Change Fluids? - JeepForum.com
post #1 of 36 Old 09-08-2012, 08:47 PM Thread Starter
toxicwaste29
Change Fluids?
I did some offroading today and i went through one puddle that was a little to deep. Water came over top of the hood however it was for a split second or two. When i got out of the puddle i checked my air intake box and there was water in the bottom but only about a splash, which i wasnt worried about since the intake and filter draw from the top of the air box. Should i have to worry about changing any of my fluids since the axle breathers are at the same height as my air intake box? I have a 2012 jku 6 speed if that would help any.
toxicwaste29 is offline
post #2 of 36 Old 09-08-2012, 09:13 PM
jjeling
Do your breather hoses still have the plastic caps on the end of them?
jjeling is offline
post #3 of 36 Old 09-08-2012, 09:24 PM Thread Starter
toxicwaste29
I do not know. I am assuming they should still have them? What kind of cap is it since the hoses have to breathe?
post #4 of 36 Old 09-08-2012, 10:17 PM
jjeling
Your breather hoses have little green caps on the end of them that prevent stuff like water from getting in. They jiggle a little bit. You can find them under your engine cover and behind the fender flare liner on the right rear wheel well. I cant imagine you got water in the breather tubes as high up as they are. They are pretty well protected too. Id be more worried about my air intake. These things are beasts, but, that was deep water if it was over your hood. I cant imagine any harm was done. I wouldnt do that continually though. Perhaps someone else will chime in.... your electrical connections are supposed to be all water proof but id be concerned about that too going through something so deep.
jjeling is offline
post #5 of 36 Old 09-08-2012, 10:56 PM Thread Starter
toxicwaste29
I know. It was only deep for a few seconds. It was high enough though to get water in my cabin airways i think that where it was coming from, because i started leaking water onto my passenger floor and it was coming from behind the glove box. I am not planning on doing it continually. Should i be worried about changing my oil?
post #6 of 36 Old 09-08-2012, 11:16 PM
jjeling
Lol i bet it still runs. How long have u had it? Haha a few seconds. These are not invincible. Maybe someone else has some experience in this. I do not want to give u any misinformation.
jjeling is offline
post #7 of 36 Old 09-09-2012, 12:14 AM
Coolcatracing
I quick splash won't really harm anything as long as it doesn't get in the breather. If the engine is fine I personally wouldn't worry about changing any fluids.
08 Unlimited Rubicon 6 speed, 315/70-16 Kelly TSR, 1.5" Spidertrax spacers factory Moab's, Rubicon Express Flex arm 3.5" lift, Smittybilt XRC front bumper with D-rings, Body Armor Extreme rock slider steps, AEV snorkel, trimmed fender flares, Hella 8" HID driving lights
Coolcatracing is offline
post #8 of 36 Old 09-09-2012, 08:12 AM
HappyTrails
HappyTrails's Avatar
Was the puddle this bad?
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #9 of 36 Old 09-09-2012, 09:18 AM Thread Starter
toxicwaste29
It wasnt nearly that bad. What do you mean if the engine is fine? How would i know until the water destroys something inside it if there is water in it?
post #10 of 36 Old 09-09-2012, 09:20 AM Thread Starter
toxicwaste29
I have had the jeep for about a month or two. It only as 6,000 miles
post #11 of 36 Old 09-09-2012, 09:31 AM
michaelleegarre
If theirs water in your oil it should look like milk on the dipstick
Michael Garrett
1987 YJ - sold, 1995 ZJ - sold, 1998 XJ - sold, 2000 TJ
michaelleegarre is offline
post #12 of 36 Old 09-09-2012, 09:34 AM
Godholio
If it was bad, you would have known almost immediately. If it makes you feel better you can change the oil, but I wouldn't worry about it. If you drove out of there and the engine wasn't making absolutely horrible noises that you could not possibly miss, it's fine.
Utah Jeep Crew #148
No powerball here? How am I supposed to finance the mods?!?
'12 Sport...miss my YJ for all the wrong reasons though
Godholio is offline
post #13 of 36 Old 09-09-2012, 09:37 AM Thread Starter
toxicwaste29
Okay, i figured. I will check though to see if my breather tubes have the green caps on them. If not it might be time to change gear oil.
post #14 of 36 Old 09-09-2012, 09:39 AM
maniacal_rick
No one can give you a definitive answer...if your that worried, change your diff fluids and be done with it. I assume you are still driving the car now, so no water was ingested into the motor. The breather hoses are about 1-1.5 feet above the axles and have caps on them that allow them to breath, but wont allow light water to splash in. If you havent extended the breathers, and water was at the bottom of your door I would be willing to bet the breathers took in water.
maniacal_rick is offline
post #15 of 36 Old 09-09-2012, 09:42 AM Thread Starter
toxicwaste29
Water at the bottom of my doors? I thought the breather tubes were at the same level of my air intake but i might be wrong. In which case i should be okay, there is no way for me to know if i got water in my axles correct.
Fluids! when to change them. kylekae TJ Wrangler Technical Forum 5 08-09-2012 10:39 AM
Should I change these fluids? vman TJ Wrangler Technical Forum 8 09-07-2011 10:40 PM
Change fluids or not? stwolf TJ Wrangler Technical Forum 14 05-27-2009 06:54 PM
How do I change the fluids eprovenzano TJ Wrangler Technical Forum 1 01-20-2006 07:41 AM
Should I change fluids or not? Bren Gun TJ Wrangler Technical Forum 3 08-15-2005 01:21 PM
