Check Engine (Gas Cap) - JeepForum.com
post #1 of 4 Old 04-27-2010, 03:02 PM Thread Starter
SkipperTW
2016 JK Wrangler
Hello all,
I wanted to see if anyone has this issue (I am having no luck re-setting my Check Engine light after having my Gas Cap stolen ...)
I was driving one day and the light came on, I had no idea why (the gaScap notification did not come up on the Odometer like the manual said it would). Called for Dealership appt. and he mentioned the Gas Cap and that was it, gone…
I then got a new gas cap (dealer ordered, not aftermarket) and still cannot get the light to re-set. I held down the trip odometer re-set and it still remains on.
Now, I have had cars where the light was always on (just the nature of old crappy vehicles) but this is a 09 JK Sahara with 7,000 miles on her. Plus, I can't use the Auto start...
Any help would be great.
Thank you,
SkipperTW is offline
post #2 of 4 Old 04-27-2010, 03:08 PM
JeffinWesternWA
2010 JK Wrangler
drive about 100~ miles, several ECM cycles (as long as lite does not "flash" there is no misfire), if still on, you've got a hard code set and have dealer pull and diagnose, it's covered undr warranty as emissions issue beyond the 3/36 warranty BTW
JeffinWesternWA
JeffinWesternWA is offline
post #3 of 4 Old 04-27-2010, 06:43 PM
biker_dude
I got this when I put a Wally World aftermarket cap on my rig. Just make sure you put a Mopar cap back on and unplug the negative battery cable for about 15 minutes. This will turn off the light but you will have to reset your clock.
biker_dude is offline
post #4 of 4 Old 04-27-2010, 07:56 PM
WVUJeeper
Fill up your gas tank so that it's easier for the vapors to pressurize it....that made the difference on the girlfriends lancer.
- Fletcher: Oil Field Trash Extraordinaire
Originally Posted by VetteDriver View Post
BTW, what's with the "if you haven't driven one shut up" nonsense? How can we have a good internet fight if experience and knowledge are going to be a requirement?
'08 Rescue Green Unlimited X - Hard Top, 3.73 gears, Limited Slip, Infinity 7 speaker system, KC Slimlite Long Range, Cobra CB, Rough Country 2.5" BB, 35" BFG KM2's on ProComp 7089's. Fenderless and proud!
My build thread:
RESCUE GREEN JEEP CLUB MEMBER #25
COLORADO JEEP CLUB MEMBER # 1001
WVUJeeper is offline
check engine light and continous engine hickup GRN_BEAST95 YJ Wrangler Technical Forum 11 09-02-2009 02:19 PM
my check engine light is on what should i check. incagoldjeep TJ Wrangler Technical Forum 17 07-31-2009 09:09 PM
Check engine light. What to check first? 94YJEEPER YJ Wrangler Technical Forum 43 03-06-2009 10:10 PM
Newby needing help with Check engine light/check gauges/stalling DannyDuvall TJ Wrangler Technical Forum 2 08-23-2008 09:02 AM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-27-2003 12:43 AM
