Changing Brake Pads - JeepForum.com
post #1 of 20 Old 06-03-2010, 02:43 PM Thread Starter
propped1
Changing Brake Pads
Anyone out there change their own?
I have changed pads on a Bronco II, Tempo, and Dodge Dakota. I know I can do it myself fine, but there are nuances to every set up.
Anyone who has done this run into anything unexpected? Tips? Tricks?
If you haven't changed brake pads on a 2007 or newer Wrangler, please don't speculate for me. Appreciated.
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline
post #2 of 20 Old 06-03-2010, 03:00 PM
Nuts
2009 JK Wrangler
Changed mine in my 2009 JK for the first time about 2 months ago. It was the rear only because as other will say they are wearing faster than the front ones. This was the first time I have ever changed brake pads and it was a piece of cake.
There is a nice write-up on Project JK about how to do it that you might find helpful. But since you have done them before it just might be repetitive nonsense that you already know.
Nuts is offline
post #3 of 20 Old 06-03-2010, 03:05 PM Thread Starter
propped1
My rears wore faster than the front too. They are about half the size, but the majority of braking should be in the front. The only thing I can guess is the limited slip pulses the brakes and they might wear faster?
I got ceramic, so hopefully I can go for quite a while before having to do them again.
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline
post #4 of 20 Old 06-03-2010, 03:19 PM
N2rock
N2rock's Avatar
Piece of cake. If you've done disc brakes before, you'll have no problems.
Tips- only one I can think of is: if you've added brake fluid into the master, you'll want to take some out. Because when you push the piston in, its going to force fluid back into the master. If you don't take some out beforehand, you might end up with a bit of a DOT4 mess.
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #5 of 20 Old 06-03-2010, 03:54 PM
V-Powered
2015 JK Wrangler
Just did my rears on my '07 last week. Unbelievably, they lasted 40k...most then most here it seems. Anyway...it's a snap. Only thing i can add- is that if you have to take off the rotor for any reason (you shouldn't..i only had to once when doing a tire rotation- snapped a lug-nut stud..over-torqued from NTW! ) make sure that you remove the stupid little washer things with some needle-nosed pliers first. I must have beat the hell outta the rotor with a rubber mallet for 15 min pullin and chit until i figured it out.
'15 Sunset O HardRock Unlimited 6-speed. There is no such thing as overKILL.
V-Powered is offline
post #6 of 20 Old 06-03-2010, 04:20 PM
fuzzyz11
I did my rear pads about a month ago on an '07 following the write up Project jk and it was a breeze for my first time ever. Just be sure to have a large enough C clamp to compress the piston.
On another note, after I completed the change, my pedal still felt soft and braking power was minimal, so I thought I screwed up and had the shop do once over while they replaced a faulty O2 sensor I couldn't reach. They said everything looked good and I went on my way, only to still have a "soft pedal" sensation. I brought it back in and it turns out the brake master cylinder is shot at only 58k. Hopefully I should get it back tomorrow.
Good Luck!
fuzzyz11 is offline
post #7 of 20 Old 06-04-2010, 06:19 AM Thread Starter
propped1
Got the rears changed last night. Used the same retainer clips... didnt even clean em. They looked good. Put the cheap brake quiet packets on. Took me about 30 minutes for the first and 10 minutes for the second... good learning curve. A 5" C clamp is minimum for these if thats what your using.
Question on the fronts... they are built the same way as the rears but the bolts are larger. It's 18mm in the rear. My wrench/socket set goes up to 20mm and it is slightly too small to get the front calipers off.
What size is the bolt? 21mm? Cant find anything on it.
Im at 38000 miles. The rears were GONE, haha. My fronts have about 40-45% left. So I don't need to get on it right away (no more chirper noise). Just need to know what wrench to buy when its time.
