Change Oil Problem - JeepForum.com
post #1 of 5 Old 07-20-2010, 11:21 AM Thread Starter
eillirand
2010 JK Wrangler
Change Oil Problem
At roughly 6500 miles, the Change Oil notification appeared. Expected as that is within the normal 6000-8000 range that modern vehicles can go between oil; I changed the oil and the filter. Note; I have been doing my own oil changes for years.
Once completed; I followed the steps on resetting the computer gauge and all was good... until now. I have 8400 miles total on the Jeep and again the Change Oil notification appears.
Takes no Einstein to figure out that 8400-6500 = 1900. That is ridiculously low for the second oil change.
I purchased quality oil (Quaker State) [I could not find Mobile 1 in stock any where near me] and FRAM oil filters. I have used FRAM for years and just like them in general.
Nevertheless, I dont think either are the cause. The oil visually looks great (near new color; expected). Oil Levels are fine. etc etc. But obviously, some reason the computer thinks I need to change the oil with 1900 miles on it.
While I can just reset the computer again, I still find this odd and wanted to check and see if this has occurred for anyone else. I really dont want to reset as that will obviously mess me up with the next oil change. (although, I do not 100% rely on this to change my oil)
Thanks for any assistance. I hope next time I can get Mobile 1 as that seems highly recommended but again, bad timely. (places carried that but was out of stock). I have however used Quaker State, Pennzoil, Mobile 1 and just about every other brand in the past without problems.
eillirand is offline
post #2 of 5 Old 07-20-2010, 12:04 PM
Jiblet
that does seem like a really short interval but the algorithm doesn't take into account mileage or time (or what kind of oil you use). Just "duty cycle" which doesn't tell you a lot.
Some of the basic parameters are cold starts, restarts, time at operating temperature, engine revolutions, run time, oil temp, coolant temp, etc. Chrysler may have many more, I have never found out exactly; I assume it is a trade secret....
The OCI predicts degradation. You're free to ignore it. If you really want to know you can have your oil tested, for example, at blackstone labs.
Had your driving habits changed recently?
Jiblet is offline
post #3 of 5 Old 07-20-2010, 12:10 PM Thread Starter
eillirand
2010 JK Wrangler
Same driving habits. Living in Texas so Summer has been in full swing but that been the case since April Jeep was purchased March 27. 75% 25% Highway/City plus a weekend offroading. The offroading weekend was before the 1st change though. The oil temp shows dead center after the normal warm up period. Trying to think of anything out of the ordinary but my mind draws a blank.
My daily commute is roughly 80 miles. Time based, it has been about a month since I did the 1st change.
I read last year that in modern cars, just looking at the oil is not necessarily the best way to test oil these days, so one would say to trust the computer; but 1900 miles. Hmmm...
post #4 of 5 Old 07-20-2010, 12:23 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
It's a very regular occurrence for these to give a very early warning.
My change oil indicator goes on at aprox. 2500 miles every time and this has been the case with numerous others on this forum.
I have been changing oil around 3500-4000 miles so this basically gives me a reminder that I have a month or two to go
Jim
JLC08JK is offline
post #5 of 5 Old 07-20-2010, 12:42 PM
Vin
I think the computer is set to give a warning for every 3000 miles, so at 2500, 5500, 8500, you'll get a message to change your oil.
Vin is offline
change oil light , JK Wrangler , oil change indicator , wrangler
Speedo gear change problem kenabbott TJ Wrangler Technical Forum 9 12-05-2009 05:40 PM
Problem with lifters after oil change rogasm TJ Wrangler Technical Forum 19 03-25-2008 08:08 AM
oil gauge problem after change? jeepnaked98 TJ Wrangler Technical Forum 4 05-14-2007 06:22 PM
TCase Fluid Change, PROBLEM LeeGro TJ Wrangler Technical Forum 5 11-20-2006 06:25 PM
Problem after alternator change devinf YJ Wrangler Technical Forum 8 12-05-2004 08:09 AM
