-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Check things after you lift...1 (http://www.jeepforum.com/forum/f96/check-things-after-you-lift-1-a-1028055/)
1222 05-07-2010 09:23 PM
I was thinking that I would have to trim my Rock Sliders and pinch seam with the 35 BFG KM2ís installed so I tried it out on a little dirt mound in my yard. Glad I did, because if I would have gone wheeling there would have been some serious damage done to my rear tires. I know itís been done a thousand times before, but for those that arenít quite sure, here are a few pics of how itís done.
This is the small dirt mound i used.
http://i469.photobucket.com/albums/r...Sliders-15.jpg
Good thing i got out to see how close the tire was getting.
http://i469.photobucket.com/albums/r...liders-1-2.jpg
Thereís a plastic retainer plug that keeps the end cap from coming off. It will have to be removed to separate the cap from the Slider.
http://i469.photobucket.com/albums/r...kSliders-1.jpg
Although I used a plasma cutter, you can use a swazall, cut-off wheel or hack saw. I measured 1inch and made my cuts.
http://i469.photobucket.com/albums/r...kSliders-3.jpg
After the cut, clean it all up.
http://i469.photobucket.com/albums/r...kSliders-4.jpg
Next, measure carefully so you can drill a new hole for the retainer clip.
http://i469.photobucket.com/albums/r...kSliders-5.jpg
Paint drilled hole to keep it from rusting.
http://i469.photobucket.com/albums/r...kSliders-6.jpg
Reinstall Slider and mark the pinch seam for cutting.
http://i469.photobucket.com/albums/r...kSliders-8.jpg
Remove Slider and use tape and square to make straight lines for an accurate cut.
http://i469.photobucket.com/albums/r...kSliders-9.jpg
This is what it will look like after the cut.
http://i469.photobucket.com/albums/r...Sliders-10.jpg
Fill-in with you favorite tube of silicon. Although itís not shown in this pic, use something to smooth the silicon before painting the cut.
http://i469.photobucket.com/albums/r...Sliders-11.jpg
Pinch seam is all finished and painted.
http://i469.photobucket.com/albums/r...Sliders-12.jpg
Rock Slider installed. Thatís it. Repeat on other side.
http://i469.photobucket.com/albums/r...Sliders-13.jpg
This is a pic of the Jeep in the same spot on the dirt mound as in the beginning. As you can see, there is now plenty of room.
http://i469.photobucket.com/albums/r...Sliders-14.jpg
Iíve read how some people pound over the pinch seam with a hammer, but I personally donít like the ďhacked jobĒ look. I didnít time it, but this mod really doesnít take long. I guess it would depend on the cutting method.
:highfive:
infernicus 05-07-2010 09:57 PM
That is such a great write-up!! thanks so much for taking out the time, and making people feel more comfortable doing it.
I will most definitely be doing this next week to my friend's JK.
1222 05-07-2010 10:08 PM
Youíre welcome. I know what its like to hear about how to do things but itís another thing when it comes to actually doing it, especially if youíve never attempted it before. Good luck on your friends Jeep.
:cheers2:
drowe303 05-07-2010 11:38 PM
Why reinstall the sliders before cutting the pinch seam? Why not just measure an inch off and cut. That way you don't have to take the sliders off, put them on, then take them off again, then put them back on.
1222 05-07-2010 11:51 PM
I wanted to make sure that the cut line was exactly lined up with the Slider. Even though I measured an inch on the sliders, after the cut is done and the die grinder to clean things up, it could actually be a bit more than the original inch. It was no big deal with the Slider. All you have to do is just place it on the Jeep. The way it bolts on with the studs, it holds its self up. No need to bolt it on. Takes no more than a minute all said and done. I like the clean look.
:cheers2:
drowe303 05-07-2010 11:57 PM
oh, gotcha. Wasnt sure how much work was involved with removing and installing the sliders. Looks great though!
dirtyjpwrangler 05-08-2010 12:13 AM
nice writeup.
love the light bar! what kind is it? got anymore pics?
1222 05-08-2010 01:01 AM
I wasnít sure either. Very simple though. By the way, theyíre quite stout too. I was surprised.
:cheers2:
yippie21 05-08-2010 02:26 AM
Ditto nice write-up and pics. I did the same to mine, but I used the sawzall and took 2.5" off each rail. Used the RTV to seal up and hold the caps on the ends of the rails and when I cut the pinch seam down too.
Nice job and good looking Jeep.
1222 05-08-2010 03:12 AM
Itís actually part of my roof rack. When itís finished I plan on doing a wright-up on it.
:cheers2:
DeepSky 05-08-2010 06:23 AM
Excellent write up.
Would the amount you trimmed off leave enough room for 37" KM2s? Right now I have 35" MTZs and the pinch seam/rail was never and issue.
Thanks.
TurtleSlinger 05-08-2010 06:31 AM
Originally Posted by DeepSky (Post 9424597)
Excellent write up.
Thanks.
I am curious about that too. I currently have 35's on a 5" lift and havent had ANY issues with the rock slide or pinch seams. Currently have plenty of room for tire to get by, but if I was to goto 37's I would probably need to do this, but am curious if this alone will make enough room for those larger diameter tires?
1222 05-08-2010 12:42 PM
I donít see why you guys would have plenty of room for your tires unless you have adjustable rear control arms and are able to re-center your axle. Even so, the rear of the tire might then become an issue. Maybe too youíre bump stops are really tall. Are you sure you flexed it out all the way? I have literally only a fraction on an inch clearance between my tire and fender as it is. Anyhow, I doubt very much that just an inch off the pinch seam would be enough to clear 37ís.
:cheers2:
fernjack 05-08-2010 11:52 PM
:highfive:
Very clean job ! Thanks for posting this , really did a nice job :cheers::wave:
1222 05-09-2010 03:44 AM
Thank you! :tea:
The time now is 09:42 PM.
