Change Oil Message showed up - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Change Oil Message showed up
Stainless Steel Door Hinge PinsPoly Door Hinge BushingsSave at JeepHut on Smittybilt Soft tops
Unread Yesterday, 12:34 PM   #1
kinggatman
Made in USA
kinggatman's Avatar
2010 JK Wrangler
So I changed my Oil about three weeks ago and this morning the "Change Oil" message showed up. I tried the pedal to the floor three times trick but nothing. Any advise?
Thanks,
Mason
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
kinggatman is offline   Reply With Quote
Unread Yesterday, 12:36 PM   #2
duneslider
You sure you did the pedal thing right?
duneslider is offline   Reply With Quote
Unread Yesterday, 12:42 PM   #3
kinggatman
Made in USA
kinggatman's Avatar
2010 JK Wrangler
Pretty sure, not 100% though. It worked when I changed the Oil, I've tried a couple times now and nothing.
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
Unread Yesterday, 12:48 PM   #4
222Doc
ket to on, but dont turn over. press the gas pedal three times. Click your heals 3 times and repeat,there is no place like home.
[URL=http://www.bullhead4wheelersinc.com[/URL]
222Doc is offline   Reply With Quote
Unread Yesterday, 01:08 PM   #5
JIMBOX
The jeep must be facing North---
JIMBO
Yellow Jeep No. 683
http://i294.photobucket.com/albums/m...10-snow027.jpg
--YA GOTTA HAVE CLASS--
JIMBOX is offline   Reply With Quote
Unread Yesterday, 01:27 PM   #6
kinggatman
Made in USA
kinggatman's Avatar
2010 JK Wrangler
JIMBO
Seriously?
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
Unread Yesterday, 01:28 PM   #7
JIMBOX
Only if you're of the NANOOK TRIBE-
Originally Posted by kinggatman View Post
Seriously?
Just kidding-
JIMBO
Yellow Jeep No. 683
Unread Yesterday, 01:33 PM   #8
kinggatman
Made in USA
kinggatman's Avatar
2010 JK Wrangler
messing with the new guy lol. on a serious note, if the message doesn't turn off should I change the oil again?
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
Unread Yesterday, 01:42 PM   #9
JIMBOX
NO-if you've turned key to "ON"-immediately pushed gas pedal to floor 3-times within 10 seconds--not lightning fast just steady--three times to floor, turn key off--should go off, if not-
FAGETABOUTIT and drive regularly--should disappear !
Good luck
JIMBO
Yellow Jeep No. 683
Unread Yesterday, 01:49 PM   #10
Jiblet
The newer models let you postpone the warning message. Like hitting snooze on your alarm clock. I'll bet you just snoozed the warning.
Just reset it per the dance steps.
If I recall, it was noticed that the driver's door needs to be shut. (Unless that was for programming keys....)
EDIT, I see in your profile you have a 2010. Correct? in which case, no snooze feature like the newer EVIC models.
So, you change the oil 3 weeks ago and you thought you reset the warning, right? But it came on again, how many miles in the last three weeks? It would be really weird to get a NEW warning after such a short time.
Jiblet is offline   Reply With Quote
Unread Yesterday, 01:53 PM   #11
kinggatman
Made in USA
kinggatman's Avatar
2010 JK Wrangler
Alrighty then, I'll give it another try. Thanks for the replies
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
Unread Yesterday, 01:59 PM   #12
Jiblet
I edited my reply...
Unread Yesterday, 06:51 PM   #13
kinggatman
Made in USA
kinggatman's Avatar
2010 JK Wrangler
That's correct, 2010. And maybe about 100-150 tops.
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
