnPShoe is offline
post #20 of 60 Old 01-20-2012, 09:25 PM
SoK66
2009 JK Wrangler
Matter of time before these became more common. The hemi cost is somewhat over the top, this looks much more reasonable if it can be pulled off somewhat turn key.
SoK66 is offline
post #21 of 60 Old 01-21-2012, 07:59 AM
fmfa0801
2009 JK Wrangler
I just got rid of a 07 Escalade ESV AWD with this same motor. It has ALOT of power and I was getting 17-21 MPG in that pig. You should get the same or better MPGs being a smaller light vehicle. I will be following along!
fmfa0801 is offline
post #22 of 60 Old 01-21-2012, 02:27 PM
h20squirter
Haha. Right on man. Yeah after reading this and doing some research I'm thinking in 3-4 years doing this same swap into a used JKU. I'm a Chevy guy at heart, and I think the Hemi swaps are overrated and over priced. Still don't know why Jeep doesn't offer a factory V8 option.
post #23 of 60 Old 01-21-2012, 07:39 PM
Rudinater
2009 JK Wrangler
Chevy with out the OnStar and daytime running lights
Not sure why the Rubicon transfer case wont work but the non Rubicon transfer case will.
Not sure I would want to give up the 4:1 low.
Thanks
Rudy Ackerman
In Oregon for now
Red 09 Unlimited Rubicon - Teraflex 4inch long arm lift, Elka shocks, 5:38 gears, 37inch GY MTR's, Expedition Core front bumper with Warn PowerPlant HD, RS-E rear bumper and carrier, RS-E step rock sliders.
Rudinater is offline
post #24 of 60 Old 01-21-2012, 07:41 PM
Millermagic
Going to be honest ... I was kind of hoping for a 6.2 diesel haha.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #25 of 60 Old 01-21-2012, 07:54 PM
DrHolliday
2011 JK Wrangler
If I total my truck I'll cannibalize it and you'll see a 6.6 Duramax in a JK
post #26 of 60 Old 01-30-2012, 08:25 PM Thread Starter
JohnPShoe
Just a little update.....I have finally finished fabricating the exhaust!! I have sent the manifolds out to be coated, and I hope they make it back before the weekend. The exhaust is broke down right now. Once I get it all back together I'll post some pics. It looks good. I am also in the process of tightening up all of the loose ends that need to be done prior to putting the body back on. I'm actually getting close, but I want to control myself and do everything while it is easy to access. More info later.
post #27 of 60 Old 01-30-2012, 10:10 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Great looking build John
I want more ponies some day!
For those that are questioning the J/F Rules of posting; you are welcome to post links to any sources you wish as long as it is not advertising for your own benefit or blatant spam
Information is the reason we are all here and if you have it share it
Jim
JLC08JK is offline
post #28 of 60 Old 01-30-2012, 10:13 PM
VEGASROBBI
Your doing a great job John, all your attention to detail will pay off. The LS 6.2 is awesome on and off road; here's a picture to give you something to look forward too.
MoTech
LS Specialists
500 South Buffalo Drive, Las Vegas NV 89145 702-491-7710
www.LSWrangler.com
VEGASROBBI is offline
post #29 of 60 Old 01-30-2012, 10:46 PM
JJAMISON_
2015 JK Wrangler
John, when putting the body back on, do you have to use a body lift for the bigger trans and engine? or is it a good close fit? just curious.
JJAMISON_ is offline
post #30 of 60 Old 01-30-2012, 11:01 PM
VEGASROBBI
Sorry to intrude but I think I can answer. No body lift required, no suspension lift required for that matter.
If you set the engine in the rearmost position that we recommend there is about 3/8"-1/2" between the firewall and the back of the heads. Using the truck intake there will be about 1/2" between the top rear of the intake and the firewall overhang. There is enough hood clearance to run a Vortec engine cover with slight mods, if desired. No firewall mods are required and all the original heat shields remain in place.
If using the stock driveshafts you can move the engine 1" forward which give lots of clearance everywhere and allows the original shafts to work.
MoTech
LS Specialists
www.LSWrangler.com
OMG!!! Saw an 07 4dr with a Chevy 6.0L 07BlackOps JK Wrangler Technical Forum 19 03-13-2011 10:25 AM
05 TJ looking for d60 and chevy 14b 2005X TJ Wrangler Technical Forum 4 03-28-2008 04:23 PM
89 2.5 ax5 to chevy 350? magoo1019 YJ Wrangler Technical Forum 1 01-01-2008 02:15 PM
Chevy 350 W/ Chevy Tranny - Will It Work??? I8JPB4U YJ Wrangler Technical Forum 5 09-16-2004 10:53 PM
4.0L or Chevy 350 SC PuddleJumper YJ Wrangler Technical Forum 2 12-29-2003 12:47 PM
