Check Engine Light Codes - JeepForum.com
post #1 of 2 Old 05-21-2010, 02:38 PM Thread Starter
Nuts
2009 JK Wrangler
I did the EVAP Canister relocation the other weekend and the check engine light just came on. The two codes that registered were:
P0440 General EVAP System Failure
P0456 EVAP Purge System Small Leak
I plan on fixing the leak this weekend but my question is about the other code, P0440. Would this code register because of the small leak or is there a possible other problem that I am having. I am assuming that if I fix the leak then I will fix the general failure. Is my rational correct?
Thanks for the help
Nuts is offline
post #2 of 2 Old 05-21-2010, 04:52 PM
Canada12
They are related codes. Either a hose is not connected or sealing or your ESIM switch is not connected or making contact. You should have 5 volts and a ground at the connector at the cannister - check all fittings and your gas cap ! Good luck.
Canada12 is offline
check engine light 2 codes 2005X TJ Wrangler Technical Forum 2 01-10-2010 08:28 PM
FAQ - Check Engine Light and Diagnostic Trouble Codes (Error Codes, Problem Codes) Wheelin98TJ TJ Wrangler Technical Forum 6 05-15-2009 05:05 PM
check engine light= no codes vargeg60 TJ Wrangler Technical Forum 5 03-11-2007 07:01 AM
'00 TJ - Check Engine Light on but can't get codes FleetPlans.com TJ Wrangler Technical Forum 4 10-09-2006 10:53 PM
check engine light codes asjeep TJ Wrangler Technical Forum 2 09-12-2003 07:04 AM
