Changing Diff fluid after gear change brake in period? - JeepForum.com
post #1 of 6 Old 08-31-2013, 06:43 AM Thread Starter
04WJfreedom
04WJfreedom's Avatar
So I heard from some people I should change the diff fluid after 500 to 1000 miles of my gears being changed? Wanted to make sure this is correct? I just installed Yukon gears about 500 miles ago and will change the fluids again if I need too, I was thinking about getting some new Diff covers when I'm at it also. Thanks
2012 JK Unlimited Sahara
Rock Krawler 3.5" X-Factor MID arm lift
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
04WJfreedom is offline
post #2 of 6 Old 08-31-2013, 07:52 AM
mello
Yukon has a break in oil change of 500 miles.
mello is offline
post #3 of 6 Old 08-31-2013, 08:33 AM Thread Starter
04WJfreedom
Thank you!
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
post #4 of 6 Old 08-31-2013, 09:58 AM
SoK66
2009 JK Wrangler
This ^. Don't be alarmed at the dark color, or if there's some fluff on the magnet, quite normal. I did mine again at 1500 miles just for comfort.
SoK66 is offline
post #5 of 6 Old 09-01-2013, 12:10 AM
TRAUMAhead
2010 JK Wrangler
Did you pull your covers both time?
TRAUMAhead is offline
post #6 of 6 Old 09-01-2013, 05:25 AM
SubAtomicGenius
2011 JK Wrangler
500 long miles after the break-in period. Check your patterns and look through the fine particulates, a combination of phosphate coating and metal wear, which is normal. Chunks and pieces are not normal! Great chance for new diff covers, if you hit water a lot you should check/change fluid often - lubelocker gaskets make it easy and they pay themselves off after a couple changes/inspections.
SubAtomicGenius is offline
