Changing Brake Pads - Page 2 - JeepForum.com
post #16 of 20 Old 06-04-2010, 01:56 PM Thread Starter
propped1
Originally Posted by Nuts View Post
propprd1 let me know if there is anything different about changing the front pads then the back pads. I wil be changing my front pads in about 2,000 miles.
Looking at the fronts, the only difference is the bolt size - 21mm instead of 18mm - and they are bigger. Still only two bolts. Similar bracket and overall design. Its still a single piston caliper and the tabs that go into the retainer clips are the same size on the replacement pads on the front and the rear.
Pretty straight forward. Follow the write up on project-jk.com. It covers everything even though they only do the rear.
If you need to change your front, change the back too. Everyone is having issues with the rear wearing before the front. I'd at least take a look.
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline
post #17 of 20 Old 06-04-2010, 02:10 PM
1Aauto
Vendor
1Aauto's Avatar
I'm doing my 04 Grand tomorrow. We sell brake pads if anyone needs them.I've got a set for myself sitting on my desk waiting to go into the grand.
Jeep Wrangler Brake Pads
1Aauto is offline
post #18 of 20 Old 06-04-2010, 10:32 PM
fernjack
It's easier to just take the caliper off and not the mounting bracket 13mm torqued to 26ft/lbs . Pry bar on between the rotor and old pad ...... no need for a c-clamp just presses on the edge of the rotor ..... very quick to change front or rear use medium (blue) lock tight on the bolts and you won't lose em' due to vibration ......... just sayin'
fernjack is offline
post #19 of 20 Old 06-05-2010, 01:09 AM
Hellbound13
Changed my rears awhile ago. I hope the fronts are as easy to do when its time..
Hellbound13 is offline
post #20 of 20 Old 06-05-2010, 01:41 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Tony; could you please change your link to include 07+ JK Wranglers
Jim
JLC08JK is offline
do i need to change my rotors when im changing my brake pads? incagoldjeep TJ Wrangler Technical Forum 10 05-06-2010 01:13 PM
Changing out my rear brake pads for the first time. Any guides out there? Dronac JK Wrangler Technical Forum 5 03-29-2010 06:09 PM
help with changing brake pads parks31 TJ Wrangler Technical Forum 4 12-30-2007 02:44 PM
Changing my brake pads CWaldrop TJ Wrangler Technical Forum 2 10-11-2005 08:48 PM
Changing brake pads NCjeeps TJ Wrangler Technical Forum 4 11-25-2003 12:26 AM
