Check things after you lift...1 - Page 3 - JeepForum.com
post #31 of 61 Old 10-19-2010, 12:30 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Originally Posted by Unknown303 View Post
Awesome thread! I'm actually just posting so it's easier to find when I get my 35s
This thread along with allot of other pertinent threads have link's located in the F.A.Q.
Jim
JLC08JK is offline
post #32 of 61 Old 10-22-2010, 11:03 AM
taoshum
Even if you don't lift, I saw this triangle of metal sticking out in the rear wheel wells and decided it might cut the tires so I used a small right angle composite blade on the grinder to cut it down. I also installed some more rubber matting to block mud from getting between the bottom front of the fender and the "running board". I guess I need to back caulk the metal with a clear silicone caulk.
Then I found this thread. thanks.
Geezer from NM
"Wisdom isn't cheap; we pay for it with pain
taoshum is offline
post #33 of 61 Old 10-22-2010, 01:45 PM
Joevacs
2010 JK Wrangler
I too thankyou.Very helpful info.
I noticed that sticking into the wheel well and it seems bizzar that it was that far back to begin with. Anyway, the only thing I would (will) do different, is, I would never use silicon caulk. It will seperate from the metal and you will have a rust problem. As thick as they are, it won't cause damage, it'll just be ugly. I will use 3M - 4200, black caulk. It will stay stuck forever.
2010 Rubicon, 4" lift, Currie control arms and trackbar, 40" Procomp MTR
Joevacs is offline
post #34 of 61 Old 10-22-2010, 01:48 PM Thread Starter
1222
RIP John
1222's Avatar
^^^ You like black caulk?
(2011-2016)
1222 is offline
post #35 of 61 Old 10-22-2010, 03:16 PM
JLC08JK
JLC08JK's Avatar
I wouldn't use caulk (I don't like it)
I would use Bondo or epoxy putty
Jim
JLC08JK is offline
post #36 of 61 Old 10-23-2010, 07:27 AM
Joevacs
2010 JK Wrangler
I like 3M 4200 as aposed to silicon caulk. It only comes in white or black. It's made for boats, and will stay stuck in the worst conditions.
Joevacs is offline
post #37 of 61 Old 11-02-2010, 02:49 PM
calys003
I would weld it closed, grind and smooth it, paint, done. Than I would never have to mess with it again. Also 1222 great write up!!
calys003 is offline
post #38 of 61 Old 11-02-2010, 07:16 PM Thread Starter
1222
RIP John
1222's Avatar
That would be fine but just in case you don’t know, in order to weld it up you would have to remove all the coating that is applied at the factory not only to the outside but also the inside in order to weld up the gap. If you didn’t then you would end up with a weld that looked like Swiss Cheese at best. As long as the inside gap is cleaned with lacquer thinner silicon will work just fine and it should last forever or there about.
Thanks for the complement.
(2011-2016)
1222 is offline
post #39 of 61 Old 01-13-2011, 08:32 PM
04sssti
Great writeup. I am thankful everyday for this forum. What the hell did people do before the internet!!!!!!!!
04sssti is offline
post #40 of 61 Old 01-13-2011, 08:42 PM
guarnibl
2009 JK Wrangler
Dude you rock
2009 Jeep Wrangler Rubicon (6mt) (in progress)
- 42x14.50 MTR's, Custom Cage, FF D60's F/R w/ ARB's and 5.38's, 4 Link Rear, 3 Link Front, 14" RR King 2.5's, 18" RR Fox 2.5's, Fox Air Bumps
- 108" wheel base
guarnibl is offline
post #41 of 61 Old 01-13-2011, 09:10 PM
jonnytc
This was a really clearly informative write up. Thanks for the great clear pictures as well.
Jc
2008 JK Sahara Unlimited Steel Blue--For the Beach and Family
2005 LJ Rubicon Unlimited Black--For anywhere I want to go
Did you Wave to a JK today???
jonnytc is offline
post #42 of 61 Old 01-13-2011, 09:22 PM Thread Starter
1222
RIP John
1222's Avatar
Thanks guys I really appreciate it.
(2011-2016)
1222 is offline
post #43 of 61 Old 04-05-2011, 09:55 PM
14thegipper
2009 JK Wrangler
Would a hack saw produce the same clean cut?
14thegipper is offline
post #44 of 61 Old 04-06-2011, 03:08 AM Thread Starter
1222
RIP John
1222's Avatar
Sure it would, just follow the line you make. If need be then a metal file would work to smooth things out. I wouldn’t really worry about it too much though. Just cut the pinch seam slightly shorter than the Rock Rails and nobody will ever notice.
(2011-2016)
1222 is offline
post #45 of 61 Old 07-19-2011, 04:09 PM
mwood5
2010 JK Wrangler
OK...10 months later, but I appreciate your joke, even though no one else made mention of it.....
m
mwood5 is offline
checklist , clearance , issues , JK Wrangler , lift , pinch seam , problems after lift , wrangler
reviving a '92 renegade, things to check? klone YJ Wrangler Technical Forum 1 12-21-2009 11:36 AM
Things to check after salvage engine swap Morpheus TJ Wrangler Technical Forum 2 11-24-2009 04:38 AM
Looking at a 94 4.0L things to look for and lift questions? broncofire75 YJ Wrangler Technical Forum 2 05-07-2008 09:35 AM
buying jeep on saturday (seatbelt issue, rust, and possible things to check) ben8jam TJ Wrangler Technical Forum 24 01-05-2008 06:18 AM
Things to check after accident waterlogged TJ Wrangler Technical Forum 17 06-28-2006 07:37 PM
