"change oil" still displayed after oil change - JeepForum.com
post #1 of 16 Old 04-26-2010, 05:29 PM Thread Starter
mudman1
hi, i bought a 2008 wrangler. when i start it up, it said "change oil"... well today i went to jiffylube and they changed the oil. but now when i start the car, it still says "change oil"
do i need to drive it a while for it to detect the new oil....or is something wrong?
thx
mudman1 is offline
post #2 of 16 Old 04-26-2010, 05:32 PM
McKBrew
JK Wrangler
Nope there is a way to reset it. Read here.
http://www.jeepforum.com/forum/f96/c...-light-953786/
McKBrew is offline
post #3 of 16 Old 04-26-2010, 05:33 PM
MilitaryJK4455
2010 JK Wrangler
First off... Shame on you for letting Jiffy Lube touch your Jeep.... Second off... All you have to do is turn the key to the on position without starting the Jeep then press the gas pedal three times very fast and it will cut the light off... You should do this after every time you change your oil, it does not "sense" the new oil... Hope that helps.
MilitaryJK4455 is offline
post #4 of 16 Old 04-26-2010, 05:35 PM
McKBrew
JK Wrangler
And Jiffy Lube is not going to have any idea how to reset the light. My dealership apparently can't figure it out either.
McKBrew is offline
post #5 of 16 Old 04-26-2010, 06:06 PM Thread Starter
mudman1
thank you, this fixed it.
it's also in my manual..page 207
mudman1 is offline
post #6 of 16 Old 04-26-2010, 06:20 PM
1222
RIP John
1222's Avatar
Itís best to change your own oil instead of Ďin and outí places. Do it yourself and know that itís done right. Many years ago I worked at a similar place and could tell you some of the mistakes that had been made (not by me of course). Remember, they want your car (Jeep) in and out as soon as possible and you donít always get the oil you ask for.
Plus, it gets you under your Jeep so you can take a look to see if everything is still ok. Stuff can come loose, bent, broke, crackedÖ
(2011-2016)
1222 is offline
post #7 of 16 Old 04-26-2010, 06:26 PM
McKBrew
JK Wrangler
There is only one reason I don't change my own oil. Dealer gave me free oil changes for 3 years when I bought it.
McKBrew is offline
post #8 of 16 Old 04-26-2010, 06:29 PM
1222
RIP John
1222's Avatar
Yeah, well look at that nice oil slick under your Jeep in your avatar. Nice job, dealer.
Just kidden.
(2011-2016)
1222 is offline
post #9 of 16 Old 04-26-2010, 06:33 PM
McKBrew
JK Wrangler
Just kidden.
Funny you mention that. Actually that is not from my Jeep, but when I put on my lift in December the guy whose garage I did it in noticed an oil leak. The filter was loose. NOW, I do second check the dealer.
McKBrew is offline
post #10 of 16 Old 04-26-2010, 07:48 PM
1222
RIP John
1222's Avatar
I was in a hurry as usual to get a customerís car finished and out, that I didnít check to see if the old filter gasket came off with the filter. Needles to say I installed the new filter with two gaskets. Luckily one of the other employees drove the car out and around the building. While doing so, the filter blew off and dumped a ***** load of oil on the ground. Hate see what would have happened if the customer drove off and had it happen on her way home. Just another point for doing it yourself.
My Jeep has to take me there and most importantly get me back. I trust it to no one unless absolutely necessary.
(2011-2016)
1222 is offline
post #11 of 16 Old 04-27-2010, 12:48 AM
No_Return
The day I witnessed A Jiffy-Lube type shop attempting to remove the T-Case Drain plug on my XJ with a pair of vice grips... This was absolutely the last time I ever set foot in one of those places... In fact I grabbed the manager and said WTF do they always use pliers as wrenches? They just looked at me like it was no big deal, routine business as usual.
Can I afford to pay someone to do this for me, Yep, Will I? Hell No!
Change your oil with your hands not a credit card.
One does not establish a dictatorship in order to safeguard a revolution; one makes a revolution in order to establish a dictatorship. - Orwell
No_Return is offline
post #12 of 16 Old 04-27-2010, 07:41 AM
jake_blue
I got the same deal... but as soon as that expires I definitely plan on being hands-on. My only problem is that it's so difficult to find places to recycle old petroleum byproducts in my area. I've been told the auto parts store accept these but I haven't checked that yet.
"My other car is..." Who needs another car, I'm driving a Jeep!
jake_blue is offline
post #13 of 16 Old 04-27-2010, 07:48 AM
BigRed09
2009 JK Wrangler
last time i went to an in and out shop was about 3 years ago with my old 92 integra. i had been going to the same place for about 6 years, knew the owner well, and usually got a discount(fluid check, carpet clean and oil change for $20). well, when they were putting the drain plug back in they stripped it and my oil slowly leaked everywhere for about a month before i noticed it. i had to drill a new hole in the oil pan and it was a big pain in the arse.
Mods so far: Mastercraft handles front and rear, Rugged Ridge euro rear tail light guards, Rugged Ridge mirror movers.
BigRed09 is offline
post #14 of 16 Old 04-27-2010, 08:33 AM
RAZORBILL
RAZORBILL's Avatar
2014 JK Wrangler
Like said above, nothing beats doing it yourself. I rcvd "free" oil changes for both my Jeep and our G8 but will never let them do either one. Sucks doing the G8 since you can't just crawl under the darn thing. Nothing some home made ramps didn't cure though.
As a side note, if you do it yourself make sure you keep receipts for your oil & filter and log when you do the oil changes. Just in case you have a warranty issue and they try to blame lack of of oil changes. Just something I've always done with my vehicles.
Previously owned: 80 CJ-5, 97 TJ,99 XJ, 95 YJ,10 JK Rubicon Unlimited, 10 JK Sport
RAZORBILL is offline
post #15 of 16 Old 04-27-2010, 08:46 AM
Jiblet
an auto parts store should definitely take the used oil (they do around me). You local wrench-turner should take it, too.
I believe any place that SELLS oil has to accept used oil for recycling.
I thought that was a federal rule, maybe it is just a state rule, maybe I am completely wrong...
someone correct me if I am wrong
Jiblet is offline
"Manual transmission fluid change" bigdogdaddy TJ Wrangler Technical Forum 103 02-10-2014 10:03 AM
How do I change the timing for the "nutter bypass" paxcrunner YJ Wrangler Technical Forum 6 03-15-2010 06:19 PM
Only 2400 miles and computer says "Change Oil" rayzordee JK Wrangler Technical Forum 15 01-17-2008 08:13 PM
"...little change through model year 2010..." otizzy JK Wrangler Technical Forum 17 03-29-2007 03:04 PM
Feel "clunk" through steering column when you change from Accel to Decel or opposite Mark_ZZ3 YJ Wrangler Technical Forum 5 04-13-2005 09:04 AM
