Cheap heep - JeepForum.com
post #1 of 2 Old 06-02-2014, 03:38 PM Thread Starter
REPR
Cheap heep
I recently put my old Land Cruiser trail rig to rest because it got too damn expensive to fix it.
I have some money laying about and need a new truck to buy and was hoping to get into a cheap JK. Here in Colorado you can get a Sport for about 22 grand, new.
I was just having some basic questions, since I'm a noob to the Jeep
-what's a good 2.5-3" lift?
-do I need to regear an MT if I run 35"s?
-can you run the new Jeeps with sway bars removed, or does it result in really scary handling?
I want to run this on the trails, but still have it livable enough that I can use it to drive 10 miles to work and back.
They sell AEV's around here, would one of their packages even be worth considering, or is it overpriced?
REPR is offline
post #2 of 2 Old 06-02-2014, 04:26 PM
222Doc
222Doc's Avatar
depends on what "good" is to you. To me it means all adjustable links with JJ's, progressive or dual ratted springs and made in the USA
Depends on what gears you get, at a base model its 3.21:1 at that no. so you need at least the 3.73:1 and that is borderline with 35s. If it was a JKR with 4.1:1 the auto your set. The manual is good though many prefer 4.88 but hat is not stock
No, not a good idea with a linked suspension.
Over priced, especially for a 2D. You plan to run this on anything hard a 2D no matter what you hear here needs lift to clear that belly. Since a Belly up on a JK for MOST people is way to expensive and not easy to do, requires the relocation of the fuel tank and MANY other things. YOu have two ways to get the belly UP. tires and lift. Tires on a sport are maxed to being anything close to reliable at 35"s and cost effective. Going bigger has a huge cost to do right. LIFT since you are looking at a 2d( ihave one) 3-4" is the best height for the money and you can plan on Drive shafts especially the rear on a 2d. I made what i call the mistake of going AEV full lift kit at 3.5. The front drop brackets will hang on many rocks and can bend and will get beat to h3!11. No control arms so the rear will need those when you change to a more flexi drive shaft If had to start fresh I would most likely go with Metal Cloaks game changer light, @2k+-. or if i had the money would get their Sixpack shocks that give you as much flex as many coilovers setups.But at 4K, yea 2k for shocks, but they are one of a kind.
My jeep is such a mix of parts now that its more a Frankenlift.
My2c that wont buy you a cup of coffee.
222Doc is offline
