Quantcast Check Engine Light Error P0306 Cyliner Misfire - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Check Engine Light Error P0306 Cyliner Misfire
SALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30 1984-2001 Jeep XJ Cherokee Lift Kits 3-4.5" with FullIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 11-20-2009, 07:43 PM   #1
MacK
2010 JK Wrangler
So heading home today my check engine light came on. I checked the code and it said "P0306". I have been noticing my engine running slightly rough, but nothing major. It says "stumbling" I assume this is what it's been doing, I truthfully don't know how to describe it..
The error reports:
What does that mean?
A P0306 code means that the the car's computer has detected that one of the engine's cylinders is not firing properly. In this case it's cylinder #6.
Symptoms
Symptoms may include:
* the engine may be harder to start
* the engine may stumble / stumble, and/or hesitate
* other symptoms may also be present
Causes
A code P0306 may mean that one or more of the following has happened:
* Faulty spark plug or wire
* Faulty coil (pack)
* Faulty oxygen sensor(s)
* Faulty fuel injector
* Burned exhaust valve
* Faulty catalytic converter(s)
* Running out of fuel
* Poor compression
* Defective computer
According to OBD-II Trouble Code: P0306 Cylinder 6 Six Misfire Detected
I'm flat broke, And I'm at 56,800 miles out of warranty slightly.
How do I reset the computer? Because it gave me the code the FIRST time around, but now it won't give me the code it just says ------ but the check engine light is still on.
I think I'll take it to autozone and have it scanned tomorrow..
I don't want your d**n lemons! What the hell are these?! Demand to see life's manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I'm the man who's gonna burn your house down! WITH THE LEMONS! I'm gonna get my engineers to invent a combustible lemon that BURNS YOUR HOUSE DOWN!
Mango Tango 2010 JK Wrangler Rubicon
Silver 2000 TJ Wrangler Sport
The 2008 Jeep Wrangler is not so much an SUV as it is an experience. It's slow and loud, handles poorly, has crummy interior materials and features doors that provide virtually no crash protection. But when it comes to off-road performance, the Wrangler is simply the best choice available.
MacK is offline   Reply With Quote
Old 11-20-2009, 07:53 PM   #2
ronjenx
ronjenx's Avatar
Are you the first owner with a delivery date on or after July 26, 2007?
ronjenx is online now   Reply With Quote
Old 11-20-2009, 07:57 PM   #3
MacK
2010 JK Wrangler
I am second owner. I bought it with 3,000 miles roughly.. Think there's a TSB? Where can I find production date?
Old 11-20-2009, 08:04 PM   #4
ronjenx
ronjenx's Avatar
You have posted a lot of information already. Is it generic OBDII info?
This is from the 2008 FSM for P0306:
P0306-CYLINDER 6 MISFIRE
Set Condition:
The threshold to set the fault is application specific; it is tied to the level of misfire that will cause emissions to increase to 1.5 times the standard or in some cases 1%. It is always a two trip fault above the calibrated RPM. It takes 1 soft fail to set a malfunction and two trips to set the MIL. Three good trips to turn off the MIL.
Possible Causes
ASD RELAY OUTPUT CIRCUIT
INJECTOR 6 CONTROL CIRCUIT
COIL CONTROL 3 CIRCUIT
IGNITION WIRE
SPARK PLUG
IGNITION COIL
FUEL PUMP INLET STRAINER PLUGGED
RESTRICTED FUEL SUPPLY LINE
FUEL PUMP MODULE
FUEL PRESSURE LEAK DOWN
FUEL INJECTOR
ENGINE MECHANICAL
POWERTRAIN CONTROL MODULE (PCM)
Old 11-20-2009, 08:20 PM   #5
MacK
2010 JK Wrangler
I assume it is generic ODBII info... Would this be caused by me or just something that went whacko by itself?
Old 11-20-2009, 08:52 PM   #6
ronjenx
ronjenx's Avatar
If you had just done some maintenance, you could have knocked something loose.
Is it still running roughly?
Pick out the items from the list that you can check.
Some people have had problems with spark plugs. Put a new one in cylinder #6. Or, just swap it with one from another cylinder. See what happens.
Get it scanned to see if there are any other codes set.
If it's not running roughly, have them erase the codes and turn out the light. See if it all comes back.
Old 11-20-2009, 09:01 PM   #7
MacK
2010 JK Wrangler
Who has to erase the codes? Can Advance Autoparts do this? I know they can scan the computer. I haven't done any kind of maintenance. However I did recently spray the engine down with water but I always do this because it tends to get muddy ;x
I'm not mechanical at all.. I can change oil and air filter that's about it. It seems like it runs smooth, then kinda "misses" every few minutes.. but only while idling not while moving. Sounds fine running. There's sometimes slight vibrations. Sometimes when I shut off the engine the whole vehicle vibrates - but it's always done this since I had it..
Old 11-20-2009, 09:53 PM   #8
MacK
2010 JK Wrangler
OK, so it won't report the error anymore. It just says ----- but the check engine light is STILL on - what does this mean? The error is null it just needs to be reset? How do I reset?
Old 11-20-2009, 10:11 PM   #9
ronjenx
ronjenx's Avatar
It could be some codes will not show with the readout on the instrument cluster. If there are other codes, that would be why the light is still on.
If the problem no longer exists, the light should go out after 3 good trips.
Anyone with a scanner should be able to clear the codes and extinguish the light.
Try disconnecting the negative battery terminal for a few minutes. That may extinguish the light.
Old 11-21-2009, 01:18 AM   #10
MacK
2010 JK Wrangler
Thanks. I'll do this and report back tomorrow.
Old 11-21-2009, 03:36 PM   #11
MacK
2010 JK Wrangler
Engine lights went off today... didn't do anything to it. Just shut off. It wasn't giving the error code anymore so I have reason to think it was just a error in the computer or it just happened to "misfire" once.. seems good now :O
Old 11-21-2009, 04:48 PM   #12
ronjenx
ronjenx's Avatar
Has the roughness gone away, too?
Old 11-21-2009, 06:57 PM   #13
MacK
2010 JK Wrangler
It seems too.. wonder what it was..?
Glock Forum