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline
post #8 of 20 Old 06-04-2010, 06:58 AM
mandalayjim
Did any of you have the rotors "turned" while you had it apart?
mandalayjim is offline
post #9 of 20 Old 06-04-2010, 09:06 AM
N2rock
N2rock's Avatar
21mm it is sir
I know this without a doubt because I lost one of my front bolts while wheeling Memorial Weekend. Went on a mega search looking for a replacement and had no luck since it was Memorial Day. Ended up having to drive the 6 hours home without the upper bolt all the way. Made for some "interesting" braking
N2rock is offline
post #10 of 20 Old 06-04-2010, 09:17 AM
N2rock
N2rock's Avatar
I did not have mine turned. From what I've read on other forums- the stock rotors come straight from the factory at the bare minimum thickness, so turning them is not possible.
N2rock is offline
post #11 of 20 Old 06-04-2010, 10:00 AM Thread Starter
propped1
Originally Posted by N2rock View Post
21mm it is sir
Dare I ask how you lose a caliper bolt wheeling?
I noticed that after the two bolts came off I still needed to pry the caliper off with a screw driver to get it off the bracket... fits pretty snug. I wouldn't want to drive 6hrs with one bolt either, but doesnt surprise me you made it.
A 21mm bolt is not common even if it wasn't a holiday. That'd suck.
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline
post #12 of 20 Old 06-04-2010, 10:06 AM Thread Starter
propped1
The rotors dont even have vents in the middle (yet another reason people are getting their brakes eaten up quickly- hot). If my rotor got warped and I had to replace it, I'd buy more stout rotors.
The weight makes it hard to stop a wrangler. The suspension - especially with a lift - makes it worse... Wouldn't be a bad investment for some vented and/or crossdrilled rotors. Safer as well.
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline
post #13 of 20 Old 06-04-2010, 10:32 AM
N2rock
N2rock's Avatar
I have no clue! I wheeled all weekend. Left the off road place Monday morning, and drove 70mph 3 miles to the nearest town. As I was rolling thru that town (30 mph speed limit) I heard a weird noise coming from my front end. Pulled into a church parking lot, and had my wife drive around while I stood outside trying to locate the noise. At one point she put in reverse, and when she started moving I saw the caliper flip backwards and smack the wheel The one bolt was MIA, and the lower bolt was loose enough to turn by hand I have no idea when/where/how. I cranked down the one bolt, and headed for the nearest city (Austin) which was over an hour away. In Austin, I hit 6 auto parts stores and 2 hardware stores. No luck. SO had to finish the 4 hour drive home.
N2rock is offline
post #14 of 20 Old 06-04-2010, 11:47 AM
Nuts
2009 JK Wrangler
propprd1 let me know if there is anything different about changing the front pads then the back pads. I wil be changing my front pads in about 2,000 miles.
N2rock good lord thats crazy but glad you made it back safely.
Nuts is offline
post #15 of 20 Old 06-04-2010, 12:13 PM
N2rock
N2rock's Avatar
Like I said- it made for interesting braking. I had to apply very little pressure to the brakes, which meant slowing down way ahead of time. If I got in a situation that required even just a slight bit of more braking power, the steering wheel would wobble really bad until I let off. And if speed went below 10mph, I could hear & feel grinding- the caliper was grinding on the top edge of the rotor. If backing up and braking, the caliper would swing back and hit the rim.
When I got back home, I stole the bolt from my wife's JK and then Tuesday went off searching for the bolt again. Ultimately had to go to a dealer and order it (even the dealers did not stock it). The dealer got it in the very next day- cost a whopping $2.50 Ironic how the dealers charge like $7-$9 for those little plastic fender clips, but then only $2.50 for this big beefy caliper bolt.
N2rock is offline
do i need to change my rotors when im changing my brake pads? incagoldjeep TJ Wrangler Technical Forum 10 05-06-2010 12:13 PM
Changing out my rear brake pads for the first time. Any guides out there? Dronac JK Wrangler Technical Forum 5 03-29-2010 05:09 PM
help with changing brake pads parks31 TJ Wrangler Technical Forum 4 12-30-2007 01:44 PM
Changing my brake pads CWaldrop TJ Wrangler Technical Forum 2 10-11-2005 07:48 PM
Changing brake pads NCjeeps TJ Wrangler Technical Forum 4 11-24-2003 11:26 PM
