Check Engine Light P1404 - JeepForum.com
post #1 of 2 Old 05-31-2012, 02:57 PM Thread Starter
soucorp
My check engine light came on, plugged my OBDII scanner, it says
P1404 - Egr Position Sensor Rationality Closed
The P1404 is a fairly straight forward code pointing to a fault with the EGR Valve. Inspect the electrical harness and connector for any loose or broken wires. Sometimes a good cleaning of the EGR with carb cleaner and a small wire brush can solve this problem. If the cleaning does not solve the problem, and the visual inspection checks ok, replace the EGR Valve.
You can still drive the car without damaging it, the EGR is only for emissions stuff and the car drives normal.
Old part number: 04861674AD
New part number: 4593896AB
There is a national backorder on EGR valves for JKs.
I got lucky and bought a new EGR valve from these guys for $85
http://www.wholesalemopar.com/
I will be replacing this part myself, dealer wants $450. From what I read, its going to be a PITA for the automatics but I can do it thru the tire well or battery well on top.
previous posting how to:
http://www.jk-forum.com/jk-write-ups...-p0406-127376/
soucorp is offline
post #2 of 2 Old 03-13-2017, 11:21 AM
waynef1969
2011 JK Wrangler
Lucas engine cleaner worked for me.
I receive this message on my Jeep Wrangler 2011. about 115,000 miles on it. I was reluctant to spend $400 so i saw one user suggested using and engine cleaner. i used Lucas engine cleaner. after going through 3/4 tank the error disappeared. so far it has not come back
waynef1969 is offline
Check Engine Light Before Startup and Check Guages monto TJ Wrangler Technical Forum 5 05-15-2012 12:58 PM
Check Engine Light/Check Gauges Light eastwood1972 TJ Wrangler Technical Forum 3 11-16-2010 05:06 PM
Newby needing help with Check engine light/check gauges/stalling DannyDuvall TJ Wrangler Technical Forum 2 08-23-2008 08:02 AM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-26-2003 11:43 PM
