Changing Fluid on a Manual Transmission Problems - JeepForum.com
post #1 of 11 Old 03-15-2010, 05:42 PM Thread Starter
BrettDez
Hey,
Does anyone have advice or a tool suggestion to get that damn drain plug out from the transmission?!?!? I cannot get access to it!
It seems in a moment of genius, the designers placed an exhaust pipe DIRECTLY below the drain plug. I don't know what I can get in there to get it off, there's no room!!!
Anyone have a solution? I actually posted this before, and still haven't found a solution. I need to do this soon now.
-Brett
My Jeep: 2012 Jeep Wrangler Unlimited Rubicon, 6-Spd Manual, Cosmos Blue
"The Smurf":
Previous Jeeps:
BrettDez is offline
post #2 of 11 Old 03-15-2010, 06:34 PM
PanthersFan
I grabbed it with a pari of vice grips. The threads that I ruined were exposed anyway. Tightened it up the same way.
Some people have welded a nut onto a bolt that fits, but that didn't work for me.
THE Conventions of a number of the States, having at the time of their adopting the Constitution, expressed a desire, in order to prevent misconstruction or abuse of its powers, that further declaratory and restrictive clauses should be added: And as extending the ground of public confidence in the Government, will best ensure the beneficent ends of its institution.
PanthersFan is offline
post #3 of 11 Old 03-15-2010, 09:35 PM Thread Starter
BrettDez
I'll give it a shot, any other ideas??
-Brett
"The Smurf":
Previous Jeeps:
BrettDez is offline
post #4 of 11 Old 03-15-2010, 10:22 PM
Avian
All of the instructions Ive seen suggest fabricating a custom tool for the job.
I agree, ridiculous spot for a drain plug. Not only because of the limited access, but also the idea of having oil spill over a hot exhaust pipe doesnt sit right.
Detonator Yellow JK-X
150w windshield mount long range KC's
bumper mount Hella 500's/ 130w KC drivers
Uniden Bearcat CB/PA
Mopar bumper
Moabs/ BFG KM's
Avian is offline
post #5 of 11 Old 03-16-2010, 01:09 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
I haven't done it yet and if I'm thinking right it takes an allen wrench. Correct?
If yes then you just get the appropriate L shaped allen wrench and cut the short side down with an angle grinder.
Don't get it too hot or you will remove the hardness, dip in water to keep it from burning.
Hope this helps.
Jim
JLC08JK is offline
post #6 of 11 Old 03-16-2010, 05:29 AM
SETXWarrior
I made one with 1ea 17MM x 1' bolt and two hex nuts. thread the first nut to the bolt head then jam the second nut FIRMLY into the first. Insert the bolt head into the drain plug, then put a wrench on the FIRST hex nut to remove.
I did this several months ago, and I'm going by memory on the 17MM. I'll double check and see if I still have it. I'll mic it and post a pic.
I also seem to remember wrapping foil around the exhaust for easy clean up.
SETXWarrior is offline
post #7 of 11 Old 03-16-2010, 05:43 AM
SETXWarrior
Yup, 17MM x 1"
post #8 of 11 Old 03-16-2010, 06:34 AM Thread Starter
BrettDez
Originally Posted by SETXWarrior View Post
Yup, 17MM x 1"
This should work!! I'll give it. Try this weekend! Thanks!
-Brett
"The Smurf":
Previous Jeeps:
BrettDez is offline
post #9 of 11 Old 03-16-2010, 07:12 AM
Steve98
I bought a cheap 17mm allen socket. Punched the allen key out and cut it shorter. It fits in nicely, and just turn it with a wrench.
I like the idea of cutting down an allen wrench though, no need for a separate wrench.
2006 LJ Rubicon
Steve98 is offline
post #10 of 11 Old 03-16-2010, 11:15 AM
BadHammers
PM Sent -- there's a good write-up at Project JK
BadHammers is offline
post #11 of 11 Old 03-16-2010, 06:28 PM Thread Starter
BrettDez
Hey thanks guys, I don't have the tools to cut down an allen wrench(military, don't have the largest tool collection based on moving alot). However, the nut and bolt idea posted should work just fine!
I will post results after I try it this saturday!
Thanks again everyone!
-Brett
"The Smurf":
Previous Jeeps:
BrettDez is offline
Changing Manual Transmission Fluid through fill hole? BrettDez JK Wrangler Technical Forum 11 09-08-2009 03:18 AM
Changing manual transmission fluid irishfastback TJ Wrangler Technical Forum 5 07-31-2009 09:42 AM
Changing Manual Trans Fluid jrb470 TJ Wrangler Technical Forum 7 02-28-2009 06:27 PM
YJ Transmission Fluid (MT90?) ,,,, metal piece when changing fluid GMC7000 YJ Wrangler Technical Forum 12 11-04-2008 07:11 PM
Changing Manual Tranny Fluid nightstalker5.0 YJ Wrangler Technical Forum 4 10-10-2004 07:49 PM
